Invalid access to memory - _ssh_send_port_open
Goto page
Previous, 1, 2, 3, 4, 5, Next
adm@...
Kann die entfernte Datei '/var/log/apache2/xxxx.de-combined.log' nicht öffnen - _ssh_send_port_open
using German Telekom as provider leaves you with the "feature" having a forced disconnect every night.
In former releases of WinSCP, the automatic reconned worked perfectly, now I face the problem,
that if I come back to WinSCP in the morning (after the forced disconnect) the screen looks quite normal.
However WinSCP is internaly in disconnected status. Trying to access remote files via SFTP lead to the error.
Looks like the reconnect in the night worked good enougth to display the WinSCP screens, but internaly the connection is gone.
Restarting the program solves...
WinSCP 5.9.2
Kann die entfernte Datei '/var/log/apache2/xxxx.de-combined.log' nicht öffnen.
(0062A1BA) _ssh_send_port_open
(00863846) C5073_3
(008658AE) ____ExceptionHandler
(00862668) __ExceptionHandler
(0008147F) ntdll.dll
(0006F02A) ntdll.dll.KiUserExceptionDispatcher
(0062A323) _get_ssh_exitcode
(006FBBAE) TSecureShell::CheckConnection
(006FA2A7) TSecureShell::Send
(007364E1) TSFTPFileSystem::SendPacket
(0073A49D) TSFTPFileSystem::SendPacketAndReceiveResponse
(0075EAC2) TSFTPFileSystem::SFTPOpenRemoteFile
(007629C5) TSFTPFileSystem::SFTPSink
(00760BEE) TSFTPFileSystem::SFTPSinkRobust
(007609E2) TSFTPFileSystem::CopyToLocal
(007856B5) TTerminal::CopyToLocal
(0001156D) TCustomScpExplorerForm::TemporarilyDownloadFiles
(00012191) TCustomScpExplorerForm::ExecuteFile
(00012776) TCustomScpExplorerForm::ExecuteFile
(00017F25) TCustomScpExplorerForm::DoDirViewExecFile
(00017DFA) TCustomScpExplorerForm::DirViewExecFile
(004082B4) Customdirview::TCustomDirView::Execute
(00405CC2) Customdirview::TCustomDirView::DoExecute
(0040688F) Customdirview::TCustomDirView::WMLButtonDblClk
(0024EC29) Vcl::Controls::TWinControl::WndProc
(00292B57) Vcl::Comctrls::TCustomListView::WndProc
(00372BEC) System::Classes::_18201
(0002C2B1) USER32.dll
(0000D885) USER32.dll
(0000CF12) USER32.dll.CallWindowProcW
(0007957A) COMCTL32.DLL
(00079561) COMCTL32.DLL
(0007939C) COMCTL32.DLL
(0002C2B1) US
john.klippenstein@...
Error changing directory to 'uncertainty-prototype' - _ssh_send_port_open
Double clicked on a folder on the server side view. Window had been open for a day or more.
WinSCP 5.9.1
Error changing directory to 'uncertainty-prototype'.
Invalid access to memory.
(0062968A) _ssh_send_port_open
(00862736) C5073_3
(0086479E) ____ExceptionHandler
(00861558) __ExceptionHandler
(000624F6) ntdll.dll
(006297F3) _get_ssh_exitcode
(006FADAA) TSecureShell::CheckConnection
(006F94A3) TSecureShell::Send
(0073550D) TSFTPFileSystem::SendPacket
(007394C9) TSFTPFileSystem::SendPacketAndReceiveResponse
(00739B02) TSFTPFileSystem::RealPath
(0073A23A) TSFTPFileSystem::RealPath
(00748495) TSFTPFileSystem::ChangeDirectory
(0077AA2E) TTerminal::ChangeDirectory
(00654AC3) TUnixDirView::ChangeDirectory
(00652EF6) TUnixDirView::ExecuteFile
(00405A42) Customdirview::TCustomDirView::DoExecute
(0040660F) Customdirview::TCustomDirView::WMLButtonDblClk
(0024EA59) Vcl::Controls::TWinControl::WndProc
(00292987) Vcl::Comctrls::TCustomListView::WndProc
(00372990) System::Classes::_18201
(000152F7) USER32.dll
(00015D35) USER32.dll
(0001FD3A) USER32.dll
(0001FD60) USER32.dll.CallWindowProcW
(0042BE5F) Dragdrop::TDragDrop::WndMethod
(000167BF) USER32.dll
(00862DA1) C5073_3
(0086437B) _ReThrowException
(00739FD5) TSFTPFileSystem::RealPath
(0077AA2E) TTerminal:%
registration@...
Invalid access to memory error - _ssh_send_port_open
I use WinSCP, switch to another application but then when I return to WinSCP to transfer files I get a memory access error and it says "Not Connected" on the bottom left of the window. I quit WinSCP, restart it and it works fine for minutes or hours before the memeory access error appears again.
I am connected to the remove server via a VPN. I know the connection is stable because other applications I am using at the same time rely on it and continue to work.
WinSCP 5.9.3
Error deleting file 'Payment.inc.bk'.
(0062AF9A) _ssh_send_port_open
(00866422) C5073_3
(0086848A) ____ExceptionHandler
(00865244) __ExceptionHandler
(0062B103) _get_ssh_exitcode
(006FDC6E) TSecureShell::CheckConnection
(006FC367) TSecureShell::Send
(00738681) TSFTPFileSystem::SendPacket
(0073C63D) TSFTPFileSystem::SendPacketAndReceiveResponse
(0074F624) TSFTPFileSystem::DoDeleteFile
(0074F79A) TSFTPFileSystem::DeleteFileW
(00779C53) TTerminal::DoDeleteFile
(00779B2A) TTerminal::DeleteFileW
(00778FBD) TTerminal::ProcessFiles
(00779DCC) TTerminal::DeleteFiles
(0001416B) TCustomScpExplorerForm::DeleteFiles
(0000E818) TCustomScpExplorerForm::ExecuteFileOperation
(0000EAB8) TCustomScpExplorerForm::ExecuteFileOperation
(0000EB3F) TCustomScpExplorerForm::ExecuteFileOperationCommand
(00036E59) TNonVisualDataModule::ExplorerActionsExecute
(003B521C) System::Actions::TContainedActionList::ExecuteAction
(0019C395) Vcl::Actnlist::TCustomAction::Execute
(00373100) System::Classes::_18201
(0000D1DF) USER32.dll
(0000CF9B) USER32.dll.DispatchMessageW
Re: Error changing directory to '..' - _ssh_send_port_open
kitchin@...
Error getting name of current remote directory - _ssh_send_port_open
Steps to repeat:
Our server had some bad inodes so we got this error in WinSCP. We get a similar error using the linux command "sftp":
# sftp name@example.com
Couldn't canonicalise: No such file or directory
Need cwd
On a previous server we saw it with American spelling:
Couldn't canonicalize: No such file or directory
Need cwd
But we are getting our server fixed by tech support, so I guess you need to somehow make cwd fail on a test server. Sorry!
Expected result:
WinSCP logs in.
Actual result:
WinSCP shows several modal popup windows about the error. Very annoying because there are about 10 modals to click through. Then they happen again if you switch tabs. Then again when you close the session.
One of the modals is actually a memory error, others are just reporting the server failure.
Thanks, and I'm a paid contributor by the way.
WinSCP 5.9.3
Error getting name of current remote directory.
(00866422) C5073_3
(0073CC76) TSFTPFileSystem::RealPath
(0073DC21) TSFTPFileSystem::GetHomeDirectory
(0074AA5D) TSFTPFileSystem::ReadCurrentDirectory
(00776F4D) TTerminal::ReadCurrentDirectory
(007743CA) TTerminal::GetCurrentDirectoryW
(00020C48) TCustomScpExplorerForm::PathForCaption
(000462CC) TScpCommanderForm::PathForCaption
(0008C1EC) TTerminalManager::UpdateAppTitle
(0008BB8C) TTerminalManager::DoSetActiveTerminal
(0008BB4A) TTerminalManager::SetActiveTerminal
(0008B183) TTerminalManager::FreeActiveTerminal
(00866A8D) C5073_3
(00868067) _ReThrowException
(0073D149) TSFTPFileSystem::RealPath
(007743CA) TT
webentwicklung@...
