WinSCP-5.21.X using a proxy never see the host key prompt.
nicko
Michigan USA
No issue with WinSCP 5.19.5 using proxy to connect to ftp-pointillist-com
  • WinSCP-Logs.zip (4.31 KB, Private file)
Description: WinSCP Session Log
Re: WinSCP-5.21.X using a proxy never see the host key prompt.
Please attach a full session log files from both versions.
nicko
Michigan USA
Attached.
Description: WinSCP Session Logs
Can you please post Debug 2 level logs from both versions?
nicko
Michigan USA
WinSCP Debug 2 log files 2023-03-06
  • WinSCP-Logs-2023-03-06.zip (5.35 KB, Private file)
Description: WinSCP Debug 2 log files 2023-03-06
Thanks. I have sent you an email with a debug version of WinSCP to the address you have used to register on this forum.
WinSCP-5.21.X using a proxy never see the server host key prompt
WinSCP-5.21.X using a proxy never see the server host key prompt like when utilizing WinSCP 5.19.5.
  • WinSCP-6.0.2-not-working-2023-03-08.zip (613.23 KB, Private file)
Description: Trace file
nicko
Michigan USA
Re: WinSCP-5.21.X using a proxy never see the server host key prompt
Description: Trace File as requested.
