Invalid access to memory - _ssh_send_port_open
Goto page
Previous, 1, 2, 3, 4, 5, Next
ysu@...
Error changing directory to 'html' - _ssh_send_port_open
- Sync browsing on
- Changed directory up, then into another local dir that does not exists on the server
- error, do you want to create directory ? NO.
- sync browsing on again. copy lots of files
- change dir up again, back to the original directory
- error again - but this time it did not pop up, it was somewhere in the background
- alt-tab here and there, finally the error's up, select "NO" again
- oops - this problem appeared "invalid access to memory"
WinSCP 5.9.4
Error changing directory to 'html'.
Invalid access to memory.
(0062B1EA) _ssh_send_port_open
(00866B5E) C5073_0
(00868BC6) ____ExceptionHandler
(00865980) __ExceptionHandler
(000624F6) ntdll.dll
(0062B353) _get_ssh_exitcode
(006FDEBE) TSecureShell::CheckConnection
(006FC5B7) TSecureShell::Send
(007388D1) TSFTPFileSystem::SendPacket
(0073C88D) TSFTPFileSystem::SendPacketAndReceiveResponse
(0073CEC6) TSFTPFileSystem::RealPath
(0073D5FE) TSFTPFileSystem::RealPath
(0074B859) TSFTPFileSystem::ChangeDirectory
(0077E15A) TTerminal::ChangeDirectory
(00656623) TUnixDirView::ChangeDirectory
(00654A56) TUnixDirView::ExecuteFile
(004063C2) Customdirview::TCustomDirView::DoExecute
(004068AD) Customdirview::TCustomDirView::KeyDown
(008671C9) C5073_0
(008687A3) _ReThrowException
(0073D399) TSFTPFileSystem::RealPath
Re: Erro ao alterar o diretório para '/u01/opt/oracle/product/grid/bin' - _ssh_send_port_open
clauix11@... wrote:
WinSCP 5.9.4
Erro ao alterar o diretório para '/u01/opt/oracle/product/grid/bin'.
Acesso inválido à memória
Rastreamento de pilha:
(00866B5E) C5073_0
(00045416) ntdll.dll.RtlRaiseStatus
(000452A2) ntdll.dll.KiUserExceptionDispatcher
(000
xilaew@...
Fehler beim Wechseln in Verzeichnis '/opt/dlcs' - _ssh_send_port_open
I am using WINScp and usually do never Close it. Over night the Computer went into Hybernation mode. Yesterday I had two Putty sessions launched from WinScp. They had been inactive this morning, as usual. But in the WinScp window instead of simply reconnecting the last opened Session it Shows an error Message (find the shown Stack trace attached).
To fix this Problem it was not necessary to close WinScp. It was enough to just click on "new Session" and open another session. And now also the before broken Session was able to reconnect.
I understand that this is not fun to debug. It is really the first time that I see this error. And I am usually never Closing WinScp over night. Furthermore ist Impact is neglectable. If I see this error more often, I will offer more detailed Information.
WinSCP 5.9.4
Fehler beim Wechseln in Verzeichnis '/opt/dlcs'.
#0062B1EA# _ssh_send_port_open
#00866B5E# C5073_0
#00868BC6# ____ExceptionHandler
#00865980# __ExceptionHandler
#000624F6# ntdll.dll
#0000F13E# ntdll.dll.KiUserExceptionDispatcher
#0062B353# _get_ssh_exitcode
#006FDEBE# TSecureShell::CheckConnection
#006FC5B7# TSecureShell::Send
#007388D1# TSFTPFileSystem::SendPacket
#0073C88D# TSFTPFileSystem::SendPacketAndReceiveResponse
#0073CEC6# TSFTPFileSystem::RealPath
#0073D5FE# TSFTPFileSystem::RealPath
#0074B859# TSFTPFileSystem::ChangeDirectory
#0077E15A# TTerminal::ChangeDirectory
#00659A6A# TCustomUnixDriveView::Change
#00285F52# Vcl::Comctrls::TCustomTreeView::CNNotify
#0040CAA5# Customdriveview::TCustomDriveView::CNNotify
#0024F269# Vcl::Controls::TWinControl::WndProc
#0028620E# Vcl::Comctrls::TCustomTreeView::WndProc
#0024F3CF# Vcl::Controls::_17076
#0024E8B0# Vcl::Controls::TWinControl::MainWndProc
#0037322C# System::Classes::_18201
#000152F7# USER32.dll
#00015D35# USER32.dll
#00015DE3# USER32.dll
#00015E41# USER32.dll
#0000F117# ntdll.dll.KiUserCallbackDispatcher
#000186C0# USER32.dll.SendMessageW
#0002B06D# COMCTL32.DLL
#000A846F# COMCTL32.DLL
#000A77FB# COMCTL32.DLL
#0004B30B# COMCTL32.DLL
#0004B226# COMCTL32.DLL
#0001FD3A#%2
alexey.abraham@...
Executed SET GLOBAL sql_mode=(SELECT REPLACE(@@sql_mode,'ONLY_FULL_GROUP_BY',''));
via command line (forgot to enter mysql mode)
WinSCP 5.9.4
(00866B5E) C5073_0
(006FBDEC) TSecureShell::SendSpecial
(006FBE31) TSecureShell::SendEOF
(00736CF7) TSFTPFileSystem::Close
(006FDCD3) TSecureShell::Discard
(0064BC67) _sk_newlistener
(0061D422) C2447_0
(0061D636) _ssh_connshare_log
(0061DC60) _ssh_connshare_log
(00625114) _ssh_agent_forwarding_permitted
(006252A8) _ssh_sharing_logf
(00625313) _ssh_sharing_logf
(00625484) _ssh_sharing_logf
(00629E47) _sshfwd_x11_is_local
(0061D20E) C2447_0
(0061D3C1) C2447_0
(0061D6DC) _ssh_connshare_log
(0064C0F9) _select_result
(006FE8C7) TSecureShell::HandleNetworkEvents
(006FEB8A) TSecureShell::ProcessNetworkEvents
(006FE17B) TSecureShell::WaitForData
(006FB866) TSecureShell::Receive
(006FBAE4) TSecureShell::ReceiveLine
(006DB761) TSCPFileSystem::ReadCommandOutput
(006DBC98) TSCPFileSystem::ExecCommand
(006DBD47) TSCPFileSystem::ExecCommand
(006DF520) TSCPFileSystem::AnyCommand
(0077EB58) TTerminal::DoAnyCommand
(0077E89F) TTerminal::AnyCommand
(007A2A31) TConsoleDialog::DoExecuteCommand
(007A2B53) TConsoleDialog::ExecuteCommand
(007A280B) TConsoleDialog::ExecuteButtonClick
(0024F269) Vcl::Controls::TWinControl::WndProc
(001B73E0) Vcl::Stdctrls%
sibiryakov.ya@...
Ошибка доступа к памяти - _ssh_send_port_open
WinSCP 5.9.4
Ошибка доступа к памяти.
Трассировка стека:
(00866B5E) C5073_0
(0008147F) ntdll.dll
(0006F02A) ntdll.dll.KiUserExceptionDispatcher
(006FE9FF) TSecureShell::HandleNetworkEvents
(006F9585) TSecureShell::Init
(006F8E5A) TSecureShell::Open
(00736CEB) TSFTPFileSystem::Open
(00771BF7) TTerminal::Reopen
(006C8C4D) TTerminalThread::TerminalReopenEvent
(006C3C14) TSignalThread::Execute
(00098B63) Userinterface::C20_0
(000152C2) KERNEL32.DLL.BaseThreadInitThunk
(0005F717) ntdll.dll
(0005F6DF) ntdll.dll
(008671C9) C5073_0
(006F9693) TSecureShell::Init
Аутентификация не пройдена.
pavel@...
Error changing directory to 'aenigmas' - _ssh_send_port_open
I left WinSCP open and connected last night and just came back to it about 22 hours later. I brought that window back to the front, double-clicked on a folder, and got this.
WinSCP 5.9.4
Error changing directory to 'aenigmas'.
#00866B5E# C5073_0
#00081D3F# ntdll.dll
#0006F8EA# ntdll.dll.KiUserExceptionDispatcher
#00656623# TUnixDirView::ChangeDirectory
#00654A56# TUnixDirView::ExecuteFile
#004063C2# Customdirview::TCustomDirView::DoExecute
#00406F8F# Customdirview::TCustomDirView::WMLButtonDblClk
#00293197# Vcl::Comctrls::TCustomListView::WndProc
#0002C2B1# USER32.dll
#0000D885# USER32.dll
#0000CF12# USER32.dll.CallWindowProcW
#0007957A# COMCTL32.dll
#00079561# COMCTL32.dll
#0007939C# COMCTL32.dll
#0042CA3F# Dragdrop::TDragDrop::WndMethod
#0000D1DF# USER32.dll
#0000CF9B# USER32.dll.DispatchMessageW
#008671C9# C5073_0
#008687A3# _ReThrowException
#0073D399# TS
Re: Invalid access to memory - _ssh_send_port_open
WinSCP 5.9.4
(00866B5E) C5073_0
rebocano@...