Zugriffsverletzung - ungültiger Zugriff auf den Speicher - _ssh_send_port_open
WinSCP 5.9.3
(00866422) C5073_3
(006FE7AF) TSecureShell::HandleNetworkEvents
(006FE93A) TSecureShell::ProcessNetworkEvents
(006FDF2B) TSecureShell::WaitForData
(006F9335) TSecureShell::Init
(006F8C0A) TSecureShell::Open
(00736A9B) TSFTPFileSystem::Open
(00771963) TTerminal::Reopen
(006C89FD) TTerminalThread::TerminalReopenEvent
(006C39C4) TSignalThread::Execute
(00098AD3) Userinterface::C20_0
(000152C2) KERNEL32.DLL.BaseThreadInitThunk
(0005F717) ntdll.dll
(0005F6DF) ntdll.dll
(00866A8D) C5073_3
(006F9443) TSecureShell::Init
Anmeldung fehlgeschlagen.
aaron.rangel@...
WinSCP 5.9.3
(00866422) C5073_3
(00016C02) KERNEL32.DLL.BaseThreadInitThunk
(00059B8D) ntdll.dll
(00059B55) ntdll.dll
Using username "root".
Access denied.
Authentication failed.
a@...
Error changing directory to '/etc/httpd/conf' - _ssh_send_port_open
WinSCP 5.9.3
Error changing directory to '/etc/httpd/conf'.
(00866422) C5073_3
(0073D3AE) TSFTPFileSystem::RealPath
(0074B609) TSFTPFileSystem::ChangeDirectory
(0077DEC6) TTerminal::ChangeDirectory
(0077E8B3) TTerminal::DoAnyCommand
(0077E5A7) TTerminal::AnyCommand
(007A26ED) TConsoleDialog::DoExecuteCommand
(007A280F) TConsoleDialog::ExecuteCommand
(007A24C7) TConsoleDialog::ExecuteButtonClick
(0024F13D) Vcl::Controls::TWinControl::WndProc
(001B72B4) Vcl::Stdctrls::TButtonControl::WndProc
(0024F2A3) Vcl::Controls::_17076
(002095EC) Vcl::Forms::TCustomForm::WndProc
(0080BD60) Vclcommon::C2754_0
(0024E784) Vcl::Controls::TWinControl::MainWndProc
(0000D4BB) USER32.dll
(00017B07) USER32.dll
(0006F004) ntdll.dll.KiUserCallbackDispatcher
(0000FBFB) USER32.dll.SendMessageW
(0004C369) COMCTL32.DLL
(0005C060) COMCTL32.DLL
(0000D885)
ronald.demneri@...
WinSCP 5.9.3
Error changing directory to '..'.
#0062AF9A# _ssh_send_port_open
#00866422# C5073_3
#0086848A# ____ExceptionHandler
#00865244# __ExceptionHandler
#0008147F# ntdll.dll
#0006F02A# ntdll.dll.KiUserExceptionDispatcher
#0062B103# _get_ssh_exitcode
#006FDC6E# TSecureShell::CheckConnection
#006FC367# TSecureShell::Send
#00738681# TSFTPFileSystem::SendPacket
#0073C63D# TSFTPFileSystem::SendPacketAndReceiveResponse
#0073CC76# TSFTPFileSystem::RealPath
#0073D3AE# TSFTPFileSystem::RealPath
#0074B609# TSFTPFileSystem::ChangeDirectory
#0077DEC6# TTerminal::ChangeDirectory
#006563D3# TUnixDirView::ChangeDirectory
#0065486A# TUnixDirView::ExecuteParentDirectory
#004088A8# Customdirview::TCustomDirView::Execute
#00406296# Customdirview::TCustomDirView::DoExecute
#00406E63# Customdirview::TCustomDirView::WMLButtonDblClk
#0024F13D# Vcl::Controls::TWinControl::WndProc
#0029306B# Vcl::Comctrls::TCustomListView::WndProc
#00373100# System::Classes::_18201
#0002C2B1# USER32.dll
#0000D885# USER32.dll
#0000CF12# USER32.dll.CallWindowProcW
#0007957A# COMCTL32.DLL
#00079561# COMCTL32.DLL
#0007939C# COMCTL32.DLL
#0042C913# Dragdrop::TDragDrop::WndMethod
#0000D1DF# USER32.dll
#0000CF9B# USER32.dll.DispatchMessageW
#00866A8D#%
levi.durfee@...
WinSCP 5.9.3
(00866422) C5073_3
(006563D3) TUnixDirView::ChangeDirectory
(0065486A) TUnixDirView::ExecuteParentDirectory
(004088A8) Customdirview::TCustomDirView::Execute
(00406296) Customdirview::TCustomDirView::DoExecute
(00406E63) Customdirview::TCustomDirView::WMLButtonDblClk
(0029306B) Vcl::Comctrls::TCustomListView::WndProc
(0042C913) Dragdrop::TDragDrop::WndMethod
(00866A8D)%
simongliddon@...
WinSCP 5.9.3
(00866422) C5073_3
(00866A8D)%
justeen@...
Не могу сменить каталог на '..' - _ssh_send_port_open
WinSCP 5.9.2
Не могу сменить каталог на '..'.
Ошибка доступа к памяти.
Трассировка стека:
(00863846) C5073_3
(00081D3F) ntdll.dll
(0073AAD6) TSFTPFileSystem::RealPath
(0073B20E) TSFTPFileSystem::RealPath
(00749469) TSFTPFileSystem::ChangeDirectory
(0077BA02) TTerminal::ChangeDirectory
(006555F3) TUnixDirView::ChangeDirectory
(00653A8A) TUnixDirView::ExecuteParentDirectory
(00037F6A) TNonVisualDataModule::ExplorerActionsExecute
(003B4D08) System::Actions::TContainedActionList::ExecuteAction
(0019BE81) Vcl::Actnlist::TCustomAction::Execute
(00863EB1) C5073_3
(0086548B) _ReThrowException
(0073AFA9) TSFTPFileSystem::RealPath
(006555F3)
Re: Не могу сменить каталог на '..' - _ssh_send_port_open
justeen@... wrote:
WinSCP 5.9.2
gaurav.pruthi88@...
WinSCP 5.9.3
(00866422) C5073_3
(00012368) kernel32.dll.BaseThreadInitThunk
(00038900) ntdll.dll
(000388D0) ntdll.dll
(00866A8D) C5073_3
lu9fcb@...
Error al intentar cambiar al directorio «/home/mummysg/httpdocs/to88» - _ssh_send_port_open
WinSCP 5.9.3
Error al intentar cambiar al directorio «/home/mummysg/httpdocs/to88».
Acceso a memoria no válido
Traza de la pila:
(00866422) C5073_3
(0065981A) TCustomUnixDriveView::Change
(00285E26) Vcl::Comctrls::TCustomTreeView::CNNotify
(0040C979) Customdriveview::TCustomDriveView::CNNotify
(002860E2) Vcl::Comctrls::TCustomTreeView::WndProc
(0006F8C4) ntdll.dll.KiUserCallbackDispatcher
(000638A8) COMCTL32.dll
(0002279B) COMCTL32.dll
(00022606) COMCTL32.dll
(0001C69E) COMCTL32.dll
(000212AE) COMCTL32.dll
(0000C
lonor@...
