Script adding an extra "/"
Deano82
UK
We have a bat script set up to move files from a local folder to a SFTP site using a program called Datamotion adapter which executes WinSCP to copy the files.
It is moving files to a folder called cacs on the SFTP site but we are getting the following error in the logs
Cannot create remote file '/"/cacs/"'.
No such file or directory.
The cacs folder already exists but it looks like the script is trying to add an extra / and trying to create a new folder. But we cant see anywhere in the script where it is doing this.
Has anyone come across this issue before?
Deano82
UK
This is the session log when we run the script where its failing:
. 2025-04-09 14:31:08.860 Getting real path for '.'
> 2025-04-09 14:31:08.860 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2025-04-09 14:31:08.876 Type: SSH_FXP_NAME, Size: 23, Number: 16
. 2025-04-09 14:31:08.876 Real path is '/'
. 2025-04-09 14:31:08.876 Startup conversation with host finished.
< 2025-04-09 14:31:08.876 Script: Session started.
< 2025-04-09 14:31:08.876 Script: Active session: [1] xxxxxx@xxxxxxxxxxxxxxx
> 2025-04-09 14:31:08.876 Script: put -delete ".\Downloads\72511367_NOTIFY-31a8bf94-1d58-427f-a6f8-d79d255c4b09.xml" ""cacs/""
. 2025-04-09 14:31:08.876 Copying 1 files/directories to remote directory ""cacs/" - total size: 20,869
. 2025-04-09 14:31:08.876   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask: "
. 2025-04-09 14:31:08.876   TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; EncryptNewFiles: Yes; ExcludeHiddenFiles: No; ExcludeEmptyDirectories: No; InclM: ; ResumeL: 0
. 2025-04-09 14:31:08.876   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2025-04-09 14:31:08.876 File: '.\Downloads\72511367_NOTIFY-31a8bf94-1d58-427f-a6f8-d79d255c4b09.xml' [2025-04-09T13:31:07.282Z] [20869]
. 2025-04-09 14:31:08.907 Copying ".\Downloads\72511367_NOTIFY-31a8bf94-1d58-427f-a6f8-d79d255c4b09.xml" to remote directory started.
. 2025-04-09 14:31:08.907 Binary transfer mode selected.
. 2025-04-09 14:31:08.907 Opening remote file.
> 2025-04-09 14:31:08.907 Type: SSH_FXP_OPEN, Size: 33, Number: 259
< 2025-04-09 14:31:08.923 Type: SSH_FXP_STATUS, Size: 29, Number: 259
< 2025-04-09 14:31:08.923 Status code: 2, Message: 259, Server: No such file, Language:
> 2025-04-09 14:31:08.923 Type: SSH_FXP_LSTAT, Size: 17, Number: 519
< 2025-04-09 14:31:08.954 Type: SSH_FXP_STATUS, Size: 29, Number: 519
< 2025-04-09 14:31:08.954 Status code: 2, Message: 519, Server: No such file, Language:
* 2025-04-09 14:31:08.954 (ETerminal) No such file or directory.
* 2025-04-09 14:31:08.954 Error code: 2
* 2025-04-09 14:31:08.954 Error message from server: No such file
. 2025-04-09 14:31:08.954 Asking user:
. 2025-04-09 14:31:08.954 Cannot create remote file '/"cacs/"'. ("No such file or directory.
. 2025-04-09 14:31:08.954 Error code: 2
. 2025-04-09 14:31:08.954 Error message from server: No such file")
< 2025-04-09 14:31:08.954 Script: Cannot create remote file '/"cacs/"'.
< 2025-04-09 14:31:08.954 Script: No such file or directory.
< 2025-04-09 14:31:08.954 Error code: 2
< 2025-04-09 14:31:08.954 Error message from server: No such file
. 2025-04-09 14:31:08.954 Answer: Abort
* 2025-04-09 14:31:08.954 (ESkipFile) Cannot create remote file '/"cacs/"'.
* 2025-04-09 14:31:08.954 No such file or directory.
Deano82
UK
and this is when we do a manual drag and drop via the GUI (which works fine and the files get coped over)
. 2025-04-09 14:36:46.486 Getting real path for '.'
> 2025-04-09 14:36:46.486 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2025-04-09 14:36:46.502 Type: SSH_FXP_NAME, Size: 23, Number: 16
. 2025-04-09 14:36:46.502 Real path is '/'
. 2025-04-09 14:36:46.533 Listing directory "/".
> 2025-04-09 14:36:46.533 Type: SSH_FXP_OPENDIR, Size: 10, Number: 267
< 2025-04-09 14:36:46.549 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
> 2025-04-09 14:36:46.549 Type: SSH_FXP_READDIR, Size: 13, Number: 524
< 2025-04-09 14:36:46.564 Type: SSH_FXP_NAME, Size: 413, Number: 524
> 2025-04-09 14:36:46.564 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2025-04-09 14:36:46.580 Type: SSH_FXP_STATUS, Size: 28, Number: 780
< 2025-04-09 14:36:46.580 Status code: 1
> 2025-04-09 14:36:46.580 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
. 2025-04-09 14:36:46.580 ..;d;0;2025-01-23T10:48:43.000Z;4;"0" [0];"1028" [1028];rwxr-xr-x;0
. 2025-04-09 14:36:46.580 dtf;d;0;2025-03-21T04:55:25.000Z;4;"1076" [1076];"1101" [1101];rwxr-xr-x;0
. 2025-04-09 14:36:46.580 cacs;d;0;2025-04-09T11:10:03.000Z;4;"1076" [1076];"1101" [1101];rwxrwxrwx;1
. 2025-04-09 14:36:46.626 Startup conversation with host finished.