No puedo abrir el archivo remoto «/home/admin/web/lab.prestashop.cl/public_html/lafete/themes/default-bootstrap/modules/homeslider/homeslider.tpl» - _ssh_send_port_open
WinSCP 5.9.1
No puedo abrir el archivo remoto «/home/admin/web/lab.prestashop.cl/public_html/lafete/themes/default-bootstrap/modules/homeslider/homeslider.tpl».
Acceso a memoria no válido
Traza de la pila:
(0062968A) _ssh_send_port_open
(00862736) C5073_3
(0086479E) ____ExceptionHandler
(00861558) __ExceptionHandler
(00081D3F) ntdll.dll
(006297F3) _get_ssh_exitcode
(006FADAA) TSecureShell::CheckConnection
(006F94A3) TSecureShell::Send
(0073550D) TSFTPFileSystem::SendPacket
(007394C9) TSFTPFileSystem::SendPacketAndReceiveResponse
(0075DAEE) TSFTPFileSystem::SFTPOpenRemoteFile
(007619F1) TSFTPFileSystem::SFTPSink
(0075FC1A) TSFTPFileSystem::SFTPSinkRobust
(0075FA0E) TSFTPFileSystem::CopyToLocal
(007846E1) TTerminal::CopyToLocal
(00011735) TCustomScpExplorerForm::TemporarilyDownloadFiles
(00012359) TCustomScpExplorerForm::ExecuteFile
(0001293E) TCustomScpExplorerForm::ExecuteFile
(000180ED) TCustomScpExplorerForm::DoDirViewExecFile
(00017FC2) TCustomScpExplorerForm::DirViewExecFile
(00408034) Customdirview::TCustomDirView::Execute
(00405A42) Customdirview::TCustomDirView::DoExecute
(0040660F) Customdirview::TCustomDirView::WMLButtonDblClk
(0024EA59) Vcl::Controls::TWinControl::WndProc
(00292987) Vcl::Comctrls::TCustomListView::WndProc
(00372990) System::Classes::_18201
(0002C2B1) USER32.dll
(0000D885) USER32.dll
(0000CF12) USER32.dll.CallWindowProcW
(0007957A) COMCTL32.DLL
(00079561) COMCTL32.DLL
s@...
Cannot open remote file '/tmp/wrapper_all.log' - _ssh_send_port_open
WinSCP 5.9.3
Cannot open remote file '/tmp/wrapper_all.log'.
(0062AF9A) _ssh_send_port_open
(00866422) C5073_3
(0086848A) ____ExceptionHandler
(00865244) __ExceptionHandler
(0062B103) _get_ssh_exitcode
(006FDC6E) TSecureShell::CheckConnection
(006FC367) TSecureShell::Send
(00738681) TSFTPFileSystem::SendPacket
(0073C63D) TSFTPFileSystem::SendPacketAndReceiveResponse
(00760F86) TSFTPFileSystem::SFTPOpenRemoteFile
(00764E89) TSFTPFileSystem::SFTPSink
(007630B2) TSFTPFileSystem::SFTPSinkRobust
(00762EA6) TSFTPFileSystem::CopyToLocal
(00787B79) TTerminal::CopyToLocal
(00011709) TCustomScpExplorerForm::TemporarilyDownloadFiles
(0001232D) TCustomScpExplorerForm::ExecuteFile
(00012912) TCustomScpExplorerForm::ExecuteFile
(0001811D) TCustomScpExplorerForm::DoDirViewExecFile
(00017FF2) TCustomScpExplorerForm::DirViewExecFile
(00408888) Customdirview::TCustomDirView::Execute
(00406296) Customdirview::TCustomDirView::DoExecute
(00406E63) Customdirview::TCustomDirView::WMLButtonDblClk
(0024F13D) Vcl::Controls::TWinControl::WndProc
(0029306B) Vcl::Comctrls::TCustomListView::WndProc
(00373100) System::Classes::_18201
(000152F7) USER32.dll
(00015D35) USER32.dll
(0001FD3A) USER32.dll
(0001FD60) USER32.dll.CallWindowProcW
(0042C913) Dragdrop::TDragDrop::WndMethod
(00015D35) USER
alex05161@...
Cannot create remote file '/spa/6.0/src/LITIG_rpt-dvlp/LitigRpt-functionality.txt' - _ssh_send_port_open
WinSCP 5.9.4
Cannot create remote file '/spa/6.0/src/LITIG_rpt-dvlp/LitigRpt-functionality.txt'.
#00866B5E# C5073_0
#007611D6# TSFTPFileSystem::SFTPOpenRemoteFile
#0076138C# TSFTPFileSystem::SFTPOpenRemote
#00773D61# TTerminal::FileOperationLoop
#0075CD4E# TSFTPFileSystem::SFTPSource
#0075B77C# TSFTPFileSystem::SFTPSourceRobust
#0075A90A# TSFTPFileSystem::CopyToRemote
#00787619# TTerminal::CopyToRemote
#0000DCB0# TCustomScpExplorerForm::ExecuteFileOperation
#0000EAB8# TCustomScpExplorerForm::ExecuteFileOperation
#0000EB3F# TCustomScpExplorerForm::ExecuteFileOperationCommand
#0000ECC6# TCustomScpExplorerForm::ExecuteCopyOperationCommand
#000374AE# TNonVisualDataModule::ExplorerActionsExecute
#003B5348# System::Actions::TContainedActionList::ExecuteAction
#0019C4C1# Vcl::Actnlist::TCustomAction::Execute
#000167BF# USER32.dll
#00016885# USER32.dll.DispatchMessageW
#008671C9# C5073_0
#007619ED# TSFTPFileSystem::SFTPOpenRemote
#00773D61# TTerminal::FileOperationLoop%
jan@...
Fehler beim Wechseln in Verzeichnis '/home/vl/web/valerielichtenstein.de' - _ssh_send_port_open
WinSCP 5.9.3
Fehler beim Wechseln in Verzeichnis '/home/vl/web/valerielichtenstein.de'.
(00866422) C5073_3
(0073CC76) TSFTPFileSystem::RealPath
(0073D3AE) TSFTPFileSystem::RealPath
(0074B609) TSFTPFileSystem::ChangeDirectory
(0077DEC6) TTerminal::ChangeDirectory
(0065981A) TCustomUnixDriveView::Change
(00285E26) Vcl::Comctrls::TCustomTreeView::CNNotify
(0040C979) Customdriveview::TCustomDriveView::CNNotify
(002860E2) Vcl::Comctrls::TCustomTreeView::WndProc
(0024F2A3) Vcl::Controls::_17076
(0024E784) Vcl::Controls::TWinControl::MainWndProc
(0000D4BB) USER32.dll
(00017B07) USER32.dll
(0006F8C4) ntdll.dll.KiUserCallbackDispatcher
(0000FBFB) USER32.dll.SendMessageW
(000638A8) COMCTL32.DLL
(0002279B) COMCTL32.DLL
(00022606) COMCTL32.DLL
(0001C69E) COMCTL32.DLL
(000212AE) COMCTL32.DLL
(0000D885) US
Re: No puedo abrir el archivo remoto «/home/admin/web/lab.prestashop.cl/public_html/lafete/themes/default-bootstrap/modules/homeslider/homeslider.tpl» - _ssh_send_port_open
rebocano@... wrote:
WinSCP 5.9.1
Traza de la pila:
(00862736) C5073_3
nmagretov@...
Не могу сменить каталог на '/etc/httpd/conf' - _ssh_send_port_open
WinSCP 5.9.4
Не могу сменить каталог на '/etc/httpd/conf'.
Трассировка стека:
(00866B5E) C5073_0
(0008519F) ntdll.dll
(000731B1) ntdll.dll.KiUserExceptionDispatcher
(00659A6A) TCustomUnixDriveView::Change
(00285F52) Vcl::Comctrls::TCustomTreeView::CNNotify
(0040CAA5) Customdriveview::TCustomDriveView::CNNotify
(0028620E) Vcl::Comctrls::TCustomTreeView::WndProc
(0024F3CF) Vcl::Controls::_17076
(0024E8B0) Vcl::Controls::TWinControl::MainWndProc
(0037322C) System::Classes::_18201
(00031B59) USER32.dll
(000240EE) USER32.dll
(00023D45) USER32.dll
(0002DC67) USER32.dll
(0007316B) ntdll.dll.KiUserCallbackDispatcher
(0000F90A) USER32.dll.SendMessageW
(000
nmagretov@...
Не могу сменить каталог на '/etc/sysconfig' - _ssh_send_port_open
WinSCP 5.9.4
Не могу сменить каталог на '/etc/sysconfig'.
Трассировка стека:
(00866B5E) C5073_0
(0006BB
catur@...