WinSCP 5.9.3
(0062AF9A)
(00866422)
(0086848A)
(00865244)
(0008A61F) ntdll.dll
(0062B103)
(006FE7AF)
(006FE93A)
(006FDF2B)
(006F9335)
(006F8C0A)
(00736A9B)
(00771963)
(006C89FD)
(006C39C4)
(00098AD3)
(000128F2) KERNEL32.DLL.BaseThreadInitThunk
(00064DE1) ntdll.dll
(00064DA9) ntdll.dll
Using username "lonor".
sathyendraprabhu1@...
Cannot change properties of file 'dec38_db2.del' - _ssh_send_port_open
WinSCP 5.9.2
Cannot change properties of file 'dec38_db2.del'.
(00863846) C5073_3
(0074CCF1) TSFTPFileSystem::SendCustomReadFile
(0074D062) TSFTPFileSystem::CustomReadFile
(0074CAA2) TSFTPFileSystem::ReadFile
(0074FA69) TSFTPFileSystem::ChangeFileProperties
(00778DDB) TTerminal::DoChangeFileProperties
(00778CAC) TTerminal::ChangeFileProperties
(00776AF9) TTerminal::ProcessFiles
(00778F58) TTerminal::ChangeFilesProperties
(000155D0) TCustomScpExplorerForm::SetProperties
(0000E6A7) TCustomScpExplorerForm::ExecuteFileOperation
(0000E91C) TCustomScpExplorerForm::ExecuteFileOperation
(0000E9A3) TCustomScpExplorerForm::ExecuteFileOperationCommand
(00036D1A) TNonVisualDataModule::ExplorerActionsExecute
(000374F1) USER32.dll
(00015C3B) USER32.dll
(0001553C) USER32.dll
(000152FB) USER32.dll.DispatchMessageW
agantelin@...
WinSCP 5.9.3
(00866422) C5073_3
(000380DA) TNonVisualDataModule::ExplorerActionsExecute
(00866A8D) C5073_3
galode@...
Impossible d'ouvrir le fichier distant '/etc/apache2/ports.conf' - _ssh_send_port_open
WinSCP 5.9.2
Impossible d'ouvrir le fichier distant '/etc/apache2/ports.conf'.
Accès mémoire invalide.
Trace de la pile :
(00863846) C5073_3
(004061AD) Customdirview::TCustomDirView::KeyDown
Re: Impossible d'ouvrir le fichier distant '/etc/apache2/ports.conf' - _ssh_send_port_open
hbpubgm@...
Error changing directory to 'mysql' - _ssh_send_port_open
WinSCP 5.9.2
Error changing directory to 'mysql'.
#0062A1BA# _ssh_send_port_open
#00863846# C5073_3
#008658AE# ____ExceptionHandler
#00862668# __ExceptionHandler
#00081D3F# ntdll.dll
#0006F8EA# ntdll.dll.KiUserExceptionDispatcher
#0062A323# _get_ssh_exitcode
#006FBBAE# TSecureShell::CheckConnection
#006FA2A7# TSecureShell::Send
#007364E1# TSFTPFileSystem::SendPacket
#0073A49D# TSFTPFileSystem::SendPacketAndReceiveResponse
#0073AAD6# TSFTPFileSystem::RealPath
#0073B20E# TSFTPFileSystem::RealPath
#00749469# TSFTPFileSystem::ChangeDirectory
#0077BA02# TTerminal::ChangeDirectory
#006555F3# TUnixDirView::ChangeDirectory
#00653A26# TUnixDirView::ExecuteFile
#00405CC2# Customdirview::TCustomDirView::DoExecute
#0040688F# Customdirview::TCustomDirView::WMLButtonDblClk
#0024EC29# Vcl::Controls::TWinControl::WndProc
#00292B57# Vcl::Comctrls::TCustomListView::WndProc
#00372BEC# System::Classes::_18201
#0042C32F# Dragdrop::TDragDrop::WndMethod
#00863EB1# C5073_3
#0086548B# _ReThrowException
#0073AFA9# TSFTP
galode@...
Erreur lors du changemenent de répertoire vers '..' - _ssh_send_port_open
WinSCP 5.9.3
Erreur lors du changemenent de répertoire vers '..'.
Trace de la pile :
(00866422) C5073_3
(00406781) Customdirview::TCustomDirView::KeyDown
(00866A8D) C5073_3
tm@...
ディレクトリ '/home/tsubu/test/wp-content/plugins' への移動のエラー。 - _ssh_send_port_open
WinSCP 5.9.2
メモリのアクセス違反
スタック トレース:
(00863846) C5073_3
(00658A3A) TCustomUnixDriveView::Change
(00285912) Vcl::Comctrls::TCustomTreeView::CNNotify
(0040C3A5) Customdriveview::TCustomDriveView::CNNotify
(00285BCE) Vcl::Comctrls::TCustomTreeView::WndProc
(0024ED8F) Vcl::Controls::_17076
(0024E270) Vcl::Controls::TWinControl::MainWndProc
(000638A8) COMCTL32.DLL
(0002279B)%
kurt.ludikovsky@...
Fehler beim Wechseln in Verzeichnis '/var/www/vhosts/biz-improver.at/httpdocs/css' - _ssh_send_port_open
I tried to drag&drop a file from the local windows-explorer to a directory which did not work and showed the forbiden symbol instead.
WinSCP was open for several days and there is a IP-Change from the provider on a daily basis. This usually is recovered from WinSCP, But might have been the issu this time.
I'll try to retart the session and redo the d&d.
So if you don't hear anything further, just ignore it.
Following the restart it worked as expected.
So just ignore it.
WinSCP 5.9.3
Fehler beim Wechseln in Verzeichnis '/var/www/vhosts/biz-improver.at/httpdocs/css'.
(00866422) C5073_3
(00015DE3) USER32.dll
(00015E41) USER32.dll
(0000F117) ntdll.dll.KiUserCallbackDispatcher
(000186C0) USER32.dll.SendMessageW
(0002B06D) COMCTL32.DLL
(000A846F) COMCTL32.DLL
(000A77FB) COMCTL32.DLL
(0004B30B) COMCTL32.DLL
(0004B226) COMCTL32.DLL
(000
gunasekar2020@...
Error deleting file 'zwqcls7tqgnxurk54111.jpg' - _ssh_send_port_open
WinSCP 5.9.3
Error deleting file 'zwqcls7tqgnxurk54111.jpg'.
(00866422) C5073_3
(0005A5DA) ntdll.dll
(000370C4) TNonVisualDataModule::ExplorerActionsExecute
sarazil@...
Error changing directory to '/home/tgentle/stage-tg/modules/Studio' - _ssh_send_port_open
After a while (10 mins or so), the connection that has been opened seems to error. For whatever reason, WinSCP doesn't notice and tries to carry on as normal, using this dead connection to open files and list folders, both ones it knows about and one's it's not yet explored or listed. This results in the error. If I duplicate the session, the connection will reset and both connections will work again.
I can reproduce this error on my own machine, it happens a few times a day.
WinSCP 5.9.3
Error changing directory to '/home/tgentle/stage-tg/modules/Studio'.
(00866422) C5073_3
(000080CC) USER32.DLL
(00008327) USER32.DLL
(00008527) USER32.DLL
(0003F594) ntdll.dll.KiUserCallbackDispatcher
(0000D8B4) USER32.DLL.SendMessageW
(0002CBDB) COMCTL32.DLL
(00073A51) COMCTL32.DLL
(00073770) COMCTL32.DLL
(0004CC98) COMCTL32.DLL
(0004CB9E) COMCTL32.DLL
(000080CC)%2
support@...
Erreur lors du changemenent de répertoire vers '/home/rnmh-dev/public_html/sites/all/modules' - _ssh_send_port_open
WinSCP 5.9.1
Erreur lors du changemenent de répertoire vers '/home/rnmh-dev/public_html/sites/all/modules'.
