Collecting Session Details
  • Host name1 of the server2, such as ftp.example.com. Particularly when connecting to server hosting your website, note that the host name of the server, where you connect to manage the web site may not be the same as your website domain.
  • Protocol the server supports (FTP, SFTP, FTPS, etc.);
  • Account username;
  • Account password3.
  • IT Support department of company you work in;
  • IT Support department of university you study at;
Connecting
  • Select Session tab (it will be selected already if you are using WinSCP for the first time).
  • Select your File protocol. When you are about to use FTPS protocol, select FTP and then choose one of the FTPS invocation methods.
  • You may want to save your session details to a site (stored session) so you do not need to type them in every time you want to connect. Press Save button and type site name.
  • Press Login to connect.
  1. Or IP addressBack
  2. When you are trying to connect to iPhone, iPod Touch or iPad, replace term “server” on these pages with iPhone, iPod Touch or iPad. Learn how to connect to iPhone, iPod Touch or iPad.Back
  3. Or other mean of authentication.Back
Last modified: by martin – Currently locked by: 178.20.31.55
