Skip remote directory listing
lurker
Hi!
I'm using script to upload files, it looks like this:
open ftp://.....
put "D:\test.txt" /test.txt
So nothing special here, just connect and upload file.
The problem is that WinSCP always executes LIST command before file upload.
Remote directory contains 70000+ files and my download speed with that server is very low (but upload is very fast).
So in order to upload 1 tiny file my script have to wait for a few minutes to get the unnecessary directory listing.
Is there any way to skip that step?
Re: Skip remote directory listing
Make sure you are using the latest version of WinSCP.
If you are already, and still get this behavior, please attach a full session log file showing the problem (using the latest version of WinSCP).
sdt99
USA
I am having same problem (WinSCP, Version 5.15.9 (Build 10071))
I want to upload / download files using FTPS – I don't want overwrite warnings – just transfer the files. I'm using a script like this:
open ftps://.....
get filename1.txt
put filename2.txt
There are over 1 million files in the FTP root – I would like to disable the directory listing but I don't know how to do this.
Re: I am having same problem (WinSCP, Version 5.15.9 (Build 10071))
@sdt99: Please attach a full session log file showing the problem (using the latest version of WinSCP).
sdt99
USA
Log files
Here is the script:
open ftps://<username>:<password>@172.30.19.21/ -explicit
get ws_bdy.txt
put 000001000001.cfs
I have attached log files for two cases – one where the directory listing has been disabled at the FTP server (the file download works fine) and another where directory listing has been enabled at the server. I had to kick the user and truncate the log otherwise there would have been millions of files listed. I think you can still see the difference between the logs - in both cases winscp is sending the MLSD command (which I don't want and would like to disable).
Re: Log files
Ken Rokos
Los Angeles
Any updates on this?
I just started using EnumerateRemoteFiles and it shows the listing twice in the WinSCP log (set using $session.SessionLogPath = 'C:\WinSCPLog.txt'). It would be nice to suppress this in the log so I don't have a huge log every time I run this.
$InvFiles = $session.EnumerateRemoteFiles($SourcePath, 'INV*.dat', [WinSCP.EnumerationOptions]::None)
There are only a few INV files in the directory.
Re: Any updates on this?
@KenRokos: This is not what this thread is about.
Anyway, did you try to enable reduced logging?
$session.AddRawConfiguration("Logging\LogProtocol", "-1")
