OpenVMS modification date wrong
Vadim
Copenhagen
I'm using WinSCP to edit files on OpenVMS over SFTP
My location is Denmark GMT+1, server located somewhere in US
I've just created test file and here is dir/full for it
test.txt;1                    File ID:  (63054,20,0)
Size:            1/16         Owner:    [VMS,VADIM]
Created:     4-JAN-2024 07:04:53.80
Modified:    4-JAN-2024 12:05:33.00 (1)
Expires:    <None specified>
Backup:     <No backup recorded>
Effective:  <None specified>
Recording:  <None specified>
Accessed:   <None specified>
Attr Mod:    4-JAN-2024 12:05:33.00
Data Mod:    4-JAN-2024 12:05:33.00
Current time on server is 4-JAN-2024 07:04:53.80
As you see creation timestamp is correct but others are not
I tried to use other FTP client, worked fine
Can I configure something or is this a bug?
Re: OpenVMS modification date wrong
Please attach a full session log file both from WinSCP and the other client.
To generate the session log file in WinSCP, enable logging, log in to your server and do the operation and only the operation that causes the error. Submit the log with your post as an attachment. Note that passwords and passphrases not stored in the log. You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names (unless they are relevant to the problem). If you do not want to post the log publicly, you can mark the attachment as private.
Vadim
Copenhagen
Attached
  • dir.log (1.84 KB, Private file)
  • filezilla.log (1.56 KB, Private file)
  • winscp_log.txt (15.97 KB, Private file)
It looks like a bug in the server to me.
Can you please post verbose logs from both WinSCP and FileZilla?
Don't you have a time offset configured in FileZilla?