Error changing directory to '/' - _ssh_send_port_open
WinSCP 5.9.4
Error changing directory to '/'.
(00866B5E) C5073_0
(00045A86) ntdll.dll
(007745D2) TTerminal::SetCurrentDirectoryW
(006565FF) TUnixDirView::ChangeDirectory
(00654D16) TUnixDirView::ExecuteRootDirectory
(000381B5) TNonVisualDataModule::ExplorerActionsExecute
(003B5348) System::Actions::TContainedActionList::ExecuteAction
(0019C4C1) Vcl::Actnlist::TCustomAction::Execute
(000167BF) USER32.dll
(008671C9) C5073_0
(003B
richard_pugh@...
Error changing directory to '/home/e-smith/files/ibays/gih/html' - _ssh_send_port_open
WinSCP 5.9.4
Error changing directory to '/home/e-smith/files/ibays/gih/html'.
(00866B5E) C5073_0
(0008A61F) ntdll.dll
(000374F1) USER32.dll
(00015C3B) USER32.dll
(0001581B) USER32.dll
(0001C167) USER32.dll
(00077E54) ntdll.dll.KiUserCallbackDispatcher
(00014EDE) USER32.dll.SendMessageW
(0007DBE8) COMCTL32.DLL
(00034F23) COMCTL32.DLL
(00034D8A) COMCTL32.DLL
(00066AF2) COMCTL32.DLL
(00039351) COMCTL32.DLL
(000159D2) USER32.dll.CallWind
jackie.scibetta@...
Cannot open remote file '/home/progressivepro/public_html/app/design/frontend/tv_futurelife_package/sts_ts/template/persistent/customer/form/register.phtml' - _ssh_send_port_open
I left the client connected overnight. Upon returning, I cannot save files I have open from the day before, and I cannot open new files.
WinSCP 5.9.4
Cannot open remote file '/home/progressivepro/public_html/app/design/frontend/tv_futurelife_package/sts_ts/template/persistent/customer/form/register.phtml'.
(00866B5E) C5073_0
(007611D6) TSFTPFileSystem::SFTPOpenRemoteFile
(007650D9) TSFTPFileSystem::SFTPSink
(00763302) TSFTPFileSystem::SFTPSinkRobust
(007630F6) TSFTPFileSystem::CopyToLocal
(00787EBD) TTerminal::CopyToLocal
(00018156) TCustomScpExplorerForm::DoDirViewExecFile
(004089B4) Customdirview::TCustomDirView::Execute
(00406F8F) Customdirview::TCustomDirView::WMLButtonDblClk
(00293197) Vcl::Comctrls::TCustomListView::WndProc
(000159D2) USER32.dll.CallWindowProcW
(00098CBA) COMCTL32.DLL
(00098CA1) COMCTL32.DLL
(00098ADC
rcommandeur@...
By clicking the tab of an earlier opened session, which probably needed a reconnect, the problem occurred.
WinSCP 5.9.4
(00866B5E) C5073_0
(000128F2) KERNEL32.DLL.BaseThreadInitThunk
(00064DE1) ntdll.dll
(00064DA9) ntdll.dll
(008671C9) C5073_0
Authentication failed.
paul.blazek@...
Cannot open remote file '/MySQLData/InstallTables/RoxboroughCustomers2.csv' - _ssh_send_port_open
WinSCP 5.9.2
Cannot open remote file '/MySQLData/InstallTables/RoxboroughCustomers2.csv'.
#0062A1BA# _ssh_send_port_open
#00863846# C5073_3
#008658AE# ____ExceptionHandler
#00862668# __ExceptionHandler
#0062A323# _get_ssh_exitcode
#006FBBAE# TSecureShell::CheckConnection
#006FA2A7# TSecureShell::Send
#007364E1# TSFTPFileSystem::SendPacket
#0073A49D# TSFTPFileSystem::SendPacketAndReceiveResponse
#0075EAC2# TSFTPFileSystem::SFTPOpenRemoteFile
#007629C5# TSFTPFileSystem::SFTPSink
#00760BEE# TSFTPFileSystem::SFTPSinkRobust
#007609E2# TSFTPFileSystem::CopyToLocal
#007856B5# TTerminal::CopyToLocal
#0001156D# TCustomScpExplorerForm::TemporarilyDownloadFiles
#00012191# TCustomScpExplorerForm::ExecuteFile
#00012776# TCustomScpExplorerForm::ExecuteFile
HGrosz@...
Error changing directory to '/root/StationSystem/Release/PersistedData' - _ssh_send_port_open
Seems like I ran into the timeout, after which I have to log on to the server again. The server terminates sessions after a certain time without activity. WinSCP seems not to detect this, and tries to access the directory, rather than either logging in automatic or asking the user for credentials.
WinSCP 5.9.3
Error changing directory to '/root/StationSystem/Release/PersistedData'.
(00866422) C5073_3
arek.aksamit@...
Network issues triggered the event. Attempting to connect after network outage (behind VPN)
WinSCP 5.9.2
(0062A1BA) _ssh_send_port_open
(00863846) C5073_3
(008658AE) ____ExceptionHandler
(00862668) __ExceptionHandler
(0062A323) _get_ssh_exitcode
(006FC6EF) TSecureShell::HandleNetworkEvents
(006FC87A) TSecureShell::ProcessNetworkEvents
(006FBE6B) TSecureShell::WaitForData
(006F7275) TSecureShell::Init
(006F6B4A) TSecureShell::Open
(007348FB) TSFTPFileSystem::Open
(0076F49F) TTerminal::Reopen
(006C6A2D) TTerminalThread::TerminalReopenEvent
(006C19F4) TSignalThread::Execute
(000987A7) Userinterface::C20_0
(0005FFD7) ntdll.dll
(0005FF9F) ntdll.dll
(00863EB1) C5073_3
(0086548B) _ReThrowException
(006F7383) TSecureShell::Init
charles@...
I use WinSCP, work in another application for several minutes then return to WinSCP and it will often throw this error.
I'm connected using sFTP. The other application I am using also uses sFTP to connect to the same server and it works without error.
WinSCP 5.9.5
(0062B452) _ssh_send_port_open
(0086700E) C5073_3
(00869076) ____ExceptionHandler
(00865E30) __ExceptionHandler
(0062B5BB) _get_ssh_exitcode
(006FEFDF) TSecureShell::HandleNetworkEvents
(006FF16A) TSecureShell::ProcessNetworkEvents
(006FE75B) TSecureShell::WaitForData
(006F9B65) TSecureShell::Init
(006F943A) TSecureShell::Open
(007372CB) TSFTPFileSystem::Open
(007721D7) TTerminal::Reopen
(006C920D) TTerminalThread::TerminalReopenEvent
(006C41D4) TSignalThread::Execute
(00098BA3) Userinterface::C20_0
(00012368) kernel32.dll.BaseThreadInitThunk
(00038900) ntdll.dll
(000388D0) ntdll.dll
Using username "charles".
Re: Error changing directory to '/root/StationSystem/Release/PersistedData' - _ssh_send_port_open
WinSCP 5.9.3
(00866422) C5073_3
robert.ulrik@...
Error changing directory to '..' - _ssh_send_port_open
WinSCP 5.9.4
Error changing directory to '..'.
(0062B1EA)
(00866B5E)
(00868BC6)
(00865980)
(0062B353)
(006FDEBE)
(006FC5B7)
(007388D1)
(0073C88D)
(0073CEC6)
(0073D5FE)
(0074B859)
(0077E15A)
(00656623) @TUnixDirView@ChangeDirectory$qqr20System@UnicodeString
(00654ABA) @TUnixDirView@ExecuteParentDirectory$qqrv
(004089D4)
(004063C2)
(00406F8F)
(0024F269)
(00293197)
(0037322C)
(0007939C) COMCTL32.DLL
(0042CA3F)
(0037322C)
(0000D1DF) USER32.dll
(0000CF9B) USER32.dll.DispatchMessageW
(008671C9)
(008687A3)
(0073D399)
(0073D5FE)
(0074B859)
(0077E15A)
(004089D4)
(004063C2)
(00406F8F)
(0024F269)
(00293197)
(0037322C)
(0002C2B1%
baneeishaque@...
Error deleting file 'Songs/Records/Aftermath Entertainment/Beats By Dr. Dre/09 T.I. - This Is Detox (Feat. Kobe) (Prod. By Dr. Dre).mp3' - _ssh_send_port_open
WinSCP 5.9.4
Error deleting file 'Songs/Records/Aftermath Entertainment/Beats By Dr. Dre/09 T.I. - This Is Detox (Feat. Kobe) (Prod. By Dr. Dre).mp3'.
(00866B5E) C5073_0
(0074F874) TSFTPFileSystem::DoDeleteFile
(0074F9EA) TSFTPFileSystem::DeleteFileW
(00779EE7) TTerminal::DoDeleteFile
(00779DBE) TTerminal::DeleteFileW
(00778961) TTerminal::ProcessDirectory
(0074F987) TSFTPFileSystem::DeleteFileW
(00779251) TTerminal::ProcessFiles
(0077A060) TTerminal::DeleteFiles
(0001416B) TCustomScpExplorerForm::DeleteFiles
(0000E818) TC
nickodemos@...
