Problem excluding folders with synchronise and filemask
gabrigabri
italy
Hello everyone
I should exclude 3 folders and all their subfolders and files
from a copy with sync
I was thinking of using the -filemask option but I can't find documentation for using it
This is the code of my script:
option batch continue
option exclude  "E:\condivisa\ftp\locale\1\*;  E:\condivisa\ftp\locale\2\*"
open ftp://utente:1@127.0.0.1:21
synchronize remote  -mirror -delete -filemask="|1/"  E:\condivisa\ftp\locale\ /e/condivisa/ftp/remota/
the folder to exclude would only be:
but I noticed that it also excludes folders with the same name in other locations:
E:\condivisa\ftp\locale\2\1
Can someone help me?
Thanks in advance
Re: problem excluding folders with synchronise and filemask
Hi
Work well
But I have problem excluding folders "with space on the name"
Tha syntax change with this variant?
Very thanks
There should be no problem with spaces in filenames in the file mask.
If you need further help, we need your new script and corresponding log file.
