Move multiple sites into a new folder
Re: Move multiple sites into a new folder
There's no easy way, yet. You can vote the feature request here:
Issue 2041 – Allow operating with multiple sites on Login dialog
Meanwhile, all you can do is to export the WinSCP configuration to an INI file and do some smart (regex-based?) search and replace of the section names. Something like:
(\[Sessions\\)(.*\])=>$1\folder$2
And then import back (after removing the HKCU\SOFTWARE\Martin Prikryl\WinSCP 2\Sessions registry key).
Be careful, backup the WinSCP registry before.