Trace de la pile :
(00862736) C5073_3
(00657F0A) TCustomUnixDriveView::Change
(00285742) Vcl::Comctrls::TCustomTreeView::CNNotify
(0040C125) Customdriveview::TCustomDriveView::CNNotify
(002859FE) Vcl::Comctrls::TCustomTreeView::WndProc
(0024EBBF) Vcl::Controls::_17076
(0024E0A0) Vcl::Controls::TWinControl::MainWndProc
(0000D885
Re: Error changing directory to '/home/tgentle/stage-tg/modules/Studio' - _ssh_send_port_open
WinSCP 5.9.3
(00866422) C5073_3
anonbk@...
WinSCP 5.9.2
Трассировка стека:
(00863846) C5073_3
(004082D4) Customdirview::TCustomDirView::Execute
sarma.naveen@...
WinSCP 5.9.3
(00866422) C5073_3
(00866A8D) C5073_3
simongliddon@...
Error changing directory to home directory - _ssh_send_port_open
Tried to click on Home button.
WinSCP 5.9.3
Error changing directory to home directory.
(00866422) C5073_3
(0074AACC) TSFTPFileSystem::HomeDirectory
(0077DB77) TTerminal::HomeDirectory
(0065633F) TUnixDirView::ChangeDirectory
(006549D8) TUnixDirView::ExecuteHomeDirectory
(00014F25) TCustomScpExplorerForm::HomeDirectory
(00046C12) TScpCommanderForm::HomeDirectory
(0003815C) TNonVisualDataModule::ExplorerActionsExecute
(00866A8D) C5073_3
(006549D8)%
info@...
Fehler beim Wechseln in Verzeichnis '..' - _ssh_send_port_open
WinSCP 5.9.2
Fehler beim Wechseln in Verzeichnis '..'.
(00863846) C5073_3
(000159D2) USER32.dll.CallWindowProcW
(00098CBA) COMCTL32.DLL
(00098CA1) COMCTL32.DLL
(00098ADC) COMCTL32.DLL
(0042C32F) Dragdrop::TDragDrop::WndMethod
(000152FB) U
d.liesenfeld@...
Fehler beim Wechseln in Verzeichnis '/var/www/vhosts/liesenfeld.de' - _ssh_send_port_open
After the computer wakes up from sleeping, the currently open session of winscp will be stuck. It won't access the directories and it will not reconnect.
WinSCP 5.9.3
Fehler beim Wechseln in Verzeichnis '/var/www/vhosts/liesenfeld.de'.
(00866422) C5073_3
(0002011A)guard32.dll
(00015D35) USER32.dll%0
infos@...
Erreur lors du changemenent de répertoire vers '/home/eestelneqz' - _ssh_send_port_open
WinSCP 5.9.3
Erreur lors du changemenent de répertoire vers '/home/eestelneqz'.
Trace de la pile :
(00866422) C5073_3
(0002279B) COMCTL32.DLL
(00022606) COMCTL32.DLL
(000222FC) COMCTL32.DLL
(0008A4D2) COMCTL32.DLL
(000212AE) COMCTL32.DLL
(0000D885%
abhishek.kumar@...
Error changing directory to 'mobeixlogs' - _ssh_send_port_open
WinSCP 5.9.3
Error changing directory to 'mobeixlogs'.
(00866422) C5073_3
(0003F27E) ntdll.dll.ZwWow64CallFunction64
(0003F9FA) ntdll.dll.KiUserExceptionDispatcher
(00654806) TUnixDirView::ExecuteFile
(00866A8D) C5073_3
Re: Fehler beim Wechseln in Verzeichnis '/var/www/vhosts/liesenfeld.de' - _ssh_send_port_open
WinSCP 5.9.3
(00866422) C5073_3
%0
Re: Fehler beim Wechseln in Verzeichnis '..' - _ssh_send_port_open
info@... wrote:
WinSCP 5.9.2
(00863846) C5073_3
tufelkinder@...
Cannot open remote file '/var/www/web/fgo2/static/js/outliner.js' - _ssh_send_port_open
WinSCP 5.9.3
Cannot open remote file '/var/www/web/fgo2/static/js/outliner.js'.
(00866422) C5073_3
(0008137F) ntdll.dll
(0006EF1A) ntdll.dll.KiUserExceptionDispatcher
(00760F86) TSFTPFileSystem::SFTPOpenRemoteFile
(00764E89) TSFTPFileSystem::SFTPSink
(007630B2) TSFTPFileSystem::SFTPSinkRobust
(00762EA6) TSFTPFileSystem::CopyToLocal
(00787B79) TTerminal::CopyToLocal
(00011709) TCustomScpExplorerForm::TemporarilyDownloadFiles
(0001232D) TCustomScpExplorerForm::ExecuteFile
(00012912) TCustomScpExplorerForm::ExecuteFile
(0001811D) TCustomScpExplorerForm::DoDirViewExecFile
(00017FF2) TCustomScpExplorerForm::DirViewExecFile
(00408888) Customdirview::TCustomDirView::Execute
(0002C271) USER32.dll
(0000D845) USER32.dll
(0000CED2) USER32.dll.CallWindowProcW
(0000CED2%2
barbushin@...
WinSCP 5.9.2
(0062A1BA)
(00863846)
(008658AE)
(00862668)
(0062A323)
(006FBBAE)
(006FA2A7)
(007364E1)
(0073A49D)
(0073AAD6)
(0073B20E)
(00749469)
(0077BA02)
(006555F3) @TUnixDirView@ChangeDirectory$qqr20System@UnicodeString
(00653A8A) @TUnixDirView@ExecuteParentDirectory$qqrv
(004082D4)
(00405CC2)
(0040688F)
(0024EC29)
(00292B57)
(00372BEC)
(0042C32F)
(00372BEC)
(00863EB1)
(0086548B)
(0073AFA9)
(0073B20E)
(00749469)
(0077BA02)
(004082D4)
(00405CC2)
(0040688F)
(0024EC29)
(00292B57)
(00372BEC)
(000374F1%
pierrecorell@...
Fehler beim Wechseln in Verzeichnis 'public_html/app' - _ssh_send_port_open
I always switch through a lot of programs and WinSCP is always one of them, this special error never came before. This time I got an inactive putty window without message - sometimes it happens when I am too long away, but this time no message - closed it via click on the close button of the window and got back to winscp, where I wanted to change to another directory to reconnect again. This message appeared, putty was already opened again.
WinSCP 5.9.3
Fehler beim Wechseln in Verzeichnis 'public_html/app'.
trans: invalid access to memory.
(00866422) C5073_3
(00095ADF) ntdll.dll
(000834AA) ntdll.dll.KiUserExceptionDispatcher
(00032E71) USER32.dll
(00017116) USER32.dll
(00016EF0) USER32.dll
(0002005D) USER32.dll
(00083484) ntdll.dll.KiUserCallbackDispatcher
(000163B2) USER32.dll.SendMessageW
(000659B8) COMCTL32.DLL
(00037957) COMCTL32.DLL
(000377BE) COMCTL32.DLL
(0004ED58) COMCTL32.DLL
(0002E5D1) COMCTL32.DLL
(00017116) USE
Description: {{hidden}} are variables I set
ya.sofwar@yandexcomn
WinSCP 5.9.2
Трассировка стека:
(00863846) C5073_3
(00080AFF) ntdll.dll
(0006EA1A) ntdll.dll.KiUserExceptionDispatcher
(0002A0A9) USER32.dll
(00011A0E) USER32.dll
(000110F2) USER32.dll.CallWindowProcW
(000613DA) COMCTL32.dll
(000613C1) COMCTL32.dll
(0006120C) COMCTL32.dll
konrad.grzyb@...
