[SOLVED] - Error code: 2 - Error message from server: No such file
Muffinz
Sweden
I'm trying to transfer some files over SFTP with a certificate and I'm getting this error message in the log:
. 2016-12-27 11:10:59.283 File: '\\Local\Path\Remove_ME.txt' [2016-12-27T09:13:02.320Z] [0]
. 2016-12-27 11:10:59.289 Copying "\\Local\Path\Remove_ME.txt" to remote directory started.
. 2016-12-27 11:10:59.289 Binary transfer mode selected.
. 2016-12-27 11:10:59.289 Opening remote file.
> 2016-12-27 11:10:59.289 Type: SSH_FXP_OPEN, Size: 48, Number: 259
< 2016-12-27 11:10:59.297 Type: SSH_FXP_STATUS, Size: 29, Number: 259
< 2016-12-27 11:10:59.297 Status code: 2, Message: 259, Server: No such file, Language:
> 2016-12-27 11:10:59.298 Type: SSH_FXP_LSTAT, Size: 32, Number: 519
< 2016-12-27 11:10:59.306 Type: SSH_FXP_STATUS, Size: 29, Number: 519
< 2016-12-27 11:10:59.306 Status code: 2, Message: 519, Server: No such file, Language:
* 2016-12-27 11:10:59.306 (ETerminal) No such file or directory.
* 2016-12-27 11:10:59.306 Error code: 2
* 2016-12-27 11:10:59.306 Error message from server: No such file
. 2016-12-27 11:10:59.306 Asking user:
. 2016-12-27 11:10:59.306 Cannot create remote file '/RemotePath/Remove_ME.txt'. ("No such file or directory.
. 2016-12-27 11:10:59.306 Error code: 2
. 2016-12-27 11:10:59.306 Error message from server: No such file")
< 2016-12-27 11:10:59.306 Script: Cannot create remote file '/RemotePath/Remove_ME.txt'.
< 2016-12-27 11:10:59.307 Script: No such file or directory.
< 2016-12-27 11:10:59.307 Error code: 2
< 2016-12-27 11:10:59.307 Error message from server: No such file
* 2016-12-27 11:10:59.307 (EScpSkipFile) Cannot create remote file '/RemotePath/Remove_ME.txt'.
* 2016-12-27 11:10:59.307 No such file or directory.
* 2016-12-27 11:10:59.307 Error code: 2
* 2016-12-27 11:10:59.307 Error message from server: No such file
. 2016-12-27 11:10:59.307 Script: Failed
It's working with the GUI and other applications as PSFTP.exe (from Putty) and FileZilla.
I've also searched this forum but I haven't found the answer.
This is my script:
# Get today's date and format it as ddMMyyyy_HHmm (exampel 27122016_1109)
$Date = Get-date -Format ddMMyyyy_HHmm
# Load WinSCP .NET assembly
Add-Type -Path "WinSCPnet.dll"
# Set up session options
    HostName = "HostName"
    UserName = "UserID"
    SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
    SshPrivateKeyPath = "\\Path\To\Key.ppk"
$session.SessionLogPath = "\\Path\To\Uploaded_$Date.log"
$sessionOptions.SshPrivateKeyPassphrase = "Password"
    # Connect
    # Your code
    $localPath = "\\Loac\Path\*"
    $remotePath = "/RemotePath/"
    # Upload files, collect results
    $transferResult = $session.PutFiles($localPath, $remotePath)
    Write-Host ("Upload succeeded")
    # Disconnect, clean up
    $session.Dispose()
Thank you in advanced!
P.S
This is the old thread if needed: https://winscp.net/forum/viewtopic.php?t=24255
Solution
The folder path are case sensitive which my college pointed out and after I change that it worked :oops:
You learn something new everyday :wink:
  • Uploaded_27122016_1110.log (10.25 KB, Private file)
Description: The complete logg
kavi
I have the same issue File or folder not found
I hav faced the same issue. Below is the sript
option batch abort
open ftp://user:password@home/
put E:\test.php /home1/www/
Re: I have the same issue File or folder not found
option batch abort
