WinSCP-5.21.8 Error drag&drop
Updated from WinSCP-5.19.6-Portable to the latest version of WinSCP-5.21.8-Portable at the time of publication. And the problems started, I switched the interface to <Explorer >, re-entered and went problems with drag &drop when trying to throw over the aisles of the application gives an error! Error: WinSCP could not detect the folder where the files were dragged. If you click OK and move it again, then there is no error and the file has moved. In fact, this error occurs every time you start. But if the interface is returned to <Commander>, then there is no such error when dragging to the desktop, outside the application! In the old version, there is no such error. Tell me if it can be fixed?
