Multi-select files -> Upload in Background = entire folder queued instead
PuddingtonBeer
When I select multiple files in the local column to "upload in background", it only adds one entry to the queue that seems to represent the entire folder, not just the ones I selected.
Re: Multi-select files -> Upload in Background = entire folder queued instead
Can you please do screen recording?
Ok, it might be misunderstanding. An entry in WinSCP queue represents a transfer, not a file. So indeed, if you select multiple files, just one entry is added.
https://winscp.net/eng/docs/ui_queue#information
But it represents just the selected files, not an entire folder. I've understood that you believe that the entire folder was uploaded. I do not think that's the case. Or do you believe otherwise? If you do, please post both recording and session log file of the same upload.
PuddingtonBeer
I confess I haven't actually tried the transfer, so I'll do a full test and see what happens. When I observed this appearance I aborted and added the files manually one at a time. In any case, as a user, I want to see the list of files I'm queueing, not a summary line that could represent any number. I often prepare a list of files to upload before pulling the trigger, and wouldn't want to lose information from that list just because I used multi-select to add files. A summary line undermines part of the purpose of the queue, in my opinion.
Now that I understand how it works, I suppose I can just keep it in mind and add files one at a time for max clarity. It's not a huge problem.
