This guide contains simplified description of automating operations on FTP/SFTP server with WinSCP. You may want to see detailed documentation of the scripting functionality instead.
There is also WinSCP .NET assembly build on top of the scripting interface. If you plan to call WinSCP from your .NET code, or if your task requires conditional processing, loops or other control structures, you should better use the .NET assembly. This guide focuses on simple automation tasks using scripting interface only.
- Before Starting
- Commands
- Script file
- Using script
- Notes
- Modifying the script automatically
- Checking script results
- Example
- Further reading
Before Starting
Before starting you should:
Commands
- Open session using
opencommand. - Perform operation. For uploads use
putcommand. For downloads usegetcommand. For synchronization usesynchronizecommand. For other operations, see supported commands. - Exit scripting using
exitcommand.
For example a typical script to upload a file is:
# Connect to SFTP server using a password open sftp://user:password@example.com/ -hostkey="ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx" # Upload file put d:\examplefile.txt /home/user/ # Exit WinSCP exit
You can have WinSCP generate a script template for you or even a complete batch file.
Script file
Use the /script command line option to pass the script to the WinSCP executable. Generally, you should also use /ini=nul switch to isolate the script execution from GUI configuration. You can embed the complete command line into a Windows batch file (.bat), like as follows:
@echo off winscp.com /ini=nul /script=myscript.txt
Using script
- Make shortcut to it on desktop to ease execution. Either make shortcut to batch file (
.bat) or enter full command line to shortcut itself.1 - If the wrapping batch file takes filename as command line parameter (see below) you can:
- Make shortcut to it on desktop and use it by dropping files on the icon. Windows automatically run the batch file and passes path to dropped file as command-line parameter.
- In a similar way you can put the shortcut to the batch file into Explorer’s ‘Send To’ context menu (
C:\Users\username\AppData\Roaming\Microsoft\Windows\SendToin Windows Vista and newer). &winvista
- Schedule automatic execution.
Notes
When connecting to SSH host, you will need to accept its host key.
When connecting to FTPS or WebDAVS host with certificate signed by untrusted authority you will need to verify the certificate.
open mysession put %1% exit
winscp.com /ini=nul /script=script.tmp /parameter // c:\myfile.txt
rem Generate temporary script to upload %1 echo open mysession >> script.tmp echo put %1 >> script.tmp echo exit >> script.tmp rem Execute script winscp.com /ini=nul /script=script.tmp rem Delete temporary script del script.tmp
upload.bat c:\myfile.txt
See more hints on using parametrized batch file.
See guide to advanced scripting for examples of script generation using more powerful languages.
- Check exit code of WinSCP (exit code is the only relevant and reliable way to check if script completed successfully). See example below and FAQ.
- Save and inspect log file. XML log format is recommended. Use command-line parameter
/xmllog. - Save and inspect output of the script. Use output redirection.
Once you find out what was the result of the script, you can perform any action you like. E.g. after evaluating exit code of WinSCP, you can send a “success” or “error” email. For that use any command-line email client you like, e.g. sendmail2.
You should also make the batch file indicate a result in its exit code, particularly if it is called from some parent system (for example SSIS).
See an example batch file:
winscp.com /ini=nul /script=example.txt if %ERRORLEVEL% neq 0 goto error echo Success sendmail.exe -t < success_mail.txt exit /b 0 :error echo Error! sendmail.exe -t < error_mail.txt exit /b 1
A similar error handling is used in the batch file template that WinSCP can generate for you.
Where for example content of success_mail.txt may be:
From: script@example.com To: me@example.com Subject: Success The files were uploaded successfully.
If you require checking results of each command individually, you should better use the WinSCP .NET assembly. Alternatively, see guide to advanced scripting for examples of checking script results (including XML log parsing) using more powerful languages and guide to interpreting XML log for advanced scripting using C# language.
Example
Further reading
- Troubleshooting;
- Scripting documentation;
- Guide to advanced scripting;
- WinSCP .NET assembly;
- Command-line parameters;
- WinSCP executables;
- FAQ about scripting;
- Example scripts;
- Schedule file transfers or synchronization.
- Note that it is not possible to use
winscp.com(.comfiles in general) directly from a shortcut. Callwinscp.comfrom a batch file or usewinscp.exewith/consolecommand-line parameter.Back - When installing sendmail, you can ignore all references to
/usr/lib/(orc:\usr\lib) directories in its installation instructions, as you will be runningsendmail.exedirectly from a Windows batch file. Just place sendmail files to any convenient location, e.g. along with WinSCP.Back