WinSCP 5.9.3
(0062AF9A)
(00866422)
(0086848A)
(00865244)
(0003F04E) ntdll.dll.ZwWow64CallFunction64
(0003F7CA) ntdll.dll.KiUserExceptionDispatcher
(0062B103)
(006FDC6E)
(006FC367)
(00738681)
(0073C63D)
(0073CC76)
(0073D3AE)
(0074B609)
(0077DEC6)
(006563D3) @TUnixDirView@ChangeDirectory$qqr20System@UnicodeString
(0065486A) @TUnixDirView@ExecuteParentDirectory$qqrv
(004088A8)
(00406296)
(00406E63)
(0024F13D)
(0029306B)
(00373100)
(0000C6C0) USER32.DLL.CallWindowProcW
(0003D15F) COMCTL32.DLL.DefSubclassProc
(0003D141) COMCTL32.DLL.DefSubclassProc
(0002B24C) COMCTL32.DLL
(0003CF10) COMCTL32.DLL
(0042C913)
(00373100)
(00009625) USER32.DLL
(0000967B) USER32.DLL.DispatchMessageW
(00866A8D)
(00868067)
(0073D149)
(0073D3AE)
(0074B609)
(0077DEC6)
(004088A8)
(00406296)
(00406E63)
(0024F13D)
(0029306B)
(00373100)
(0000C6C0)
aleccarval@...
Erro ao alterar o diretório para '/etc/nginx' - _ssh_send_port_open
WinSCP 5.9.3
Erro ao alterar o diretório para '/etc/nginx'.
Acesso inválido à memória
Rastreamento de pilha:
(00866422) C5073_3
(00062496) ntdll.dll
(00015DE8) USER32.dll
(00015E49) USER32.dll
(000186D0) USER32.dll.SendMessageW
(0001FD32) USER32.dll
spiele@...
WinSCP 5.9.3
(006FBB9C) TSecureShell::SendSpecial
(006FBBE1) TSecureShell::SendEOF
(00736AA7) TSFTPFileSystem::Close
(006FDA83) TSecureShell::Discard
(0064BA17) _sk_newlistener
(0061D1D2) C2447_0
(0062A2E1) _sshfwd_x11_is_local
(006FDA5C) TSecureShell::FreeBackend
(006DA7AB) TSCPFileSystem::Close
(006C9D63) TSecondaryTerminal::~TSecondaryTerminal
(0076E64B) TTerminal::~TTerminal
(0008A65E) TManagedTerminal::~TManagedTerminal
(0008BAB4) TTerminalManager::FreeTerminal
jason@...
Error changing directory to '/etc' - _ssh_send_port_open
WinSCP 5.9.3
Error changing directory to '/etc'.
#00866422# C5073_3
#000624F6# ntdll.dll
#0000F13E# ntdll.dll.KiUserExceptionDispatcher
#0065981A# TCustomUnixDriveView::Change
#00285E26# Vcl::Comctrls::TCustomTreeView::CNNotify
#0040C979# Customdriveview::TCustomDriveView::CNNotify
#002860E2# Vcl::Comctrls::TCustomTreeView::WndProc
#0024F2A3# Vcl::Controls::_17076
#0024E784# Vcl::Controls::TWinControl::MainWndProc
#000152F7# USER32.dll
#00015D35# USER32.dll
#00015DE3# USER32.dll
#00015E41# USER32.dll
#0000F117# ntdll.dll.KiUserCallbackDispatcher
#000186C0# USER32.dll.SendMessageW
#0002B06D# COMCTL32.DLL
#000A846F# COMCTL32.DLL
#000A77FB# COMCTL32.DLL
#0004B30B# COMCTL32.DLL
#0004B226# COMCTL32.DLL
#0001FD3A# USER32.dll
#0001FD60# USER32.dll.CallWindowProcW
frankie.tayar@...
Error changing directory to '/' - _ssh_send_port_open
clicking on any directory or writing it in the address field produce the issue.
It does not happen all the time. Closing and opening WinSCP solve the issue.
WinSCP 5.9.3
Error changing directory to '/'.
(00866422) C5073_3
fch.vianeos@...
WinSCP 5.9.3
(00866422) C5073_3
(00866A8D) C5073_3
ingjocen@...
Error al intentar cambiar al directorio «..» - _ssh_send_port_open
WinSCP 5.9.3
Error al intentar cambiar al directorio «..».
Traza de la pila:
(00866422) C5073_3
(000461C6) ntdll.dll.RtlRaiseStatus
(00046052) ntdll.dll.KiUserExceptionDispatcher
(000176EC) USER32.dll
(00017871) USER32.dll
(000133CA) USER32.dll
(000133F0) USER32.dll.CallWindowProcW
(000179B0) USER32.dll
(00017E97) USER32.dll.DispatchMessageW
(00866A8D) C5073_3
marco.knezevich@...
Errore cambiando cartella su '..' - _ssh_send_port_open
WinSCP 5.9.1
Errore cambiando cartella su '..'.
#0062968A# _ssh_send_port_open
#00862736# C5073_3
#0086479E# ____ExceptionHandler
#00861558# __ExceptionHandler
#00062496# ntdll.dll
#006297F3# _get_ssh_exitcode
#006FADAA# TSecureShell::CheckConnection
#006F94A3# TSecureShell::Send
#0073550D# TSFTPFileSystem::SendPacket
#007394C9# TSFTPFileSystem::SendPacketAndReceiveResponse
#00739B02# TSFTPFileSystem::RealPath
#0073A23A# TSFTPFileSystem::RealPath
#00748495# TSFTPFileSystem::ChangeDirectory
#0077AA2E# TTerminal::ChangeDirectory
#00654AC3# TUnixDirView::ChangeDirectory
#00652F5A# TUnixDirView::ExecuteParentDirectory
#00408054# Customdirview::TCustomDirView::Execute
#00405A42# Customdirview::TCustomDirView::DoExecute
#0040660F# Customdirview::TCustomDirView::WMLButtonDblClk
#0024EA59# Vcl::Controls::TWinControl::WndProc
#00292987# Vcl::Comctrls::TCustomListView::WndProc
#00372990# System::Classes::_18201
#0042BE5F# Dragdrop::TDragDrop::WndMethod
#000167BF# USER32.dll
#00016885# USER32.dll.DispatchMessageW
#00862DA1# C5073_3
#0086437B# _ReThrowException
#00739FD5# TSFTPFileSystem::RealPath
#00748495# T
david.scheiner@...
Cannot open remote file '/u01/oracle/Middleware/Oracle_WT1/instances/UAT_instance3/config/OHS/ohs3/moduleconf/vh1_customer_wl_ohs.conf' - _ssh_send_port_open
WinSCP 5.9.3
Cannot open remote file '/u01/oracle/Middleware/Oracle_WT1/instances/UAT_instance3/config/OHS/ohs3/moduleconf/vh1_customer_wl_ohs.conf'.
(00866422) C5073_3
(0000DDD1) TCustomScpExplorerForm::ExecuteFileOperation
(0001D837) TCustomScpExplorerForm::RemoteFileControlFileOperation
(0001DB94) TCustomScpExplorerForm::RemoteFileControlDDEnd
(004090F6) Customdirview::TCustomDirView::DDDragDetect
(00656172) TUnixDirView::DDDragDetect
(00405558) Customdirview::TCustomDirView::CNNotify
(0024A5F9) Vcl::Controls::TControl::WndProc
(0002C2B1)%
joe@...
Error changing directory to 'rc.d' - _ssh_send_port_open
WinSCP 5.9.3
Error changing directory to 'rc.d'.
(00866422) C5073_3
(00866A8D) C5073_3
(0073D149) TSFTPF
danieltuzes@...
I left my computer connected to a remote ssh server overnight, and the next day the path was not shown. I typed Ctrl+R to refresh the page, then maybe F5 (then I had to cancel an opening window), but the path bar war still empty. Then I tried to move 1 level up in the tree, then the error occured.
WinSCP 5.9.3
(00866422) C5073_3
(00866A8D) C5073_3
Description: Screenshot after the error occured. Note the empty path on the server side.
2016@...
Error changing directory to '/usr/share' - _ssh_send_port_open
Had rebooted Raspberry Pi and didnt notice the normal 'reconnecting' dialogue
WinSCP 5.9.3
Error changing directory to '/usr/share'.
