SessionOptions Error
I have a script that works in PowerShell using the WinSCP DLL it uploads a file and receive a receipt and I have copied out the relevant parts for another script using the same methodology.
I use variables with the relevant info and have ** out the ppk name
And I get the following error
Not that helpful.
The only difference between the "working" code and this is that I get a
Where am I going wrong?
$sessionOptions = New-Object WinSCP.SessionOptions -Property @{ Protocol = [WinSCP.Protocol]::Sftp HostName = "$urlID" UserName = "$Username" Password = "$null" SshHostKeyFingerprint = "$certfp" SshPrivateKeyPath = "C:\Users\user\.ssh\*******.ppk" }
New-Object : The value supplied is not valid, or the property is read-only. Change the value, and then try again.
At line:1 char:19
+ $sessionOptions = New-Object WinSCP.SessionOptions -Property @{
+ CategoryInfo : InvalidData: (:) [New-Object], Exception
+ FullyQualifiedErrorId : SetValueException,Microsoft.PowerShell.Commands.NewObjectCommandThe only difference between the "working" code and this is that I get a
password=******* in the working one. From what I have been told we use SSH authentication using the fingerprint and the ppk so no password.
