This guide contains a simplified description of automating operations on FTP/SFTP server with WinSCP. You may want to see detailed documentation of the scripting functionality instead.
There is also WinSCP .NET assembly built on top of the scripting interface. If you plan to call WinSCP from your .NET code or PowerShell, or if your task requires conditional processing, loops or other control structures, you should better use the .NET assembly. This guide focuses on simple automation tasks using scripting interface only.
- Before Starting
- Commands
- Generating script
- Using script
- Notes
- Modifying the script automatically
- Checking script results
- Example
- Further reading
Before Starting
Before starting you should:
Commands
- Open session using
opencommand. - Perform operation. For uploads use
putcommand. For downloads usegetcommand. For synchronization usesynchronizecommand. For other operations, see supported commands. - Exit scripting using
exitcommand.
For example a typical script to upload a file is:
# Connect to SFTP server using a password open sftp://user:password@example.com/ -hostkey="ssh-rsa 2048 xxxxxxxxxxx...=" # Upload file put d:\examplefile.txt /home/user/ # Exit WinSCP exit
ghfut
Generating script
You can have WinSCP generate a script template for you or even a complete batch file.
To generate a script for a file transfer:
- Connect in the GUI.
- Select the files you want to transfer.
- Use one of the file transfer commands: Upload, Download, Upload and Delete, Download and Delete.
- On the transfer confirmation dialog, setup transfer options (if you need any non default settings).
- Use the Transfer Settings > Generate Code command.
- The Generate transfer code dialog will appear with the generated script or code template.
Using script
- Make shortcut to it on desktop to ease execution. Either make shortcut to batch file (
.bat) or enter full command line to shortcut itself.1 - If the wrapping batch file takes filename as command line parameter (see below) you can:
- Make shortcut to it on desktop and use it by dropping files on the icon. Windows automatically run the batch file and passes path to dropped file as command-line parameter.
- In a similar way you can put the shortcut to the batch file into Explorer’s ‘Send To’ context menu (
C:\Users\username\AppData\Roaming\Microsoft\Windows\SendToin Windows Vista and newer). &winvista
- Schedule automatic execution.
Notes
When connecting to SSH host, you will need to accept its host key.
When connecting to FTPS or WebDAVS host with certificate signed by untrusted authority you will need to verify the certificate.
open mysession put %1% exit
winscp.com /ini=nul /script=script.tmp /parameter // c:\myfile.txt
rem Generate a temporary script to upload %1 ( echo open mysession echo put %1 echo exit ) > script.tmp rem Execute the script winscp.com /ini=nul /script=script.tmp rem Delete the temporary script del script.tmp
upload.bat c:\myfile.txt
See more hints on using parametrized batch file.
See Conditional processing in automation for a more complex example; and Advanced FTP/SFTP scripting for examples of script generation using more powerful languages.
- Check exit code of WinSCP (exit code is the only relevant and reliable way to check if script completed successfully). See example below and FAQ.
- Save and inspect log file. XML log format is recommended. Use command-line parameter
/xmllog. - Save and inspect output of the script. Use output redirection.
Once you find out what was the result of the script, you can perform any action you like: print a message, send an email, etc.
You should also make the batch file indicate a result in its exit code, particularly if it is called from some parent system (for example SSIS).
See an example batch file:
winscp.com /ini=nul /log=example.log /script=example.txt if %ERRORLEVEL% equ 0 ( echo Success exit /b 0 ) else ( echo Error! exit /b 1 )
A similar error handling is used in the batch file template that WinSCP can generate for you.
If you require checking results of each command individually, you should better use the WinSCP .NET assembly. Alternatively, see the guide Advanced FTP/SFTP scripting for examples of checking script results (including XML log parsing) using more powerful languages and the guide to Interpreting XML log for advanced scripting using C# language.
Example
Further reading
- Troubleshooting;
- Scripting documentation;
- Guide to Advanced FTP/SFTP scripting;
- WinSCP .NET assembly and COM library;
- Command-line parameters;
- WinSCP executables;
- FAQ about scripting;
- Example scripts;
- Schedule file transfers (or synchronization) to FTP/SFTP server.