(00866422) C5073_3
daria-dudina@...
Не удалось перейти в домашнюю папку - _ssh_send_port_open
WinSCP 5.9.3
Не удалось перейти в домашнюю папку.
Трассировка стека:
(00866422) C5073_3
(0003CF4E) ntdll.dll
(0003CDB6) ntdll.dll.KiUserExceptionDispatcher
(0074AABE) TSFTPFileSystem::HomeDirectory
(0000675B) USER32.DLL.CallNextHookEx
(00007C25) USER32.DLL
(000074E0) USER32.DLL
(000083CC) USER32.DLL.DispatchMessageW
(00866A8D) C5073_3
thomas.michaels@...
Cannot create remote file '/home1/eloccs/templates/q05.cfm' - _ssh_send_port_open
Pressed F5 to copy a file from the local directory to the remote, which I had done successfully ten minutes prior. /shrug
WinSCP 5.9.3
Cannot create remote file '/home1/eloccs/templates/q05.cfm'.
(00866422) C5073_3
(0076113C) TSFTPFileSystem::SFTPOpenRemote
(00773ACD) TTerminal::FileOperationLoop
(0075CAFE) TSFTPFileSystem::SFTPSource
(0075B52C) TSFTPFileSystem::SFTPSourceRobust
(0075A6BA) TSFTPFileSystem::CopyToRemote
(007872D5) TTerminal::CopyToRemote
(0000DCB0) TCustomScpExplorerForm::ExecuteFileOperation
(0000ECC6) TCustomScpExplorerForm::ExecuteCopyOperationCommand
(00037277) TNonVisualDataModule::ExplorerActionsExecute
(00866A8D) C5073_3
(0076179D) TSFTPFileSystem::SFTPOpenRemote
mdelascu@...
Happens after connection is lost and recovered, but cannot manage to reproduce it
WinSCP 5.9.3
(00866422) C5073_3
(0003E4EE) ntdll.dll
(0003E366) ntdll.dll.KiUserExceptionDispatcher
(00006831) USER32.DLL.CallNextHookEx
(00006A95) USER32.DLL
(00008889) USER32.DLL
(000088EC) USER32.DLL.DispatchMessageW
(00866A8D) C5073_3
(00014F25) TCustomScpExplorerForm%3
a@...
Error changing directory to '/var/www/scripts' - _ssh_send_port_open
WinSCP 5.9.3
Error changing directory to '/var/www/scripts'.
#00866422# C5073_3
#0000D4BB# USER32.dll
#00017B07# USER32.dll
#0006F8C4# ntdll.dll.KiUserCallbackDispatcher
#0000FBFB# USER32.dll.SendMessageW
#000638A8# COMCTL32.DLL
#0002279B# COMCTL32.DLL
#00022606# COMCTL32.DLL
#0001C69E# COMCTL32.DLL
#000212AE# COMCTL32.DLL
(0024F24E
k0t@...
WinSCP 5.9
Трассировка стека:
(00629596) _ssh_send_port_open
(0086216E) C5073_3
(008641D6) ____ExceptionHandler
(00860F90) __ExceptionHandler
(0005A466) ntdll.dll
(006296FF) _get_ssh_exitcode
(006FA4AE) TSecureShell::CheckConnection
(006F8BA7) TSecureShell::Send
(00735111) TSFTPFileSystem::SendPacket
(007390CD) TSFTPFileSystem::SendPacketAndReceiveResponse
(00739706) TSFTPFileSystem::RealPath
(00739E3E) TSFTPFileSystem::RealPath
(00748099) TSFTPFileSystem::ChangeDirectory
(0077A3B6) TTerminal::ChangeDirectory
(006549CB) TUnixDirView::ChangeDirectory
(00652E66) TUnixDirView::ExecuteParentDirectory
(00407ECC) Customdirview::TCustomDirView::Execute
(004058C2) Customdirview::TCustomDirView::DoExecute
(0040648F) Customdirview::TCustomDirView::WMLButtonDblClk
(0024E715) Vcl::Controls::TWinControl::WndProc
(00292643) Vcl::Comctrls::TCustomListView::WndProc
(0037264C) System::Classes::_18201
(0001FD22) USER32.dll
(0042BD7F) Dragdrop::TDragDrop::WndMethod
joerg@...
Fehler beim Wechseln in Verzeichnis '/opt/otrs/Custom/Kernel' - _ssh_send_port_open
suspend windows to disk inside a domain
recover outside of the domain
WinSCP 5.9.1
Fehler beim Wechseln in Verzeichnis '/opt/otrs/Custom/Kernel'.
(00862736) C5073_3
(0001581B) USER32.dll
(0001C167) USER32.dll
(00077E54) ntdll.dll.KiUserCallbackDispatcher
(00014EDE) USER32.dll.SendMessageW
(0007DBD8) COMCTL32.DLL
(00034F23) COMCTL32.DLL
(00034D8A) COMCTL32.DLL
(00066AE2) COMCTL32.DLL
(00039351) COMCTL32.DLL
none@...
Chyba při změně aktuálního adresáře na '..' - _ssh_send_port_open
WinSCP 5.9.3
Chyba při změně aktuálního adresáře na '..'.
Chyba přístupu do paměti.
(00866422) C5073_3
(000
Re: Fehler beim Wechseln in Verzeichnis '/opt/otrs/Custom/Kernel' - _ssh_send_port_open
WinSCP 5.9.1
(00862736) C5073_3
lszota@...
Błąd podczas przejścia do katalogu 'ola' - _ssh_send_port_open
WinSCP 5.9.3
Błąd podczas przejścia do katalogu 'ola'.
Naruszenie ochrony pamęci.
(00866422) C5073_3
(00866A8D) C5073_3
(0077DEC6) TTe
recosh@...
WinSCP 5.9.3
Трассировка стека:
(00866422) C5073_3
gmalato@...
gmalato@hotmail.com
WinSCP 5.9.3
Error changing directory to '/nfs/c09/h02/mnt/135397/domains/gmalato.com.br/html/labs/cdo/www/application/views/errors'.
#00866422# C5073_3
m.overmeyer@...
The connection failed, the auto-reconnect caused this exception.
WinSCP 5.9.3
(00866422) C5073_3
(00866A8D) C5073_3
jfelipe885@...
WinSCP 5.9.3
(0062AF9A)
(00866422)
(0086848A)
(00865244)
(0062B103)
(006FDC6E)
(006FC367)
(00738681)
(0073C63D)
(0073CC76)
(0073DC21)
(0074AABE)
(0077DB77)
(0065633F) @TUnixDirView@ChangeDirectory$qqr20System@UnicodeString
(006549D8) @TUnixDirView@ExecuteHomeDirectory$qqrv
(00014F25)
(00046C12)
(0003815C)
(003B521C)
(0019C395)
(00373100)
(00866A8D)
(00868067)
(0073D149)
(0073DC21)
(0074AABE)
(0077DB77)
(00014F25)
(00046C12)
(0003815C)
(003B521C)
(0019C395)
(00373100)
paulvancingel@...
Error changing directory to '/home/oracle' - _ssh_send_port_open
WinSCP 5.9.4
Error changing directory to '/home/oracle'.
(0062B1EA) _ssh_send_port_open
(00866B5E) C5073_0
(00868BC6) ____ExceptionHandler
(00865980) __ExceptionHandler
(0062B353) _get_ssh_exitcode
(006FDEBE) TSecureShell::CheckConnection
(006FC5B7) TSecureShell::Send
(007388D1) TSFTPFileSystem::SendPacket
(0073C88D) TSFTPFileSystem::SendPacketAndReceiveResponse
(0073CEC6) TSFTPFileSystem::RealPath
(0073D5FE) TSFTPFileSystem::RealPath
(0074B859) TSFTPFileSystem::ChangeDirectory
(0077E15A) TTerminal::ChangeDirectory
(00659A6A) TCustomUnixDriveView::Change
(00285F52) Vcl::Comctrls::TCustomTreeView::CNNotify
(0040CAA5) Customdriveview::TCustomDriveView::CNNotify
(0024F269) Vcl::Controls::TWinControl::WndProc
(0028620E) Vcl::Comctrls::TCustomTreeView::WndProc
(0024F3CF) Vcl::Controls::_17076
(0024E8B0) Vcl::Controls::TWinControl::MainWndProc
(0037322C) System::Classes::_18201
office@...
