WinSCP doesn't follow S3 bucket naming convention
Re: WinSCP doesn't follow S3 bucket naming convention
I get "The specified bucket is not valid" from the AWS when I try that.
Sorry, I do not understand what should the log show. To me it looks like you are using WinSCP to access existing bucket IGR-DataLake-FAT. What's wrong about that? Am I missing something?
mminihold
Yes. Correct. The bucket IGR-DataLake-FAT is and can be accessed with WinSCP without error. And that's the problem. IGR-DataLake-FAT isn't a valid bucket name! Bucket names can only be lower case and have to follow some rules. It's even worse. The bucket was created with WinSCP which brakes the naming rules and the compatibility. See Amazon S3 bucket naming requirements https://docs.aws.amazon.com/AmazonS3/latest/userguide/bucketnamingrules.html for correct naming.
As I wrote before, when I try to create IGR-DataLake-FAT in WinSCP, I get "The specified bucket is not valid" response from AWS.
I've asked you for a log file showing how you can create such bucket in WinSCP.
