Preserve timestamp is not preserving it when uploading files
marcebil
Argentina
I set the option to Preserve timestamp, but it does not preserve it, it just put the current date
Using WinSCP Version 5.21.5 (Build 12858 2022-10-06)
Re: Preserve timestamp is not preserving it when uploading files
Re: Copying file not preserving timestamp file
You are using the FTP protocol. In FTP, command MFMT can be used to set remote file timestamps. Your server does not support it. Some servers also support non-standard syntax of MDTM command for the same purpose. Your server does not support that either.
Though actually, your server is ProFTPD, which does support MFMT. Maybe you are using some old version.
