Problems with scandinavian characters "File or Folder 'Operat÷r' does not exist" in WinSCP script
JPIT
Norway
I have recently taken over a WinSCP script at work that transfers files over from an old Windows Server 2012 R2 (Version 6.3 Build 9600) to another server using FTP protocol.
The script is a .bat (encoded with UTF-8 without BOM) that runs a /script for a .txt (also in UTF-8 no BOM) file that opens the FTP session.
The filepath from the server includes a Swedish letter ö. As in c:\operatör\files
I have an existing script that includes a filepath with no scandinavian letters and it works fine. But the second script comes with error:
System error. Code:2
The system cannot find the file specified
I tried various methods that I found online and on these forums to no luck. When I try a similar setup on my own PC it works just fine, but not on the 2012 server. However if I run .bat files that simply move files from the same folder they work if I include chcp 1252 in the script. But it does not work if I try that in the WinSCP .bat script. Nor other chcp like 65001 or 1252.
WinSCP version is 6.1 (Build 13674)
Is there a way to fix this or a workaround I can use?
I am also quite new to this role, so apologies if I misunderstand some technical details.
Thanks!
Re: Problems with scandinavian characters "File or Folder 'Operat÷r' does not exist" in WinSCP script
If you are using separate WinSCP script file, the chcp command have no effect on WinSCP (nor anything else in the batch file or its encoding).
Does the script file explicitly refer to the filename? Can you transfer that file in WinSCP GUI?
JPIT
Norway
The script name is rapport2.bat which contains the following:
"c:\program files (x86)\winscp\winscp" /script="c:\program files (x86)\winscp\rapporter2.txt" /log="c:\program files (x86)\winscp\rapporter2.log
pause
The pause is temporary to see the error. The .bat script is in the same folder as winscp.exe.
Rapporter2.txt file contains the following:
open rapporter2
put -delete C:\VA-Operatör\removed\OUTPUT\Esave\Dygnsrapporter\*.* /rapporter2/Esave/Dygnsrapporter/
The "removed" section also contains a letter ø in it, it is removed for privacy. The rapporter2 WinSCP session is a FTP with port 21. The same script works if I change the folders to something without scandinavian letters. I have attached the log file for rapporter2 with some information removed.
Thank you so much for taking your time to look into this.
  • rapporter2.log.txt (8.24 KB, Private file)
Description: This is a copy of the log exported to a new .txt file
JPIT
Norway
To answer these questions more concretely:
The filename of the file I want to transfer is simply Esave-Date" but it exists in the VA-Operatör folder. I transferring them via *.* inside the folder they exist. I can transfer the files just fine from the same path in the GUI.
JPIT
Norway
I must apologize, it seems the problem was not the ö after all. I copied my script from an existing script that gets some files from a folder with no Scandinavian letters and it works fine. So I thought to simply copy it and import my own filepath there. It seems the error actually occurs because there is a space in-between the VA-Operatör and projects, not the ö despite it not showing up properly in the cmd window. The script requires double quotes "". I previously tested with single quote ''. And I got a syntax error, I assumed then that you cannot have quotes in the filepath inside the script. Today I tested with double quotes "" and it worked just fine.
Thank you for taking time to look into this.
