Incorrect MAC received on packet
whitedd
Split
Trying to download very large file... over 100GB... after one minutes WinSCP disconnecting from my server...error is:
Re: Incorrect MAC received on packet
Can you download the file in any other client?
whitedd
Split
re
The problem occurs exclusively if the transfer is done via SCP (batch file). Via SFTP, everything works normally, but it takes a long time to download. Log sent.
  • WinSCP.log (44.65 KB, Private file)
whitedd
Split
batch file
@echo off
  /log="C:\Users\XXXX\Desktop\WinSCP.log" /ini=nul ^
  /command ^
    "open scp://root@XXXX:XXXX/ -hostkey=""ssh-ed25519 255 XXXX"" -privatekey=""F:\ppk\XXXX.ppk"" -rawsettings PingType=1 SendBuf=0 SshSimple=0 TunnelPortNumber=1" ^
    "cd /home/BackupSite" ^
    "lcd ""C:\Users\XXXX\Desktop""" ^
    "get -delete *_XXXX.tar.gz" ^
    "exit"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
exit /b %WINSCP_RESULT%
whitedd
Split
I try this but have same error:
@echo off
  /log="C:\Users\XXXX\Desktop\DD-WinSCP.log" /ini=nul ^
  /command ^
  "open scp://root@XXXX:XXXX/ -hostkey=""ssh-rsa 3072 XXXX"" -privatekey=""F:\ppk\XXXXrsa.ppk"" -rawsettings PingType=1 AuthGSSAPIKEX=1 Cipher=""aes,chacha20,aesgcm,blowfish,3des,WARN,arcfour,des"" KEX=""rsa,ntru-curve25519,ecdh,dh-gex-sha1,dh-group16-sha512,dh-group17-sha512,dh-group18-sha512,dh-group15-sha512,dh-group14-sha1,WARN,dh-group1-sha1"" HostKey=""rsa,ed448,ed25519,ecdsa,dsa,WARN"" AddressFamily=1 RekeyBytes=0 RekeyTime=0 SendBuf=0 SshSimple=0" ^
    "cd /home/XXXX" ^
    "lcd ""C:\Users\XXXX\Desktop\""" ^
    "get -delete *.tar.gz" ^
    "exit"
  echo Success
) else (
  echo Error
whitedd
I found where the problem is. The error appeared only when using the Asus OpenWRT router. I replaced the router with an AsusWRT router and the problem disappeared. Please write to me if you know what the problem could be in the OpenWRT router. Thank you in advance.
Tino Bellmann
Invalid MAC
Solution: Power off Server + Router Hardware and restart. Delete WinSCP Profile for this Server. Add a new one for this device.
Works.
Maybe the error comes on, when changing hardware too often with same IP. Cant verify.
Tino Bellmann
Check your hardware
Please check your hardware, I also had a server with a mad Intel NIC. Runs super for years. Suddenly errors occured in WinSCP and PuTTY, esp. when transferring many and big files. Check and change your LAN Adapters (server / client).
