Error listing directory '/'
EricEnerplan
Suisse
When I try to connecting to a FTP server, WinSCP make a connection, start the session and when it try to read the remote directory an error happen.
Error:
Error listing directory '/'.
Command not implemented
It is the same with GUI or Powershell script.
It happens for two servers but works with a third.
It works with FileZilla :-) with all the servers.
I use WinSCP 5.13.8172 on Windows 7 Pro SP1.
Thanks.
Re: Error listing directory '/'
Please attach a full session log file showing the problem (using the latest version of WinSCP). As well as verbose FileZilla log file for comparison.
EricEnerplan
Suisse
You will found 3 log files :
1 - "SS01---192.168.15.20.log", a WinSCP log file of a working connexion.
2 - "SS10---192.168.15.10.log", a WinSCP log file of an unworking connexion.
3 - "filezilla SS10.log", a FileZilla log file of the same connexion than 2 (but works).
Thanks.
Fr_user
> 2018-03-23 13:51:54.583 PASV
< 2018-03-23 13:51:54.611 502 Command not implemented
. 2018-03-23 13:51:54.611 Could not retrieve directory listing
You have to configure WinSCP to use an active mode (= not to use a passive mode):
https://winscp.net/eng/docs/ui_login_connection
On my side, it was caused by an invalid caracter "?" shown in a filename.
Throuhg an ssh connection I removed this caracter (mv filename? filename) and the problem was solved
Regards,
