Error Error listing directory '/opt/tomcat' After change to new laptop
Kong
After I change to a new laptop and reinstall WinSCP, it give me this error and not able to login as before.
> 2025-11-05 17:19:50.974 unset "LS_BLOCK_SIZE" ; echo "WinSCP: this is end-of-file:$?"
< 2025-11-05 17:19:50.993 WinSCP: this is end-of-file:0
. 2025-11-05 17:19:50.993 Changing directory to "/opt/tomcat".
> 2025-11-05 17:19:50.993 cd "/opt/tomcat" ; echo "WinSCP: this is end-of-file:$?"
< 2025-11-05 17:19:51.018 WinSCP: this is end-of-file:0
. 2025-11-05 17:19:51.019 Getting current directory name.
> 2025-11-05 17:19:51.019 pwd ; echo "WinSCP: this is end-of-file:$?"
< 2025-11-05 17:19:51.040 /opt/tomcat
< 2025-11-05 17:19:51.040 WinSCP: this is end-of-file:0
. 2025-11-05 17:19:51.098 Listing current directory.
> 2025-11-05 17:19:51.098 ls -la --full-time ; echo "WinSCP: this is end-of-file:$?"
. 2025-11-05 17:20:07.610 Waiting for data timed out, asking user what to do.
. 2025-11-05 17:20:07.610 Asking user:
. 2025-11-05 17:20:07.610 **Host is not communicating for 15 seconds.
. 2025-11-05 17:20:07.610 Wait for another 15 seconds?** ()
. 2025-11-05 17:20:55.115 Answer: Abort
. 2025-11-05 17:20:55.115 Attempt to close connection due to fatal exception:
* 2025-11-05 17:20:55.115 **Terminated by user.**
. 2025-11-05 17:20:55.115 Closing connection.
. 2025-11-05 17:20:55.115 Sending special code: 1
* 2025-11-05 17:20:55.782 (EFatal) **Terminated by user.**
* 2025-11-05 17:20:55.782 Error listing directory '/opt/tomcat'.
Kong
Hi I do not have access to my old computer. Yes, I use a SCP file, and I tried change to SFTP. It can't work as well. My colleague have share me his ini configuration file, but it wont work as well, when I want to go to parent directory it gives the same issue.
Re: Error Error listing directory '/opt/tomcat' After change to new laptop
Please post session log files from both your and your colleague's computer showing how he can access the folder and you cannot with the same settings.
