Trying to upload an entire directory structure in one hit
SirClickalot
UK
I have WinSCP working nicely at the command line (Windows 11) for single files in the 'current' directory- (i.e. the directory in which the batch file is located) directory using...
  /log="C:\my-dir\WinSCP.log" /ini=nul ^
  /command ^
    "open ftp://username:password@host/ -rawsettings CacheDirectories=0 CacheDirectoryChanges=0" ^
    "put *.pdf /public_html/assets/PDF/" ^
    "exit"
But, what I really need is for ALL pdf files (and only pdf files) in the current directory AND all those in subdirectories PLUS I need the subdirectory structure to be honoured and created on the remote if they don't already exist.
Is that actually possible? – maybe I'm missing a simple switch but I cannot find it in the documentation.
Many thanks everyone
Nick
SirClickalot
Replacing spaces in paths and leaf filenames
Is it anyway possible to replace all SPACES (%20) in the original path/filename with dashes (-)?
I have a had another read through the documentation but I cannot see anything obvious 'though there is a mention of 'replace' but I don't quite understand it.
Thank you
Re: Replacing spaces in paths and leaf filenames
No there's no such built-in replacement functionality for uploads.
It's no difficult to implement this though with use of some advanced scripting language (like PowerShell) and WinSCP .NET assembly.
