Always use the last opened local directory
This is my first post to the forum as I cannot find solution to my problem. I have been using WinSCP for some time now, but cannot find a way to do this:
I want WinSCP remember the last opened local directory no matter which remote server a start session to. I do not want to go into Advance property of each session to change this.
So, if I open
Thanks...
So, if I open
C:\Arun\Pictures
, then no matter which remote server I connect to, the local directory should stay at C:\Arun|Pictures
. Now, when I change the local directory to C:\Arun\Documents
, then WinSCP should save it. Next time, when I launch WinSCP, the local directory should stay at C:\Arun\Documents
and the same local directory should be used no matter which remote server I open a session to. This is the behavior in FileZilla and I cannot find a way to do this in WinSCP. WinSCP keeps a track of local directory on a per session basis and keeps changing it automatically. I have, on numerous occasions, ended up downloading files from remote servers to wrong local directory because WinSCP changed the local directory. Kindly help.
Thanks...
