Date restriction for WinSCP 4.3.7
ZTARMOA
For WinSCP 4.3.7 the script is downloading the files the only issue filemask=">=today" is not working, as when i run the script all old files are downloaded to local folder as well.
Script:
option batch on
open Farcha
option transfer binary
synchronize local -filemask=">=Today;|*.tmp"  D:\FTP\RNC2  /bam/common/fam/famlogfmt/pchr
Re: Date restriction for WinSCP 4.3.7
WinSCP 4.3.7 is over 10 years old! Do not use it. That also explains why the filemask=">=today" does not work.
Please use the latest version of WinSCP.
ZTARMOA
Issue resolved with by changing the advance setting, go to connection under this header click on TLS/SSL set the min and Max to TLS/SSL 1.0 version from the drop down
Thanks Admin
