Problem by connecting via AlwaysUp
mooijtje070
The Netherlands
Hi there!
I've got a little problem. I need WinSCP runs by AlwaysUp. I've installed about 7 servers and everything works fine, except 1 server. It wouldn't start and I think it's because an path with a space in it.
I tried multiple things, but nothing works.. This is what in my script is:
open ftp://server@server -rawsettings ProxyPort=0
lcd C:\path\path\path\path
cd /00 Path
keepuptodate C:\path\path\path\path /00 Path
Can someone help me?
mooijtje070
Re: Problem by connecting via AlwaysUp
Thanks for your quick response. I tried to do that, but it still not start. I also tried to upload in another path (without space) and that works, but we are not allowed to use that path.
mooijtje070
The Netherlands
I changed it to
cd "/00 Path"
keepuptodate C:\path\path\path\path "/00 Path"
But it still doesn't work.
