Script per download files
jonathan
Italy
Hi, I recently discovered WinSCP and so I'm completely unaware of its use.
I ask for help to solve a problem, I need to download files from some PCs that are on different segments of the LAN (e.g. 172.16.7.50 172.16.132.160 172.16.110) and I need a script that queries all of them from a central PC PCs and download some files and put them in some folders. Thanks everyone they will help me.
Re: Script per download files
Sorry, I do not know what "queries all of them from a central PC" means. Do you have some API to retrieve the list of servers?
jonathan
Hi, let me explain better, from a PC I create a routine that queries the various computers allowing me to download data. Thanks for the kind replies.
Sorry, that's as vague as before. What is "queries"?
Do you want to write a script that goes over a list of IP addresses/hostnames, connects to each and downloads some specific files from each?
Hi, thanks for the time you are dedicating to me, I did as you told me but unfortunately when I launch the script the winscp.com window opens but the cursor remains flashing. What could it depend on?
winscp.com
open scp://172.16.........
user
pass
get /usr/tprsystem/validations C:\validations
If it helps you, here is the script I run. If I execute one instruction at a time from the command line everything goes well........
Hi, sorry if I'm here again taking up your precious time. The solution you gave me for downloading the files is fine but, the following week, finding the destination folder already full, WinSCP freezes and waits for keyboard input. How can I solve it?
Thank you
  1. You are using 11 years old WinSCP 5.1.3. You urgently need to upgrade to the latest version.
  2. Your commandline syntax is wrong. It seems that you have something like "/ini" "=nul" there. It should be /ini=nul.
I'm not even sure that any of this is the actual cause of the problem you are facing. But it's hard to help, with all the side effects the above two points cause.
Hi, thank you for the valuable advice you give me. I updated the program and now everything works fine except that if you connect to a server and find it "down" the process stops and WinSCP closes. How can I make it go forward by skipping the "down" IP?
@Guest: If you use the solution, I've pointed you to above, then for each "IP" you start new WinSCP process. So it should not be a problem that WinSCP is closed. If you need further help, show us what exactly are you doing and some logs.
Hi, regarding your answer I attach three files, one is the batch, the other the script and the third the generated log. As you can see from the log, the session is interrupted and the program is closed when it connects to the PC with address 172.16.130.158 because it is turned off. How to overcome the inconvenience? Thank you always for your precious advice
