Using Directory.Exists allways give "false"
idan357
Hello all,
Im using "Directory.Exists" to verify if a folder exist and if not im crating it.
My problem is the the "Directory.Exists" is always false.
i want to verify "myfolder"
bool FolderExist= Directory.Exists("/folder1/folder2/myfolder");
im using SCP protocol and
session.ExecuteCommand("mkdir /folder1/folder2/myfolder")
to crate it later in the code and it works with no problem.
But still "Directory.Exists" is always false.
What am i missing here ?
BR,
Idan
idan357
Re: Using Directory.Exists allways give "false"
idan357 wrote:
Hello all,
BR,
Idan
Using
RemoteDirectoryInfo info1 = session.ListDirectory("/folder1/folder2/myfolder")
shows the directory info and the number of files under it.
Who says that Directory.Exists should work for remote paths?
Use Session.FileExists.
https://winscp.net/eng/docs/library_session_fileexists
It works for directories too.
If you want to test for directory explicitly, use Session.GetFileInfo and test RemoteFileInfo.IsDirectory:
https://winscp.net/eng/docs/library_session_getfileinfo
https://winscp.net/eng/docs/library_remotefileinfo
