WinSCP .NET VB: Can't get attributes of file
precuset
When downloading multiple files and exception is thrown with the following error messages:
Script: Can't get attributes of file '/toPayerFusion/C337290N.H837PRD.C0270481.20240416.00001'.
No such file or directory.
vb code:
Dim localFolder As String = ConfigurationManager.AppSettings("ParseDirectory")
Dim sftpFolder As String = ConfigurationManager.AppSettings("SFTPFolder")
Dim sftpFolderPaperClaims As String = ConfigurationManager.AppSettings("SFTPFolderPaperClaims")
Dim sftpProcessFolder As String = sftpFolder + ConfigurationManager.AppSettings("SFTPProcessFolder")
Dim sftpProcessFolderPaperClaim As String = sftpFolderPaperClaims + ConfigurationManager.AppSettings("SFTPProcessFolder")
With sessionOptions
    .Protocol = Protocol.Sftp
    .HostName = ConfigurationManager.AppSettings("SFTPHost")
    .UserName = ConfigurationManager.AppSettings("SFTPUser")
    .Password = ConfigurationManager.AppSettings("SFTPPassword")
    .FtpSecure = FtpSecure.None
    '.TlsHostCertificateFingerprint = "18:7f:a3:ad:8e:e9:9e:3b:ab:03:a6:71:1a:b6:28:e5:f3:67:e8:85"
    .SshHostKeyFingerprint = "ssh-rsa-hGn3OiqHcSEVML4xIvmRDpGzhTEiHBpoQBhbs1U9rzo"
End With
sessionOptions.AddRawSettings("ProxyPort", "0")
Using session As New Session
    ' Connect
    Console.WriteLine("Open Connection....")
    session.SessionLogPath = ConfigurationManager.AppSettings("SessionLogPath")
    session.Open(sessionOptions)
    '/toPayerFusion/PaperClaims
    Console.Write("Get Files ")
    Dim files As List(Of RemoteFileInfo) = session.ListDirectory(sftpFolder).Files.Where(Function(x) x.IsDirectory = False).ToList()
    Console.WriteLine(files.Capacity)
    For Each file In files
        transferResult = session.GetFiles(file.FullName, localFolder, False, transferOptions)
        transferResult.Check()
        session.MoveFile(file.FullName, sftpProcessFolder + file.Name)
        For Each transfer In transferResult.Transfers
            Console.WriteLine("Upload of {0} succeeded", transfer.FileName)
        Next
    Next
WinSCP version:1.15.0.14890
Runtime version: v4.0.30319
Win version: Windows server 2019
Re: WinSCP .NET VB: Can't get attributes of file