Érvénytelen memóriaelérés - _ssh_send_port_open
WinSCP 5.9.4
Veremkivonat:
(00866B5E) C5073_0
(0076B652) TSFTPUploadQueue::SendPacket
(0075E4C7) TSFTPFileSystem::SFTPSource
(0075B77C) TSFTPFileSystem::SFTPSourceRobust
(0075A90A) TSFTPFileSystem::CopyToRemote
(00787619) TTerminal::CopyToRemote
(0001F704) TCustomScpExplorerForm::RemoteFileControlDragDropFileOperation
(0001F890) TCustomScpExplorerForm::RemoteFileControlDDFileOperation
(006559DE) TUnixDirView::PerformItemDragDropOperation
(004085A6) Customdirview::TCustomDirView::DDProcessDropped
(0042CB4B) Dragdrop::TDragDrop::WndMethod
actividades@...
WinSCP 5.9.4
Traza de la pila:
(00866B5E) C5073_0
(00656623) TUnixDirView::ChangeDirectory
(00654ABA) TUnixDirView::ExecuteParentDirectory
(0003816A) TNonVisualDataModule::ExplorerActionsExecute
(003B5348) System::Actions::TContainedActionList::ExecuteAction
(0019C4C1) Vcl::Actnlist::TCustomAction::Execute
(008671C9) C5073_0
(008687A3) _ReThrowException
(0073D399) TSFTPFileSystem::RealPath
joerg.folckers@...
after suspend to disk
WinSCP 5.9.4
(00866B5E) C5073_0
(00066AD2) COMCTL32.DLL
devaa@...
Error changing directory to '/home/dev/newdisk/dev/edt-tools/vega-automations/finance/forgerock/roles/openam-config/tasks' - _ssh_send_port_open
WinSCP 5.9.3
Error changing directory to '/home/dev/newdisk/dev/edt-tools/vega-automations/finance/forgerock/roles/openam-config/tasks'.
#00866422# C5073_3
#0008A9AF# ntdll.dll
#00077F5A# ntdll.dll.KiUserExceptionDispatcher
#000374E1# USER32.dll
#00015C2B# USER32.dll
#0001580B# USER32.dll
#0001C157# USER32.dll
#00077F34# ntdll.dll.KiUserCallbackDispatcher
#00014ECE# USER32.dll.SendMessageW
#0007DBD8# COMCTL32.DLL
#00034F23# COMCTL32.DLL
#00034D8A# COMCTL32.DLL
#00066AD2# COMCTL32.DLL
#00039351# COMCTL32.DLL
sterrenman@...
Error changing directory to '/srv/users/serverpilot/apps/schoolproj-testcenter/public' - _ssh_send_port_open
WinSCP 5.9.1
Error changing directory to '/srv/users/serverpilot/apps/schoolproj-testcenter/public'.
(00862736) C5073_3
(000829CF) ntdll.dll
(0006F3CA) ntdll.dll.KiUserExceptionDispatcher
(00033A09) USER32.dll
(000117DB) USER32.dll
(000111D5) USER32.dll
(000184D7) USER32.dll
(0006F3A4) ntdll.dll.KiUserCallbackDispatcher
(0000CF1B) USER32.dll.SendMessageW
(00062036) COMCTL32.DLL
(000225F4) COMCTL32.DLL
(00022464) COMCTL32.DLL
(0001C622) COMCTL32.DLL
(00021185) COMCTL32.DLL
(00010C52)
sq5nry@...
Error changing directory to '/export/home/pto/sentinel-2.4_offline/build/target/ivy-caches/offline-resolvers.cache' - _ssh_send_port_open
WinSCP 5.9.3
Error changing directory to '/export/home/pto/sentinel-2.4_offline/build/target/ivy-caches/offline-resolvers.cache'.
#00866422# C5073_3
#0008A61F# ntdll.dll
#00077E7A# ntdll.dll.KiUserExceptionDispatcher
#000374F1# USER32.dll
#00015C3B# USER32.dll
#0001581B# USER32.dll
#0001C167# USER32.dll
#00077E54# ntdll.dll.KiUserCallbackDispatcher
#00014EDE# USER32.dll.SendMessageW
#00066AE2# COMCTL32.DLL
#00015C3B#
taurosro@...
Erro ao alterar o diretório para 'account' - _ssh_send_port_open
WinSCP 5.9.3
Erro ao alterar o diretório para 'account'.
(00866422) C5073_3
(0000D19F) USER32.dll
(0000CF5B) USER32.dll.DispatchMessageW
(00866A8D) C5073_3
(00868067) _R
jozsef.dudas@...
Usually I have 10-15 sessions open all day, and next they when I try to reach them, it needs reconnect. and when I press reconnect, this error appears, and then clicking again on reconnect, everything works.
WinSCP 5.9.4
(00866B5E) C5073_0
(006FE9FF) TSecureShell::HandleNetworkEvents
(006FEB8A) TSecureShell::ProcessNetworkEvents
(006FE17B) TSecureShell::WaitForData
(006F9585) TSecureShell::Init
(006F8E5A) TSecureShell::Open
(00736CEB) TSFTPFileSystem::Open
(00771BF7) TTerminal::Reopen
(006C8C4D) TTerminalThread::TerminalReopenEvent
(006C3C14) TSignalThread::Execute
(00098B63) Userinterface::C20_0
(0005FFD7) ntdll.dll
(0005FF9F) ntdll.dll
(008671C9) C5073_0
(006F9693) TSecureShell::Init
jozsef.dudas@...
Cannot open remote file '/etc/asterisk/extensions.conf' - _ssh_send_port_open
WinSCP 5.9.4
Cannot open remote file '/etc/asterisk/extensions.conf'.
(00866B5E) C5073_0
(007611D6) TSFTPFileSystem::SFTPOpenRemoteFile
(007650D9) TSFTPFileSystem::SFTPSink
(00763302) TSFTPFileSystem::SFTPSinkRobust
(007630F6) TSFTPFileSystem::CopyToLocal
(00787EBD) TTerminal::CopyToLocal
(00018156) TCustomScpExplorerForm::DoDirViewExecFile
(004089B4) Customdirview::TCustomDirView::Execute
(004063C2) Customdirview::TCustomDirView::DoExecute
(00406F8F) Customdirview::TCustomDirView::WMLButtonDblClk
(00293197) Vcl::Comctrls::TCustomListView::WndProc
WinSCP 5.9.4
(00866B5E) C5073_0
Re: Error changing directory to '/export/home/pto/sentinel-2.4_offline/build/target/ivy-caches/offline-resolvers.cache' - _ssh_send_port_open
sq5nry@... wrote:
WinSCP 5.9.3
#00866422# C5073_3
#00015C3B#
Re: Invalid access to memory - _ssh_send_port_open
WinSCP 5.9.4
(00866B5E) C5073_0
harindrah@...
WinSCP 5.9.4
(00866B5E) C5073_0
(004065B8) Customdirview::_16537
(00406604) Customdirview::TCustomDirView::DoExecuteParentDirectory
(004068E0) Customdirview::TCustomDirView::KeyDown
(008671C9) C5073_0
philippe.verdret@...
Error changing directory to '/export/home/cft/Cft/tosend_qual' - _ssh_send_port_open
WinSCP 5.9.4
Error changing directory to '/export/home/cft/Cft/tosend_qual'.
(00866B5E) C5073_0
(0001
onthevalley@...
