Error msg
sheau wei
Error msg
I have issue with the last file. Error msg below received:
General failure (server should provide error description).
Error code: 4
Error message from server: Failure
Common reasons for the Error code 4 are:
- Renaming a file to a name of already existing file.
- Creating a directory that already exists.
- Moving a remote file to a different filesystem (HDD).
- Uploading a file to a full filesystem (HDD).
- Exceeding a user disk quota.
What could be the next step for me to resolve the issue?
Re: Error msg
So did you check if your disk/quota is full?
Isn't the SG.txt file larger than the others? So that it is possibly the only one that triggers "Transfer to Temporary Filename"?
https://winscp.net/eng/docs/resume#automatic
If you need further help, please attach a full session log file showing both successful upload of some other file from/to the same directory and failed upload of the SG.txt (using the latest version of WinSCP).
