Deletion of files within folders in root folder
daanbrg
The Netherlands
Hey everyone,
I'm a volunteer tech at the local community radio station. We have a system that automatically publishes recorded shows online. It keeps them online for 4 weeks, and then removes the references to these older shows to make room for new ones.
But only the references on the webpage are removed--the audio files themselves stay on the web server.
The publishing software works in a hierarchy to upload files. Every program has a unique ID, and a new episode of the program is uploaded to a folder with the ID for that program.
So the root folder of the FTP account for this program looks like this. A bunch of folders with ID numbers for each show that the station has:
And this is a look inside one of those folders:
I'd like to automatically remove these files when they are 35 days or older. Using a WinSCP example from StackOverflow, I tried accomplishing deletion of these files with the following batch script:
"C:\Program Files (x86)\WinSCP\WinSCP.com" /ini=nul /log=C:\Users\omitted\Documents\webdelete.log /command ^
    "open ftp://omitted" ^
    "rm /*<35D" ^
    "exit"
Unfortunately, this code does not seem to look inside the various folders, but only acts on the root directory. It does delete folders and files inside the root directory that are older than 35 days, but that's not of great help because most shows have one or more new episodes every week. That would update the folder's date, and render this code useless.
I've tried searching Google and this website for clues on how to do recursive deletion, but I can't get the obvious wildcards like *.* to work properly with rm and the <35D mask. Maybe rm is the wrong tool for the job, maybe the mask doesn't work for this particular situation... but I don't know where to look any more.
If you could help me solve this puzzle, that'd be greatly appreciated.
Thanks in advance, also on behalf of the more than 90 volunteers of our station!
Cheers,
Daan Berg
Re: Deletion of files within folders in root folder
It's not possible with the rm command.
But you can use a PowerShell script with WinSCP .NET assembly.
See this:
Delete files older than X days from FTP server with PowerShell or batch file
Though it does not actually descend to subfolder either. But if you replace the Session.ListDirectory with Session.EnumerateRemoteFiles with appropriate options ([WinSCP.EnumerationOptions]::AllDirectories), it will.
https://winscp.net/eng/docs/library_session_enumerateremotefiles
$remotePath = "/"
$files = $session.EnumerateRemoteFiles($remotePath, "*", [WinSCP.EnumerationOptions]::AllDirectories)
# Find old files
$limit = (Get-Date).AddDays(-35)
$oldFiles =
    $files |
    Where-Object { -Not $_.IsDirectory } |
    Where-Object { $_.LastWriteTime -lt $limit }
# Delete them
foreach ($oldFileInfo in $oldFiles)
    $oldFilePath = $session.EscapeFileMask($remotePath + "/" + $oldFileInfo.Name)
    $session.RemoveFiles($oldFilePath).Check()
Test it well, before running it on live data!
pladus
hello!
may plays with this command to delete files in subfolders
rm /*15D
and accidently I found this topic.
Please, tell me please if there is a option to make possible in rm (WinSCP scripting)
How can be your script above in NET, be automated in a batch?
I used these steps:
  1. bat file for WinSCP
    winscp /script=ftp_config.txt /log="D:\WinCSP\ftp_transfer.log"
  2. file_config – open FTP and synchronize options
    option batch abort
    open ftp://MyFTPServer -passive=on -timeout=60
    synchronize remote -preservetime -nopermissions -filemask="*.*" -transfer=automatic E:\BackUp\ /ftp_backup
    cd /ftp_backup/
    rm *<12D
pladus
Thanks, I will.
Before migrate to .NET, I did like on reply in topic, using FTPUSE, a freeware command-line tool which maps a FTP folder to a Windows drive letter.
Quick and not much effort.
: delete files older than 7 days from ftp://my.ftpsite.net/folder/subfolder
ftpuse F: my.ftpsite.net password /USER:username
timeout /t 5
forfiles -p "F:\folder\subfolder" -s -m *.* -d -7 -c "cmd /C DEL @File /Q"
ftpuse F: /DELETE
Maybe in next version, RD command will work to subfolders, so will be very nice.
Thanks for WinSCP!
