Can't create .filepart with a file that has no extension.
Geoffww
Canada
I'm using 6.3.6. I have several commands getting and putting files with extensions that are working fine, just won't work with non extension files. I've browsed Google for a solution but none are working.
I've tried...
get /usr/bin/php   #  (this throws error and halts the script)
get /usr/bin/php*  #  (this throws error and halts the script)
get /usr/bin/php*. #  (this throws "file not found" but continues with the rest of the commands i.e. put)
My get command in a .bat file.
   "open sftp://root:[password]@%IPAddress%/ -hostkey=* -rawsettings ProxyPort=0" ^
   "get /usr/bin/php* "%BuildDir%\Backup\PHP\"" ^
The error
Session started.
Active session: [1] root@10.0.0.100
php                       |            0 B |    0.0 KB/s | binary |   0%
Can't create file 'E:\Backup\PHP\php.filepart'.
System Error.  Code: 3.
The system cannot find the path specified
Error
Re: Can't create .filepart with a file that has no extension.
Please attach a full session log file showing a successful download of a file with an extension and failed download of a file from the same remote folder to the same local folder without an extension.