WinSCP 5.9.4
(00866B5E) C5073_0
(00654ABA) TUnixDirView::ExecuteParentDirectory
(004089D4) Customdirview::TCustomDirView::Execute
(00019EB2) USER32.dll.CallWindowProcW
(00057059) COMCTL32.DLL
(0005712E) COMCTL32.DLL
(00056EDC) COMCTL32.DLL
(0042CA3F) Dragdrop::TDragDrop::WndMethod
(00023A7D) USER32.dll
(0002384B) USER32.dll.DispatchMessageW
(008671C9)%
aluserex@...
Fehler beim Wechseln in Verzeichnis '..' - _ssh_send_port_open
Yesterday I left my PC at work on and went home. WinSCP was still open. As I came to work today it was still open with an old session from yesterday. So I tried to doubleclick on '..' and the message popped up.
Haven't tried to reproduce it yet.
WinSCP 5.9.4
Fehler beim Wechseln in Verzeichnis '..'.
(00866B5E) C5073_0
(0005A60A) ntdll.dll
(0001FD22) USER32.dll
(008671C9) C5073_0
Re: Error changing directory to '..' - _ssh_send_port_open
gauravsingh.8026@...
Error changing directory to 'app' - _ssh_send_port_open
WinSCP 5.9.5
Error changing directory to 'app'.
(0086700E) C5073_3
(006FE49E) TSecureShell::CheckConnection
(006FCB97) TSecureShell::Send
(00738EB1) TSFTPFileSystem::SendPacket
(0073CE6D) TSFTPFileSystem::SendPacketAndReceiveResponse
(0073D4A6) TSFTPFileSystem::RealPath
(0073DBDE) TSFTPFileSystem::RealPath
(0074BE39) TSFTPFileSystem::ChangeDirectory
(0077E60A) TTerminal::ChangeDirectory
(00656B2F) TUnixDirView::ChangeDirectory
(00654F62) TUnixDirView::ExecuteFile
(00406402) Customdirview::TCustomDirView::DoExecute
(00406FCF) Customdirview::TCustomDirView::WMLButtonDblClk
(0024F2A9) Vcl::Controls::TWinControl::WndProc
(002931D7) Vcl::Comctrls::TCustomListView::WndProc
(0037326C) System::Classes::_18201
(0042CA7F) Dragdrop::TDragDrop::WndMethod
(00867679) C5073_3
(00868C53) _ReThrowException
(0073D979) TSFTPFi
rktaxali@...
WinSCP 5.9.4
(00866B5E) C5073_0
(008671C9) C5073_0
(003B
popovic@...
I keep WinSCP connection to my virtual box opened while I write code, compile etc. The session apparently times out (is there a keepalive?). When I try to copy my freshly compiled file, there is no indication that connection died so I try to copy...
I think either keepalive is missing or there should be a check every time app is returned to focus whether connection is still up.
Thank you!
WinSCP 5.9.4
(00866B5E) C5073_0
(0074F0E1) TSFTPFileSystem::SendCustomReadFile
(0074F452) TSFTPFileSystem::CustomReadFile
(0074EF34) TSFTPFileSystem::RemoteFileExists
(0075C228) TSFTPFileSystem::SFTPSource
(0075B77C) TSFTPFileSystem::SFTPSourceRobust
(0075A90A) TSFTPFileSystem::CopyToRemote
(00787619) TTerminal::CopyToRemote
(0000DCB0) TCustomScpExplorerForm::ExecuteFileOperation
(0000EAB8) TCustomScpExplorerForm::ExecuteFileOperation
(0000EB3F) TCustomScpExplorerForm::ExecuteFileOperationCommand
(0000ECC6) TCustomScpExplorerForm::ExecuteCopyOperationCommand
(00037307) TNonVisualDataModule::ExplorerActionsExecute
(008671C9) C5073_0
(0074EFA6) TSFTPFileSystem::RemoteFileExists
(0000EB3F) TCustomScpExplorerForm::ExecuteFileOperationCommand%
Thank you!
WinSCP 5.9.4
(00866B5E) C5073_0
moeti@...
WinSCP 5.9.5
(0086700E) C5073_3
(00654FC6) TUnixDirView::ExecuteParentDirectory
(000381AA) TNonVisualDataModule::ExplorerActionsExecute
(003B5388) System::Actions::TContainedActionList::ExecuteAction
(0019C501) Vcl::Actnlist::TCustomAction::Execute
(00867679) C5073_3
(0073D979) TSFTPFileSystem::RealPath
gerharddvs@...
This hapenned when logged on for a long time and tried to change folders on remote SSH
WinSCP 5.9.4
(0061D422) C2447_0
(0062A531) _sshfwd_x11_is_local
(006FDCAC) TSecureShell::FreeBackend
(006DA9FB) TSCPFileSystem::Close
(006C9FB3) TSecondaryTerminal::~TSecondaryTerminal
(0076E89B) TTerminal::~TTerminal
(0008A6EE) TManagedTerminal::~TManagedTerminal
(0008BB44) TTerminalManager::FreeTerminal
(0008B213) TTerminalManager::FreeActiveTerminal
gonzalo.martins@...
Erreur lors du changement de répertoire vers le répertoire 'home' - _ssh_send_port_open
WinSCP 5.9.3
Erreur lors du changement de répertoire vers le répertoire 'home'.
Accès mémoire invalide.
Trace de la pile :
(00866422) C5073_3
(00052DD6) ntdll.dll
(0073DC21) TSFTPFileSystem::GetHomeDirectory
(0074AABE) TSFTPFileSystem::HomeDirectory
(0077DB77) TTerminal::HomeDirectory
(0065633F) TUnixDirView::ChangeDirectory
(006549D8) TUnixDirView::ExecuteHomeDirectory
(00014F25) TCustomScpExplorerForm::HomeDirectory
(00046C12) TScpCommanderForm::HomeDirectory
(0003815C) TNonVisualDataModule::ExplorerActionsExecute
(003B521C) System::Actions::TContainedActionList::ExecuteAction
(0019C395) Vcl::Actnlist::TCustomAction::Execute
(000167CE) USER32.dll
(00866A8D) C5073_3
(00868067) _ReThrowException
(0073D149) TSFTPFileSystem::RealPath
marko.roomusoks@...
Error changing directory to '/home/marko.roomusoks/ringchain/bza' - _ssh_send_port_open
WinSCP 5.9.4
Error changing directory to '/home/marko.roomusoks/ringchain/bza'.
(00866B5E) C5073_0
(0077EBAB) TTerminal::DoAnyCommand
(008671C9) C5073_0
warren.martin@...
WinSCP 5.9.5
(0086700E) C5073_3
(00017742) KERNEL32.DLL.BaseThreadInitThunk
(0006487B) ntdll.dll.RtlGetAppContainerNamedObjectPath
(00064848) ntdll.dll.RtlGetAppContainerNamedObjectPath
(00867679) C5073_3
(006F9C73) TSecureShell::Init
Re: Error changing directory to '/home/marko.roomusoks/ringchain/bza' - _ssh_send_port_open
marko.roomusoks@... wrote:
WinSCP 5.9.4
(00866B5E) C5073_0
Adam.ZOVITS@...
I had 3 sessions to different servers open in a workspace, then at the end of the day sent the PC to sleep. The next day after waking the machine I saw that the last used and still open session had displayed its welcome message which I dismissed. Then the first error was displayed stating that the login attempt did not succeed and I can either abort or reconnect. After reconnecting the session was restored. Then I changed over to an other session, where the same error was shown (Network error: software caused connection abort) (this server has no welcome message). After clicking Reconnect the stack trace below was produced.
This is the first time this happened, so I wouldn't say I know how to reproduce it but I'll happily assist any debugging efforts if needed.
WinSCP 5.9
(0086216E)
(008641D6)
(00860F90)
(006296FF)
(006FAFEF)
(006FB17A)
(006FA76B)
(006F5B75)
(006F544A)
(0073352B)
(0076DE53)
(006C57B9)
(006C0780)
(0009836F)
(008627D9)
(00863DB3)
(006F5C83)
(006F544A)
(0073352B)
(0076DE53)
(006C57B9)
(006C0780)
(0009836F)
mike.buck@...
WinSCP 5.9.5
(0086700E) C5073_3
(00408A14) Customdirview::TCustomDirView::Execute
(00867679)%
zwieratko1@...
Nepodarilo sa zmeniť priečinok na domovský priečinok - _ssh_send_port_open
WinSCP 5.9.5
Nepodarilo sa zmeniť priečinok na domovský priečinok.
Neplatný prístup do pamäte.