Не могу сменить каталог на 'templates' - _ssh_send_port_open
WinSCP 5.9.4
Не могу сменить каталог на 'templates'.
Трассировка стека:
(00866B5E) C5073_0
(00654A56) TUnixDirView::ExecuteFile
(0042CA3F) Dragdrop::TDragDrop::WndMethod
kmakukhin@...
Cannot open remote file '/Volumes/KProData/Users/kir/Documents/Matlab/ConvNets23/fish04/aFindFish2.m' - _ssh_send_port_open
I just tried to edit a remote file (sftp)
WinSCP 5.9.4
Cannot open remote file '/Volumes/KProData/Users/kir/Documents/Matlab/ConvNets23/fish04/aFindFish2.m'.
(00866B5E) C5073_0
(0007957A) COMCTL32.dll
(00079561) COMCTL32.dll
(0007939C) COMCTL32.dll
(000
yomifro@...
ディレクトリ 'css' への移動のエラー。 - _ssh_send_port_open
WinSCP 5.9.4
メモリのアクセス違反
スタック トレース:
(00866B5E) C5073_0
(0002C2B1) USER
r.sterna@...
Kann die entfernte Datei nicht öffnen - _ssh_send_port_open
WinSCP 5.9.3
Kann die entfernte Datei nicht öffnen.
(00866422) C5073_3
moar82@...
Error listing directory '/home/user/files/' - _ssh_send_port_open
If I suspend my windows 10 laptop and turn it on again I received this error. That did not happen in the previous version of WinSCP.
WinSCP 5.9.4
Error listing directory '/home/user/files/'.
(00866B5E) C5073_0
(006FB6BD) TSecureShell::Receive
(0073AF3F) TSFTPFileSystem::ReceivePacket
(0073C6A4) TSFTPFileSystem::ReceiveResponse
(0074C4E7) TSFTPFileSystem::ReadDirectory
(00778193) TTerminal::CustomReadDirectory
(00777721) TTerminal::ReadDirectory
(007752D9) TTerminal::DoEndTransaction
(007770D8) TTerminal::DoStartup
(0077042A) TTerminal::Open
(008671C9) C5073_0
(007781C2) TTerminal::CustomReadDirectory
Re: Error listing directory '/home/user/files/' - _ssh_send_port_open
kurt.ludikovsky@...
Error when changing directories following an IP-change - _ssh_send_port_open
Tried to change the directory for the first time after the IP-Adresses has been changed by the provider.
This did not happen before, just since a few days (Update in beetwen probably?!)
Background:
The Internetprovider is changing the IP-adress at least once a day. As my connections are sometimes open for long time, when an update of the selected directory is done this error happens.
I have not expereinced this error for 'normal' operaion.
This error did also not happen before.
WinSCP 5.9.4
Fehler beim Wechseln in Verzeichnis '/var/www/vhosts/biz-improver.at/httpdocs/typo3conf/ext'.
(00866B5E) C5073_0
schritter74@...
WinSCP 5.9.3
Трассировка стека:
(00866422) C5073_3
(00866A8D) C5073_3
(0073D149)
jzurowski2016@...
I left WinSCP idle for 20 minutes and disconnected from the server. I tried to refresh the current directory, but refresh was grayed out. Moving to a new directory causes this issue.
WinSCP 5.9.3
(0062AF9A)
(00866422)
(0086848A)
(00865244)
(0062B103)
(006FDC6E)
(006FC367)
(00738681)
(0073C63D)
(0073CC76)
(0073D3AE)
(0074B609)
(0077DEC6)
(0077433E)
(006563AF) @TUnixDirView@ChangeDirectory$qqr20System@UnicodeString
(00654AC6) @TUnixDirView@ExecuteRootDirectory$qqrv
(00038125)
(003B521C)
(0019C395)
(00373100)
(00866A8D)
(00868067)
(0073D149)
(0073D3AE)
(0074B609)
(0077DEC6)
(0077433E)
(00038125)
(003B521C)
(0019C395)
(00373100)
Re: Error when changing directories following an IP-change - _ssh_send_port_open
Background:
WinSCP 5.9.4
(00866B5E) C5073_0
rveloso@...
Não é possível abrir arquivo remoto '/rhevolution/migracao/ctl/EBT_funcionario_beneficios.ctl' - _ssh_send_port_open
WinSCP 5.9.4
Não é possível abrir arquivo remoto '/rhevolution/migracao/ctl/EBT_funcionario_beneficios.ctl'.
(00866B5E) C5073_0
(00045CC6) ntdll.dll.RtlRaiseStatus
(00045B52) ntdll.dll.KiUserExceptionDispatcher
(004068AD) Customdirview::TCustomDirView::KeyDown
irenerosen1@...
Error changing directory to '/mydisks' - _ssh_send_port_open
This happens when I change networks (WIFI<->wired). In the past, it just asked for my password again.
WinSCP 5.9.4
Error changing directory to '/mydisks'.
(00866B5E) C5073_0
(00013D90) USE
getluckybyme@...
Error changing directory to 'wp-content' - _ssh_send_port_open
WinSCP 5.9.3I
Please help us improving WinSCP by reporting the error on WinSCP support forum.
Error changing directory to 'wp-content'.
(00866422) C5073_3
(00866A8D) C5073_3
(0073D149)
overfiend4ever@...
WinSCP 5.9.4
(00866B5E) C5073_0
(008671C9) C5073_0
Re: Error changing directory to '/mydisks' - _ssh_send_port_open
WinSCP 5.9.4
(00866B5E) C5073_0
karosemena@...
WinSCP 5.9
(0086216E) C5073_3
(0077082E) TTerminal::SetCurrentDirectoryW
(006549A7) TUnixDirView::ChangeDirectory
(006530C2) TUnixDirView::ExecuteRootDirectory
(00037F81) TNonVisualDataModule::ExplorerActionsExecute
(003B4768) System::Actions::TContainedActionList::ExecuteAction
(0019B96D) Vcl::Actnlist::TCustomAction::Execute
(008627D9) C5073_3
(00863DB3) _ReThrowException
(00739BD9) TSFTPFileSystem::RealPath
(003B47
clauix11@...
Erro ao alterar o diretório para '/u01/opt/oracle/product/grid/bin' - _ssh_send_port_open
WinSCP 5.9.4
Erro ao alterar o diretório para '/u01/opt/oracle/product/grid/bin'.
(00866B5E) C5073_0
(00045416) ntdll.dll.RtlRaiseStatus
(000452A2) ntdll.dll.KiUserExceptionDispatcher
(0077EBAB) TTerminal::DoAnyCommand
(0077E89F) TTerminal::AnyCommand
(007A2A31) TConsoleDialog::DoExecuteCommand
(007A2B53) TConsoleDialog::ExecuteCommand
(007A280B) TConsoleDialog::ExecuteButtonClick
(001B73E0) Vcl::Stdctrls::TButtonControl::WndProc
(00209718) Vcl::Forms::TCustomForm::WndProc
(0080C348) Vclcommon::C2754_0
(000160EF) USER32.dll
(0001638C) USER32.dll
(0004527B) ntdll.dll.KiUserCallbackDispatcher
(00016690) USER32.dll.SendMessageW
(000A3E8F) COMCTL32.DLL
(000
jonas.hess@...
Fehler beim Wechseln in Verzeichnis 'page' - _ssh_send_port_open
WinSCP 5.9.4
Fehler beim Wechseln in Verzeichnis 'page'.
(00866B5E) C5073_0
(008671C9) C5073_0
(008687A
paulcarnie@...
Cannot open remote file '/home/n100577/MRVtools/ASC-configBackup/utility/.tmp' - _ssh_send_port_open
Copying a file from host to pc (where the existing file exists in target dir) - after error the original PC file is GONE... deleted !!
WinSCP 5.9.3
Cannot open remote file '/home/n100577/MRVtools/ASC-configBackup/utility/.tmp'.
(00866422) C5073_3
(00015DE3)%2
Goto page
