Host name path stripped in latest version
Connie.DeCinko@knighttrans.com
Arizona
I just updated to WinSCP 6.3.1. I went to add a new Login. I have several entries that have a path as part of the Host name, i.e. dev.mysite.com/wps/mycontenthandler/dav/fs-type1/themes because some users only have permissions to that nested folder.
I enter a Host Name, tab or click out of the field, and the path is stripped down to dev.mysite.com and my login fails.
Why did this behavior change in the new version?
Re: Host name path stripped in latest version
That's not a host name. Host name is just the dev.mysite.com. The rest is a path. WinSCP strips the path to Remote directory:
https://winscp.net/eng/docs/ui_login_directories
So it should work correctly.
If it does not, please attach a full session log file showing the problem (using the latest version of WinSCP).