Trasa hromadenia
(0086700E) C5073_3
(0074B2FC) TSFTPFileSystem::HomeDirectory
(0077E2BB) TTerminal::HomeDirectory
(00656A9B) TUnixDirView::ChangeDirectory
(00655134) TUnixDirView::ExecuteHomeDirectory
(00046CE2) TScpCommanderForm::HomeDirectory
(0003822C) TNonVisualDataModule::ExplorerActionsExecute
(00867679) C5073_3
(00656A9B) TUn
temichaels@...
Cannot create remote file '/home1/loccs/test/mapper/index.cfm' - _ssh_send_port_open
Clicked on the local file I wanted to copy, clicked F5 to copy to remote - this time received error.
Steps I have done routinely for months with no trouble. I did happen to Duplicate some files from the parent directory into the target directory earlier in the session - not sure if that is relevant but is one of the few actions I do not perform regularly.
WinSCP 5.9.5
Cannot create remote file '/home1/loccs/test/mapper/index.cfm'.
(0086700E) C5073_3
(007617B6) TSFTPFileSystem::SFTPOpenRemoteFile
(0076196C) TSFTPFileSystem::SFTPOpenRemote
(00774341) TTerminal::FileOperationLoop
(0075D32E) TSFTPFileSystem::SFTPSource
(0075BD5C) TSFTPFileSystem::SFTPSourceRobust
(0075AEEA) TSFTPFileSystem::CopyToRemote
(00787AC9) TTerminal::CopyToRemote
(00037347) TNonVisualDataModule::ExplorerActionsExecute
(00867679) C5073_3
(00761FCD) TSFTPFileSystem::SFTPOpenRemote
test@...
Не могу сменить каталог на 'vendor' - _ssh_send_port_open
WinSCP 5.9.4
Не могу сменить каталог на 'vendor'.
Трассировка стека:
(00866B5E) C5073_0
(0
oelmas@...
Error changing directory to '/home/cmaquser1' - _ssh_send_port_open
WinSCP 5.9.5
Error changing directory to '/home/cmaquser1'.
(0086700E) C5073_3
(0077F05B) TTerminal::DoAnyCommand
(0077ED4F) TTerminal::AnyCommand
(007A2EE1) TConsoleDialog::DoExecuteCommand
(007A3003) TConsoleDialog::ExecuteCommand
(007A2CBB) TConsoleDialog::ExecuteButtonClick
(00867679) C5073_3
novation02@...
Error changing directory to 'admin' - _ssh_send_port_open
WinSCP 5.9.4
Error changing directory to 'admin'.
(00866B5E) C5073_0
(008671C9) C5073_0
(0073D399) TSFTP
bestponymilo@...
WinSCP 5.9.5
(0086700E) C5073_3
(00867679) C5073_3
iomedvedev@...
happened after execute command: sudo apt-get install curl libcurl3 libcurl3-dev php5-curl
Amazon server - Apache/2.4.7 (Ubuntu)
WinSCP 5.9.5
(0086700E) C5073_3
(006FC3CC) TSecureShell::SendSpecial
(006FC411) TSecureShell::SendEOF
(007372D7) TSFTPFileSystem::Close
(006FE2B3) TSecureShell::Discard
(0064C0CB) _sk_newlistener
(0061D5BA) C2447_0
(0062A789) _sshfwd_x11_is_local
(006FE28C) TSecureShell::FreeBackend
(006DAFCB) TSCPFileSystem::Close
(006FD9B6) TSecureShell::FatalError
(006FE897) TSecureShell::WaitForData
(006FBE46) TSecureShell::Receive
(006FC0C4) TSecureShell::ReceiveLine
(006DBD31) TSCPFileSystem::ReadCommandOutput
(006DC268) TSCPFileSystem::ExecCommand
(006DC317) TSCPFileSystem::ExecCommand
(006DFAF0) TSCPFileSystem::AnyCommand
(0077F008) TTerminal::DoAnyCommand
(001B7420) Vcl::Stdctrls::TButtonControl::WndProc
(0024F40F) Vcl::Controls::_17076
(00209758) Vcl::Forms::TCustomForm::WndProc
(0080C7F8) Vclcommon::C2754_0
(0024E8F0) Vcl::Controls::TWinControl::MainWndProc
(0037326C) System::Classes:%
james.henderson@...
WinSCP 5.9.2
(00863846) C5073_3
(006FBBAE) TSecureShell::CheckConnection
(006F9ADC) TSecureShell::SendSpecial
(006F9B21) TSecureShell::SendEOF
(00734907) TSFTPFileSystem::Close
(006FB9C3) TSecureShell::Discard
(0064AC37) _sk_newlistener
(0061C3F2) C2447_0
(00629501) _sshfwd_x11_is_local
(006FB99C) TSecureShell::FreeBackend
(006D86EB) TSCPFileSystem::Close
(006FB0C6) TSecureShell::FatalError
(006FBFA7) TSecureShell::WaitForData
(006F9556) TSecureShell::Receive
(006F97D4) TSecureShell::ReceiveLine
(006D9451) TSCPFileSystem::ReadCommandOutput
(006D9988) TSCPFileSystem::ExecCommand
(006D9A37) TSCPFileSystem::ExecCommand
(006DD210) TSCPFileSystem::AnyCommand
(0077C39C) TTerminal::DoAnyCommand
(0077C0E3) TTerminal::AnyCommand
(007A0229) TConsoleDialog::DoExecuteCommand
(007A034B) TConsoleDialog::ExecuteCommand
(007A0003) TConsoleDialog::ExecuteButtonClick
(0024EC29) Vcl::Controls::TWinControl::WndProc
(001B6DA0) Vcl::Stdctrls::TButtonControl::WndProc
(0024ED8F) Vcl::Controls::_17076
(002090D8) Vcl::Forms::TCustomForm::WndProc
(008094EC) Vclcommon::C2754_0
(0024E270) Vcl::Controls::TWinControl::MainWndProc
(00372BEC) System::Classes:%
slyguy2000@...
WinSCP 5.9.5
(0086700E) C5073_3
(00867679) C5073_3
ge
Error changing directory to '/var/www/purchase/app/Resources' - _ssh_send_port_open
WinSCP 5.9.5
Error changing directory to '/var/www/purchase/app/Resources'.
(0086700E) C5073_3
(0065A02A) TCustomUnixDriveView::Change
(00285F92) Vcl::Comctrls::TCustomTreeView::CNNotify
(0040CAE5) Customdriveview::TCustomDriveView::CNNotify
(0028624E) Vcl::Comctrls::TCustomTreeView::WndProc
joxmiguel@...
Acceso a memoria no válido - _ssh_send_port_open
WinSCP 5.9.5
Traza de la pila:
(0061D5BA) C2447_0
(006CA573) TSecondaryTerminal::~TSecondaryTerminal
(0076EE7B) TTerminal::~TTerminal
(0008A72E) TManagedTerminal::~TManagedTerminal
(0008BB84) TTerminalManager::FreeTerminal
(0008B253) TTerminalManager::FreeActiveTerminal
james.henderson@... wrote:
WinSCP 5.9.2
(00863846) C5073_3
ucupkeling26@...
WinSCP 5.9
(00629596) _ssh_send_port_open
(0086216E) C5073_3
(008641D6) ____ExceptionHandler
(00860F90) __ExceptionHandler
(006296FF) _get_ssh_exitcode
(006FA4AE) TSecureShell::CheckConnection
(006F8BA7) TSecureShell::Send
(00735111) TSFTPFileSystem::SendPacket
(007390CD) TSFTPFileSystem::SendPacketAndReceiveResponse
(00739706) TSFTPFileSystem::RealPath
(00739E3E) TSFTPFileSystem::RealPath
(00748099) TSFTPFileSystem::ChangeDirectory
(0077A3B6) TTerminal::ChangeDirectory
(006549CB) TUnixDirView::ChangeDirectory
(00652E66) TUnixDirView::ExecuteParentDirectory
(00037F36) TNonVisualDataModule::ExplorerActionsExecute
(003B4768) System::Actions::TContainedActionList::ExecuteAction
(0019B96D) Vcl::Actnlist::TCustomAction::Execute
(0037264C) System::Classes::_18201
(008627D9) C5073_3
(00863DB3) _ReThrowException
(00739BD9) TSFTPFileSystem::RealPath
(0019B96D) Vcl::Actnlist%
info@...
Fehler beim Wechseln in Verzeichnis '/hp/bt/ac/dx/www/_bdg/_gae_48772' - _ssh_send_port_open
It happens when clicking onto a folder after Windows 10 coming up again after sleep.
WinSCP 5.9.5
Fehler beim Wechseln in Verzeichnis '/hp/bt/ac/dx/www/_bdg/_gae_48772'.
(0086700E) C5073_3
(000638A8) COMCTL32.dll
(0002279B) COMCTL32.dll
(00022606) COMCTL32.dll
(0001C69E) COMCTL32.dll
(000212AE) COMCTL32.dll
(0000D885)%2
php.essitco1@...
