HTTP command: [put]
Squidgy
HTTP command: [put]
I'm new to using WinSCP and try to learn the proper syntax and I get the error in my title when I run this put commanded.
put Test.txt Moving/
Anyone knows why.
Here is my logs for when I ran the command:
. 2023-08-11 11:27:53.064 Executing user defined command.
> 2023-08-11 11:27:53.064 put Test.txt Moving/
< 2023-08-11 11:27:53.114 500 HTTP command: [put]
. 2023-08-11 11:27:53.114 Disconnected from server
* 2023-08-11 11:27:53.117 (ESshFatal) **Lost connection.**
* 2023-08-11 11:27:53.117 Disconnected from server
* 2023-08-11 11:27:53.117 HTTP command: [put]
I then got disconnected from my server
I'm using FTP and my sever is a GoDaddy server.
Thanks.
Re: HTTP command: [put]
How exactly are you running the command?
I looks like you are executing it in WinSCP GUI console window. Why? What are you trying to achieve?
