Add Flag
elshanR
Azerbaijan
Add Flag
Hello
i have problem with flags when i upload file to remote I get error code 4. SFTP soft support team answered that
I believe this is an issue with the WinSCP client the user is using.
The client does not send the SSH_FXF_RENAME_OVERWRITE flag as part of the rename request. That flag is required for replacing an existing file on rename.
From the SSH SFTP spec:
If flags does not include SSH_FXP_RENAME_OVERWRITE, and there already
exists a file with the name specified by newpath, the server MUST
respond with SSH_FX_FILE_ALREADY_EXISTS.
They will need to delete the existing file first, or contact WinSCP to see if there is a way to add that flag to the rename request.
So is it possible to add this flag on WinSCP?
Re: Add Flag
