How to modify the directory listing in .NET assembly
                In relation to my previous post:
Testing for remote directory existence before copying files
It appears that my directory listing format cannot be parsed. I have seen several posts where the suggested solution is to modify the
I've found some pages on this subject such as Converting Script to Code Based on .NET Assembly
however I can't see how to actually do the mapping. I'm assuming that you create a custom command string that is run in place of the
Mote - I cannot use SFTP as the server only supports SCP.
Thanks.
ls command using sed to produce a format that will be parsed correctly, but I cannot see how to do this in .NET. Can someone point me in the direction of the doco or an example of how to do this?
ls command; I should be able to make a script but how is the mapping done?
Thanks.
