Unable to Upload Files with Korean Characters in the Filename
newto
We recently updated our WinSCP from 6.3.6 to 6.5.3 and get the following error message when attempting to upload a file with Korean characters in the filename:
Permission denied
Error Code: 3
Error message from server: Permission denied
We rolled back to version 6.3.6 and confirmed we could upload the files with no issues. We're using SFTP and connecting to an OpenFTP server on the distant end.
I've tried changing the UTF-8 encoding for filenames from Auto to On, and forcing it to use SFTP version 3, and also disabled the transfer to temporary file name option but I can't get it to work.
Thanks for any guidance.
Re: Unable to Upload Files with Korean Characters in the Filename
Thanks for your report. Please attach a full session log files from both versions of WinSCP showing upload of the same file. Use log level Debug 2.
Ok, and were you forcing the SFTP 6 with the old version too?
Or did it work with the default settings?
If it did work with the default settings, I'd still appreciate if you can post the logs.