Cannot open remote file '/var/www/vastedge/launchpad/loan/loanproApi/composer/vendor/simnang/loanpro-sdk/src/LoanPro.php' - _ssh_send_port_open
WinSCP 5.9.5
Cannot open remote file '/var/www/vastedge/launchpad/loan/loanproApi/composer/vendor/simnang/loanpro-sdk/src/LoanPro.php'.
(0086700E) C5073_3
(000455C6) ntdll.dll.RtlRaiseStatus
(00045452) ntdll.dll.KiUserExceptionDispatcher
(007656B9) TSFTPFileSystem::SFTPSink
(007638E2) TSFTPFileSystem::SFTPSinkRobust
(007636D6) TSFTPFileSystem::CopyToLocal
(0078836D) TTerminal::CopyToLocal
(004089F4) Customdirview::TCustomDirView::Execute
(000176EC) USER32.dll
(00017871) USER32.dll
(000133CA) USER32.dll
(000133F0) USER32.dll.CallWindowProcW
(003732
mikael@...
Error changing directory to '/var/www/clients/client1/web1/web/name_of_direct' - _ssh_send_port_open
I opened a session and left the computer for a few hours. When i came back and was going to change directory i got this error message. I got it from both the directory tree and the file list. I tried changing to many different directories and always got the error. When i rightclicked the active sessions tab and chose duplicate session so that the new sessions tab got active and then changed back to the old session tab it was working as it should again.
This was first time i got this error as far as i can remember.
WinSCP 5.9.4
Error changing directory to '/var/www/clients/client1/web1/web/name_of_direct'.
(00866B5E) C5073_0
(0000CF12) U
kz@...
WinSCP 5.9.4
Трассировка стека:
(00866B5E) C5073_0
(008671C9) C5073_0
rene.clevers@...
Evertime after timeout / connection loss:
WinSCP 5.9.5
(0086700E) C5073_3
(00867679) C5073_3
Re: Fehler beim Wechseln in Verzeichnis '..' - _ssh_send_port_open
allabtweb@...
Error changing directory to '/etc/varnish' - _ssh_send_port_open
WinSCP 5.9.4
Error changing directory to '/etc/varnish'.
(00866B5E) C5073_0
(0024F37A)
jjstiff@...
I clicked up a directory but the process may have been disconnected from the network because I just rewoke my computer.
WinSCP 5.9.5
(0086700E) C5073_3
(00098ADC) COMCTL32.DLL
(0001553C) USER32.dll
(000152FB) USER32.dll.DispatchMessageW
(00867679)%
postmaster@...
WinSCP 5.9.5
#0062B452# _ssh_send_port_open
#0086700E# C5073_3
#00869076# ____ExceptionHandler
#00865E30# __ExceptionHandler
#0062B5BB# _get_ssh_exitcode
#006FE49E# TSecureShell::CheckConnection
#006FCB97# TSecureShell::Send
#00738EB1# TSFTPFileSystem::SendPacket
#0073CE6D# TSFTPFileSystem::SendPacketAndReceiveResponse
#0073D4A6# TSFTPFileSystem::RealPath
#0073DBDE# TSFTPFileSystem::RealPath
#0074BE39# TSFTPFileSystem::ChangeDirectory
#0077E60A# TTerminal::ChangeDirectory
#00774A82# TTerminal::SetCurrentDirectoryW
#00656B0B# TUnixDirView::ChangeDirectory
#00655222# TUnixDirView::ExecuteRootDirectory
#000381F5# TNonVisualDataModule::ExplorerActionsExecute
#003B5388# System::Actions::TContainedActionList::ExecuteAction
#0019C501# Vcl::Actnlist::TCustomAction::Execute
#0037326C# System::Classes::_18201
#00867679# C5073_3
#00868C53# _ReThrowException
#0073D979# TSFTPFileSystem::RealPath
(003B
jason.m.oliver@...
WinSCP 5.9.5
(0086700E) C5073_3
(00867679) C5073_3
Re: Error changing directory to '/' - _ssh_send_port_open
postmaster@... wrote:
WinSCP 5.9.5
#0086700E# C5073_3
#000381F5# TNonVisualDataModule::ExplorerActions Execute
#00867679# C5073_3
(003B
leo.fedder@...
Error creating folder 'New folder' - _ssh_send_port_open
I suspect it occurred after a network glitch - have not been able to reproduce it.
WinSCP 5.9.4
Error creating folder 'New folder'.
(00866B5E) C5073_0
(0073D8F1) TSFTPFileSystem::Canonify
(00750B71) TSFTPFileSystem::CreateDirectoryW
(0077D835) TTerminal::DoCreateDirectory
(0077D696) TTerminal::CreateDirectoryW
(006568E3) TUnixDirView::CreateDirectoryExW
(00014D9F) TCustomScpExplorerForm::CreateDirectoryW
(000378AD) TNonVisualDataModule::ExplorerActionsExecute
(008671C9) C5073_0
lqhminei@...
Error changing directory to home directory - _ssh_send_port_open
using wget to remotely move files
some of the log
2017-06-09 02:03:27.639 There are 0 bytes remaining in the send buffer
. 2017-06-09 02:03:27.639 Read file 'public_html' from listing
. 2017-06-09 02:03:27.641 Read file '.' from listing
. 2017-06-09 02:03:27.641 Read file '.well-known' from listing
. 2017-06-09 02:03:27.641 Read file 'cgi-bin' from listing
. 2017-06-09 02:03:27.641 Read file 'dashsignature.com' from listing
. 2017-06-09 02:03:27.641 Read file '..' from listing
. 2017-06-09 02:03:27.641 Read file 'mp3' from listing
. 2017-06-09 02:03:27.641 Read file 'nusofting' from listing
. 2017-06-09 02:03:27.641 Waiting for another 4 bytes
. 2017-06-09 02:03:27.833 Detected network event
. 2017-06-09 02:03:27.833 Received 32 bytes (0)
. 2017-06-09 02:03:27.833 Read 4 bytes (28 pending)
. 2017-06-09 02:03:27.833 Read 28 bytes (0 pending)
< 2017-06-09 02:03:27.833 Type: SSH_FXP_STATUS, Size: 28, Number: 1036
< 2017-06-09 02:03:27.834 Status code: 1
> 2017-06-09 02:03:27.834 Type: SSH_FXP_CLOSE, Size: 13, Number: 1284
. 2017-06-09 02:03:27.834 Sent 17 bytes
. 2017-06-09 02:03:27.834 There are 0 bytes remaining in the send buffer
. 2017-06-09 02:03:27.834 public_html;d;0;2017-06-08T22:57:25.000Z;3;"liqihsyn" [964];"liqihsyn" [964];rwxrwxr-x;0
. 2017-06-09 02:03:27.834 .well-known;d;0;2017-06-08T18:39:40.000Z;3;"liqihsyn" [964];"liqihsyn" [964];rwxr-xr-x;2
. 2017-06-09 02:03:27.834 cgi-bin;d;0;2017-06-08T18:38:16.000Z;3;"liqihsyn" [964];"liqihsyn" [964];rwxr-xr-x;0
. 2017-06-09 02:03:27.834 dashsignature.com;d;0;2017-06-08T22:54:38.000Z;3;"liqihsyn" [964];"liqihsyn" [964];rwxrwxr-x;0
. 2017-06-09 02:03:27.834 ..;d;0;2017-06-08T18:38:56.000Z;3;"liqihsyn" [964];"liqihsyn" [964];rwx--x--x;0
. 2017-06-09 02:03:27.834 mp3;d;0;2017-06-08T22:03:42.000Z;3;"liqihsyn" [964];"liqihsyn" [964];rwxrwxr-x;0
. 2017-06-09 02:03:27.834 nusofting;d;0;2017-06-08T21:45:55.000Z;3;"liqihsyn" [964];"liqihsyn" [964];rwxrwxr-x;0
. 2017-06-09 02:03:27.834 Session upkeep
. 2017-06-09 02:03:27.902 Startup conversation with host finished.
. 2017-06-09 02:03:28.256 Session upkeep
. 2017-06-09 02:03:28.256 Detected network event
. 2017-06-09 02:03:28.256 Received 28 bytes (0)
. 2017-06-09 02:03:28.764 Session upkeep
. 2017-06-09 02:03:29.266 Session upkeep
. 2017-06-09 02:03:29.766 Session upkeep
. 2017-06-09 02:03:30.267 Session upkeep
. 2017-06-09 02:03:30.753 Session upkeep
. 2017-06-09 02:03:31.253 Session upkeep
WinSCP 5.9.5
Error changing directory to home directory.
(0086700E) C5073_3
(0073E451) TSFTPFileSystem::GetHomeDirectory
(0074B2EE) TSFTPFileSystem::HomeDirectory
(00867679) C5073_3
Re: Error changing directory to home directory - _ssh_send_port_open
sergey.shandra@...
WinSCP 5.9.5
Трассировка стека:
(0086700E) C5073_3
(00867679) C5073_3
rob@...
