Trouble on setting the permissions and/or timestamp via command line
I have a client with a SFTP server.
Here is the command line:
Here is the script:
After running the script I get following in console:
Using WinSCP 5.11.2 (build 7781) on Windows 2012 R2.
winscp.exe /console /script=test.txt /log=log.txt
Here is the script:
option transfer binary open sftp://Username:PASSWORD@XXX:22/ -hostkey="xxx" synchronize remote -delete -resumesupport=off -nopermissions -nopreservetime C:\CD \CD synchronize remote -delete -resumesupport=off -nopermissions -nopreservetime C:\DQ \DQ synchronize remote -delete -resumesupport=off -nopermissions -nopreservetime C:\IMP \IMP exit
transfer binary Searching for host... Connecting to host... Authenticating... Using username "Username". Authenticating with pre-entered password. Authenticated. Starting the session... Session started. Active session: [1] Username@ip xxx Comparing... Local 'C:\CD' => Remote '\CD' Synchronizing... Local 'C:\CD' => Remote '\CD' C:\CD\xxx.pdf | 736 KB | 97.4 KB/s | binary | 100% Upload of file 'xxx.pdf' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn off setting permissions or preserving timestamp. Alternatively you can turn on 'Ignore permission errors' option. The server does not support the operation. Error code: 8 Error message from server: (A)bort, (R)etry, (S)kip, Ski(p) all: Abort