. 2025-04-09 14:36:49.392 Cached directory change via "cacs" to "/cacs".
. 2025-04-09 14:36:49.392 Getting current directory name.
. 2025-04-09 14:36:49.392 Listing directory "/cacs".
> 2025-04-09 14:36:49.392 Type: SSH_FXP_OPENDIR, Size: 14, Number: 1291
< 2025-04-09 14:36:49.392 Type: SSH_FXP_STATUS, Size: 24, Number: 1028
. 2025-04-09 14:36:49.392 Discarding reserved response
< 2025-04-09 14:36:49.408 Type: SSH_FXP_HANDLE, Size: 13, Number: 1291
> 2025-04-09 14:36:49.424 Type: SSH_FXP_READDIR, Size: 13, Number: 1548
< 2025-04-09 14:36:49.439 Type: SSH_FXP_NAME, Size: 645, Number: 1548
> 2025-04-09 14:36:49.439 Type: SSH_FXP_READDIR, Size: 13, Number: 1804
< 2025-04-09 14:36:49.455 Type: SSH_FXP_STATUS, Size: 28, Number: 1804
< 2025-04-09 14:36:49.455 Status code: 1
> 2025-04-09 14:36:49.470 Type: SSH_FXP_CLOSE, Size: 13, Number: 2052
. 2025-04-09 14:36:49.470 ..;d;0;2025-01-23T10:48:43.000Z;4;"0" [0];"1028" [1028];rwxr-xr-x;0
. 2025-04-09 14:36:49.470 72509020_REFER-b9ee2c14-bfba-4066-aeb3-bdcb7947cd76.processed;-;7956;2025-04-09T08:37:41.000Z;4;"1076" [1076];"1101" [1101];rw-r--r--;0
. 2025-04-09 14:36:49.470 72510160_NOTIFY-6c203ff1-e2eb-4fb6-9b03-4309b7b43c58.processed;-;10829;2025-04-09T11:00:57.000Z;4;"1076" [1076];"1101" [1101];rw-r--r--;0
. 2025-04-09 14:36:54.252 Copying 1 files/directories to remote directory "/cacs/" - total size: 20,869
. 2025-04-09 14:36:54.252   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2025-04-09 14:36:54.252   TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; EncryptNewFiles: Yes; ExcludeHiddenFiles: No; ExcludeEmptyDirectories: No; InclM: ; ResumeL: 0
. 2025-04-09 14:36:54.252   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2025-04-09 14:36:54.252 File: 'C:\Program Files\DataMotion\DataMotion Adapter Service\Downloads\72511367_NOTIFY-31a8bf94-1d58-427f-a6f8-d79d255c4b09.xml' [2025-04-09T13:31:07.282Z] [20869]
. 2025-04-09 14:36:54.252 Copying "C:\Program Files\DataMotion\DataMotion Adapter Service\Downloads\72511367_NOTIFY-31a8bf94-1d58-427f-a6f8-d79d255c4b09.xml" to remote directory started.
. 2025-04-09 14:36:54.252 Binary transfer mode selected.
. 2025-04-09 14:36:54.252 Opening remote file.
> 2025-04-09 14:36:54.252 Type: SSH_FXP_OPEN, Size: 87, Number: 2307
< 2025-04-09 14:36:54.252 Type: SSH_FXP_STATUS, Size: 24, Number: 2052
. 2025-04-09 14:36:54.252 Discarding reserved response
< 2025-04-09 14:36:54.267 Type: SSH_FXP_HANDLE, Size: 13, Number: 2307
> 2025-04-09 14:36:54.267 Type: SSH_FXP_WRITE, Size: 20894, Number: 2822
> 2025-04-09 14:36:54.267 Type: SSH_FXP_CLOSE, Size: 13, Number: 3076
> 2025-04-09 14:36:54.267 Type: SSH_FXP_SETSTAT, Size: 83, Number: 2569
< 2025-04-09 14:36:54.299 Type: SSH_FXP_STATUS, Size: 24, Number: 2822
< 2025-04-09 14:36:54.299 Status code: 0
< 2025-04-09 14:36:54.299 Type: SSH_FXP_STATUS, Size: 24, Number: 3076
. 2025-04-09 14:36:54.299 Preserving timestamp [2025-04-09T13:31:07.000Z]
< 2025-04-09 14:36:54.299 Type: SSH_FXP_STATUS, Size: 24, Number: 2569
. 2025-04-09 14:36:54.299 Transfer done: 'C:\Program Files\DataMotion\DataMotion Adapter Service\Downloads\72511367_NOTIFY-31a8bf94-1d58-427f-a6f8-d79d255c4b09.xml' => '/cacs/72511367_NOTIFY-31a8bf94-1d58-427f-a6f8-d79d255c4b09.xml' [20869]
It's likely due to the doubled-double quotes in your put command:
put -delete ".\Downloads\...d79d255c4b09.xml" ""cacs/""
Use just "cacs/", or even no quotes at all: cacs/.