Server I was connected to had rebooted, winscp didn't detect the loss of connection. I got the error when I clicked to change directory. I don't know if it happens a lot as the server I was connected to, doesn't go down a lot.
WinSCP 5.9.5
(0086700E) C5073_3
(00867679)%
Adam.ZOVITS@...
The error occurred after a remote site was opened in WinSCP, the PC was hibernated and restored from hibernation (with a weekend between these two events), then a directory change was attempted.
WinSCP 5.9
(0086216E)
(008641D6)
(00860F90)
(006296FF)
(006FA4AE)
(006F8BA7)
(00735111)
(007390CD)
(00739706)
(00739E3E)
(00748099)
(0077A3B6)
(006549CB) @TUnixDirView@ChangeDirectory$qqr20System@UnicodeString
(00652E66) @TUnixDirView@ExecuteParentDirectory$qqrv
(00407ECC)
(004058C2)
(0040648F)
(0024E715)
(00292643)
(0037264C)
(0042BD7F)
(0037264C)
(008627D9)
(00863DB3)
(00739BD9)
(00739E3E)
(00748099)
(0077A3B6)
(00407ECC)
(004058C2)
(0040648F)
(0024E715)
(00292643)
(0037264C)
(0042BD7F)
(0037264C)
maxim@...
Tried to change directory. Session was open overnight.
WinSCP 5.9.5
(0086700E) C5073_3
(00867679) C5073_3
jason_m_oliver@...
I clicked on the application to bring it to focus. then it tossed error. It should have prompted for a reconnect. As my prior session would have been expired at the time of the window being brought back to focus.
WinSCP 5.9.5
#0086700E# C5073_3
#00656B2F# TUnixDirView::ChangeDirectory
#00654FC6# TUnixDirView::ExecuteParentDirectory
#00408A14# Customdirview::TCustomDirView::Execute
#00406402# Customdirview::TCustomDirView::DoExecute
#00406FCF# Customdirview::TCustomDirView::WMLButtonDblClk
#0024F2A9# Vcl::Controls::TWinControl::WndProc
#002931D7# Vcl::Comctrls::TCustomListView::WndProc
#0007957A# COMCTL32.DLL
#00079561# COMCTL32.DLL
#0007939C# COMCTL32.DLL
#0042CA7F# Dragdrop::TDragDrop::WndMethod
#00867679#%
tommro24@...
Błąd podczas przejścia do katalogu '..' - _ssh_send_port_open
WinSCP 5.9.5
Błąd podczas przejścia do katalogu '..'.
Naruszenie ochrony pamęci.
(0086700E) C5073_3
(004065F8) Customdirview::_16537
(00406644) Customdirview::TCustomDirView::DoExecuteParentDirectory
(00406920) Customdirview::TCustomDirView::KeyDown
(00867679) C5073_3
samuelfac@...
Erro ao alterar o diretório para '..' - _ssh_send_port_open
WinSCP 5.9.5
Erro ao alterar o diretório para '..'.
(0086700E) C5073_3
Adam.ZOVITS@...
A connection was opened to a host, then the PC was put to sleep. After waking up the connection was declared lost and the error occurred during reconnection.
WinSCP 5.9
(0086216E)
(008641D6)
(00860F90)
(006296FF)
(006FAFEF)
(006FB17A)
(006FA76B)
(006F5B75)
(006F544A)
(0073352B)
(0076DE53)
(006C57B9)
(006C0780)
(0009836F)
Using username "apadmin".
meritokrasi@...
'/var/www/vhosts/system/blablabla/logs' klasörüne geçilirken hata - _ssh_send_port_open
WinSCP 5.9.6
Belleğe hatalı erişim.
Yığın izleme:
(0062C826) _ssh_send_port_open
(008689AA) C5077_0
(0086AA12) ____ExceptionHandler
(008677CC) __ExceptionHandler
(0062C98F) _get_ssh_exitcode
(006FFB4E) TSecureShell::CheckConnection
(006FE247) TSecureShell::Send
(0073A561) TSFTPFileSystem::SendPacket
(0073E51D) TSFTPFileSystem::SendPacketAndReceiveResponse
(0073EB56) TSFTPFileSystem::RealPath
(0073F28E) TSFTPFileSystem::RealPath
(0074D4E9) TSFTPFileSystem::ChangeDirectory
(0077FCBA) TTerminal::ChangeDirectory
(0065B6CE) TCustomUnixDriveView::Change
(0028628A) Vcl::Comctrls::TCustomTreeView::CNNotify
(0040CDDD) Customdriveview::TCustomDriveView::CNNotify
(0024F5A1) Vcl::Controls::TWinControl::WndProc
(00286546) Vcl::Comctrls::TCustomTreeView::WndProc
(0024F707) Vcl::Controls::_17076
(0024EBE8) Vcl::Controls::TWinControl::MainWndProc
(00373564) System::Classes::_18201
(0006BBA6) COMCTL32.DLL
(0002A0AA) COMCTL32.DLL
(00029F7E) COMCTL32.DLL
(0004960D) COMCTL32.DLL
(00026169) COMCTL32.DLL
57049825@...
无效的内存访问。 - _ssh_send_port_open
WinSCP 5.9.5
无效的内存访问。
(0086700E) C5073_3
(00867679) C5073_3
验证失败。
martin_diehl@...
Changing directory on the server side, maybe one accident extra click.
WinSCP 5.9.5
(0086700E) C5073_3
(00867679)%
Re: 无效的内存访问。 - _ssh_send_port_open
57049825@... wrote:
WinSCP 5.9.5
无效的内存访问。
(0086700E) C5073_3
验证失败。
Re: '/var/www/vhosts/system/blablabla/logs' klasörüne geçilirken hata - _ssh_send_port_open
meritokrasi@... wrote:
WinSCP 5.9.6
Yığın izleme:
(008689AA) C5077_0
info@...
WinSCP 5.9.5
(0086700E) C5073_3
(0002384B) U
sumitauthankar@...
Cannot open remote file '/home/samsung/Email_Add/TestHarness/TestHarness/static/scripts/email_list.js' - _ssh_send_port_open
WinSCP 5.9.5
Cannot open remote file '/home/samsung/Email_Add/TestHarness/TestHarness/static/scripts/email_list.js'.
(0086700E) C5073_3
it.thaian2009@...
Error changing directory to '/var/www/html' - _ssh_send_port_open
WinSCP 5.9.6
Error changing directory to '/var/www/html'.
(008689AA) C5077_0
(0078070B) TTerminal::DoAnyCommand
(007803FF) TTerminal::AnyCommand
(007A4595) TConsoleDialog::DoExecuteCommand
(007A46B7) TConsoleDialog::ExecuteCommand
(007A436F) TConsoleDialog::ExecuteButtonClick
(00869015) C5077_0
(0086A5EF) _ReThrowException
(0073F029) TSFTPFileSystem::RealPath
hriziya@...
Cannot create remote file '/var/www/html/sandbox/web_services/pdf_estimate_internal.php' - _ssh_send_port_open
I have checked the checkbox for "Do not show the transfer box confirmation" and it causes the server disconnected. I had to reconnect to complete the file transfer. hope that helps..
WinSCP 5.9.5
Cannot create remote file '/var/www/html/sandbox/web_services/pdf_estimate_internal.php'.
(0086700E) C5073_3
(0005A466) ntdll.dll
(00867679) C5073_3
(00787AC9) TTe
Re: Cannot open remote file '/home/samsung/Email_Add/TestHarness/TestHarness/static/scripts/email_list.js' - _ssh_send_port_open
sumitauthankar@... wrote:
WinSCP 5.9.5
(0086700E) C5073_3
fmt@...
Error changing directory to 'test' - _ssh_send_port_open
WinSCP 5.9.5
Error changing directory to 'test'.
(0086700E) C5073_3
(00867679) C5073_3
kiranraichamling@...
WinSCP 5.9.6
(006FDA7C) TSecureShell::SendSpecial
(006FDAC1) TSecureShell::SendEOF
(00738987) TSFTPFileSystem::Close
(006FF963) TSecureShell::Discard
(0064D737) _sk_newlistener
(0061E98E) C2449_0
(0062BB5D) _sshfwd_x11_is_local
(006FF93C) TSecureShell::FreeBackend
(006DC66F) TSCPFileSystem::Close
(006CBC17) TSecondaryTerminal::~TSecondaryTerminal
(0077052B) TTerminal::~TTerminal
(0008AA26) TManagedTerminal::~TManagedTerminal
(0008BE7C) TTerminalManager::FreeTerminal
(0008B54B) TTerminalManager::FreeActiveTerminal
(003B5680) System::Actions::TContainedActionList::ExecuteAction
(0019C7F9) Vcl::Actnlist::TCustomAction::Execute
Re: Error changing directory to 'test' - _ssh_send_port_open
fmt@... wrote:
WinSCP 5.9.5
(0086700E) C5073_3
bug-report@...
