Signature problem with Cloudflare R2
When I attempt to connect to Cloudflare R2 using the S3 protocol, I receive the following error:
This is what I can confirm/have tried, to no avail:---------------------------
Authentication failed.
The request signature we calculated does not match the signature you provided. Check your secret access key and signing method.
Connection failed.
OK Reconnect Help
- I have double checked the access key and secret.
- I tried re-generating a new set of keys.
- The key is a 'full access' admin key.
- I have tried changing the region from blank to auto.
