Date of the transferred file is not preserved
Patrick Fäh
Dear Support Team
The Preserve timestamp checkbox makes WinSCP preserve the last modification timestamp of the transferred file. However, that is not true. When I'm using FileZilla, it works!
WinSCP Version 5.13.6, SFTP
Best regards
Patrick
Patrick Fäh
Re: date of the transferred file is not preserved
Additional information:
Source: PC with Windows 7 Pro
Destination: Unix Apache
Connection: VPN
Thanks for the log. Can you set logging level to "Debug 2" and post a new log file?
Though it actually looks like a server-side problem. From the log, it looks like WinSCP correctly asked for timestamp update.
Patrick Fäh
Re: date of the transferred file is not preserved - 2019-01-29
WinSCP 5.13.7 set to Debug 2: just transferred pdf.gif.
With FileZilla 3.40.0 the date of the transferred file is correct!
Regards
Patrick
Description: .log, .xml, 3x .png
> 2019-01-29 17:30:06.051 Type: SSH_FXP_SETSTAT, Size: 66, Number: 2057
> 2019-01-29 17:30:06.051 09,00,00,08,09,00,00,00,2C,2F,62,69,6F,63,68,65,6D,2F,68,74,74,70,64,6F,63,
> 2019-01-29 17:30:06.051 73,2F,44,61,74,65,6E,62,61,6E,6B,2F,70,68,70,2F,66,6F,6E,74,2F,70,64,66,2E,
> 2019-01-29 17:30:06.051 67,69,66,00,00,00,20,01,00,00,00,00,48,B4,3A,6B,
This is a correct request by WinSCP to set a timestamp of a file /biochem/httpdocs/Datenbank/php/font/pdf.gif to 1219770987 (‭48B43A6B‬, 2008-08-26T17:16:27+00:00).
The server confirmed the request:
< 2019-01-29 17:30:06.091 Type: SSH_FXP_STATUS, Size: 26, Number: 2057
< 2019-01-29 17:30:06.091 65,00,00,08,09,00,00,00,00,00,00,00,07,53,75,63,63,65,73,73,00,00,00,02,65,
< 2019-01-29 17:30:06.091 6E,
< 2019-01-29 17:30:06.091 Status code: 0
Please report the problem to your server vendor. Actually, what SFTP server is that? It reports as OpenSSH, but uses SFTP version 5, what OpenSSH does not support. So it must be some proprietary server.
Patrick Fäh
Thank you very much for your work!
However, why the transfer with FileZilla works with this server?
Best regards
Patrick
I do not know. The server bug may manifest only in some very specific situations.
For example FileZilla uses SFTP version 3. While WinSCP is capable of SFTP up to version 6.
You can try forcing WinSCP to use version 3:
https://winscp.net/eng/docs/ui_login_sftp
Issue 2247 – Limiting SFTP version to 3 with non-well-known SFTP servers as a workaround for interoperability issues