Cannot open remote file '/home/username/example.net/_main_/www/index.php' - _ssh_send_port_open
WinSCP has many issues related to losing connection to the server, reconnecting & trying to continue using WinSCP as if nothing happened. The bottom line is that if you are using WinSCP & the connection to the server disconnects, for any reason, it's best to close WinSCP completely (even if reconnecting was successful {which it normally is}), otherwise you WILL encounter some version of "Invalid access to memory", at some point when you try to do something. I think I will actually try to start reporting all "Invalid access to memory" errors, so I can help you find & fix them. I've encountered various "Invalid access to memory" issues over the years...& I've seen many of them reported in this "Automatic Bug Reports" forum, so I would've thought they would've been found & fixed by now.
<If relevant, consider attaching a session log file or a screenshot)> -- sorry, no session log, cuz logging wasn't active when this happened, but I can try to do it again (it should be easy) & get you a log
Steps to Reproduce...
    1. Run WinSCP
    2. Connect to a server (SSH/SFTP, if that matters)
    3. Double click a remote file to open it in an Editor (mine opens in Notepad2-mod, but I don't think which Editor matters)
    4. Make a change & Save the file (maybe not necessary, but just for example)
    5. Disconnect your Internet (do something to lose connection to the server {like unplug your network cable or disconnect from WiFi [or just wait for your ISP to flake out]})
    6. Wait for WinSCP to notice the disconnection & it will try to reconnect (or poke around {click Refresh in the Remote file list} & help it notice)...it might also stop trying to reconnect & say something like "Host doesn't exist"
    7. Reconnect your Internet (reconnect your network cable or reconnect to WiFi)
    8. In WinSCP click Reconnect
    9. In WinSCP, double click to open a 2nd Notepad of the same file you were editing before the reconnect (leave the original Notepad open)
    10. In the 2nd copy of Notepad, make a change & save the file
    11. WinSCP will say something about it can't save the file cuz the connection was already closed (sorry, I don't have the exact error msg at the moment)
    12. In the 2nd copy of Notepad, make another change & save the file again
    13. WinSCP will say it's not able to save (again)
    14. Close the 2nd Notepad
    15. Focus the 1st Notepad, make a change & save
Actual Results...
    This is when I got the "Invalid access to memory." error with the Stack trace. I guess when WinSCP reconnects, it doesn't re-associate already-open files with the newly-reconnected session?
    I would fix this 2 ways...
    1. When a session disconnects, I would flag any open files as being associated with a disconnected session, so if any of them are saved/updated, I would display a msg telling the user that, telling them to reconnect to the same server to be able to upload the changes. Also, if WinSCP is closed, I would flag any changed-but-not-uploaded files to NOT BE DELETED...I would save info about which connection they are related to, so they can be uploaded when a connection to the same server is made.
    2. When the same session is reconnected, I would re-associate any still-opened files with the newly-reconnected session. This should avoid the "Invalid access to memory" error, since at no time would I be accessing invalid memory.
Crash Report...
WinSCP 5.9.5
Cannot open remote file '/home/username/home/sites/example.net/sub-domain/_main_/www/index.php'.
(0062B452)
(0086700E)
(00869076)
(00865E30)
(0062B5BB)
(006FE49E)
(006FCB97)
(00738EB1)
(0073CE6D)
(007617B6)
(007656B9)
(007638E2)
(007636D6)
(0078836D)
(00011709)
(0001232D)
(00012912)
(00018156)
(00017FF2)
(004089F4)
(00406402)
(004068ED)
frank@...
Fehler beim Wechseln in Verzeichnis '/hp/bt/ac/dx/www' - _ssh_send_port_open
Usually happens after WinSCP idle in background for a longer time, maybe even requiring a PC sleep in between. Not sure.
WinSCP 5.9.6
Fehler beim Wechseln in Verzeichnis '/hp/bt/ac/dx/www'.
(008689AA) C5077_0
(000222FC) COMCTL32.DLL
(0008A4D2) COMCTL32.DLL
hugo@...
Error changing directory to '/var/www/cp.megs.co.za/public_html' - _ssh_send_port_open
WinSCP 5.9.5
Error changing directory to '/var/www/cp.megs.co.za/public_html'.
(0086700E) C5073_3
Re: Cannot open remote file '/home/username/example.net/_main_/www/index.php' - _ssh_send_port_open
joerg@...
Fehler beim Wechseln in Verzeichnis '/opt/otrs/Kernel/Output/HTML/Templates' - _ssh_send_port_open
While changing between different VPN-Connections
WinSCP 5.9.6
Fehler beim Wechseln in Verzeichnis '/opt/otrs/Kernel/Output/HTML/Templates'.
(008689AA) C5077_0
(0007DBD8) COMCTL32.DLL
(00066AD2) COMCTL32.DLL
(00015C3B%
I cannot reproduce the 11.
Please send me the email. Do not respond here. The "Automatic Bug Reports" forum is processed automatically for automatic reports only.
rsampsonpcss@...
WinSCP 5.9.6
#0062C826# _ssh_send_port_open
#008689AA# C5077_0
#0086AA12# ____ExceptionHandler
#008677CC# __ExceptionHandler
#0062C98F# _get_ssh_exitcode
#006FFB4E# TSecureShell::CheckConnection
#006FE247# TSecureShell::Send
#0073A561# TSFTPFileSystem::SendPacket
#0073E51D# TSFTPFileSystem::SendPacketAndReceiveResponse
#0073EB56# TSFTPFileSystem::RealPath
#0073F28E# TSFTPFileSystem::RealPath
#0074D4E9# TSFTPFileSystem::ChangeDirectory
#0077FCBA# TTerminal::ChangeDirectory
#006581D3# TUnixDirView::ChangeDirectory
#0065666A# TUnixDirView::ExecuteParentDirectory
#00408D0C# Customdirview::TCustomDirView::Execute
#004066FA# Customdirview::TCustomDirView::DoExecute
#004072C7# Customdirview::TCustomDirView::WMLButtonDblClk
#0024F5A1# Vcl::Controls::TWinControl::WndProc
#002934CF# Vcl::Comctrls::TCustomListView::WndProc
#00373564# System::Classes::_18201
#0001FD3A# USER32.dll
#0001FD60# USER32.dll.CallWindowProcW
#0042CD77# Dragdrop::TDragDrop::WndMethod
#00869015# C5077_0
#0086A5EF# _ReThrowException
#0073F029# TSFTPFileSystem::RealPath
dgloucks@...
Error deleting file 'c_upload/3rdparty/flexnav/js/index.html' - _ssh_send_port_open
WinSCP 5.9.5
Error deleting file 'c_upload/3rdparty/flexnav/js/index.html'.
#0086700E# C5073_3
#0074FE54# TSFTPFileSystem::DoDeleteFile
#0074FFCA# TSFTPFileSystem::DeleteFileW
#0077A397# TTerminal::DoDeleteFile
#0077A26E# TTerminal::DeleteFileW
#00778E11# TTerminal::ProcessDirectory
#0074FF67# TSFTPFileSystem::DeleteFileW
#00779701# TTerminal::ProcessFiles
#0077A510# TTerminal::DeleteFiles
#0001416B# TCustomScpExplorerForm::DeleteFiles
#0000E818# TCustomScpExplorerForm::ExecuteFileOperation
joerg.folckers@...
Fehler beim Wechseln in Verzeichnis '/opt/otrs/scripts/auto_build' - _ssh_send_port_open
nach Wechsel des VPN
WinSCP 5.9.6
Fehler beim Wechseln in Verzeichnis '/opt/otrs/scripts/auto_build'.
(008689AA) C5077_0
...yeah, unfortunately, I can't either. I tried at least 5 times after I posted.
When the error (with the stack trace) happened, I clicked Report (which took me here) & I tried to remember my steps to post in the report...either I missed a Step or something else is happening (random chance?). The only thing I can think of is: instead of "Step 5: Disconnect your Internet", just minimize WinSCP & wait a few hours or days...if you leave a connection open long enough & use your computer like normal (like putting it to sleep), the connection will drop eventually: either cuz the server gives up or you lose Internet or whatever. I thought manually disconnecting the Internet would simulate that, but I guess not...
...sorry, it's been a few days & I needed to respond with something: I didn't want you to think I wasn't gonna followup on this report. These "Invalid access to memory" errors do happen, a lot...it's just that, as soon as I finally reported it, I can't make it happen...but hey, if I never get another "Invalid access to memory" error then that's good too, I guess.
...do you wanna move my report (& its replies) to another Forum?...I only posted it here cuz that's where the Report button took me.
Also, note...when you say this...
...that assumes people are registered & can login, I'm not registered & cannot login, I haven't decided to register here yet. I would prefer to continue on the Forum, even if not in this topic or subforum.
Re: Fehler beim Wechseln in Verzeichnis '/opt/otrs/scripts/auto_build' - _ssh_send_port_open
WinSCP 5.9.6
(008689AA) C5077_0
Goto page
