Upload to SFTP with Batch
AGG_MS
Dortmund
i tried several Times to generate a Batch Script to upload Files from Local C:\Users\%User%\Desktop\Test to an SFTP Server //vrspoftp/TEST/JAMA/OUT/ORDERS/.
I generate a fingerprint with WinSCP but it didn't work (sftp://vrspoftp;fingerprint=ssh-ed23418-AoEf9IR0MRCBMA1SS7ykBo9t-3zXrNYyiYkwffSUCds@183.94.1.89/vrspoftp/TEST/JAMA/OUT/ORDERS/)
To start the Upload I have the command line
put "C:\Users\%User%\Desktop\*.raw /vrspoftp/TEST/JAMA/OUT/ORDERS/"
What am I doing wrong?
With Greets from Germany AGG_MS
Re: Upload to SFTP with Batch
You didn't show us what are you doing, nor did you describe your problem. Please give us more details. Also please attach a full session log file showing the problem (using the latest version of WinSCP).
AGG_MS
Problem is solved
Hello, the path was not correct in its syntax. Therefore the script did not work properly. In the line with the command open I have the folder where I want to store the data in the SFTP server. I then had this in the line with the put command.
After I deleted it, the upload of the data works without any problems. Furthermore, I no longer log on to the SFTP server with my fingerprint, but with a password, username and IP.
Re: Problem is solved
So was anything wrong with the generated code? Or was the problem caused by your modification of the generated code?
AGG_MS
The problem was not due to the code generated by WinSCP but to my modification in the command line. This is called after you have logged on to the SFTP server in the first line. My syntax was wrong in this line, I had no specifications from the generation of the WinSCP code.
