Getting the following error " Copying files to remote side failed. GCGN_Guns.pbo: Append/Restart not
Kaweraklu
Very new to working with WinSCP. I am transferring files to a server. I did one server and it worked just fine but realized the host was located in Brazil so had to uninstall everything and change to the US. Had to create a whole new session. All files transferred just fine like before but the last mod I am transferring I get the following error. Mind you this mod worked 3 days before on the other session.
GCGN_Guns.pbo: Append/Restart not permitted, try again
I have done the following. Deleted and uninstalled WinSCP to see if that helped nope. I have done the suggested going into transfer settings and unchecking the "Preserve timestamp" that did nothing so changed it back. How can I get this file to transfer without getting that error? I have gotten it over 20 times now. I thought maybe it's just the internet going out but it is not disconnecting.
The transfer speeds also are taking a long time almost 4 hours for a 2.9GB when it takes my PC 10-15mins to download that file. I checked the FAQ's that didn't help. I do need it to be FTP.
As I said very new so will need detailed step by step help.
Thank you!
Re: Getting the following error " Copying files to remote side failed. GCGN_Guns.pbo: Append/Restart not
jesenko.sokoljak
Bosnia
I have the same issue
At the very end of transfer I press Skip option of the popped dialog box (Abort/Retry/Skip/Skip All) and the transfer continues and finishes fully.
The issue started sometime in the beginning 2023. Remote server had no changes.
Description: xml log is empty, nothing recorded.
