V 5.15 very Slow to start
andybrown
UK
Windows 7 Build 7601 SP1
Since upgrading from WinSCP 5.13.7 to WinSCP 5.15 the program is exceedingly slow to launch (5+ minutes). An exploratory with Process Monitor is indicating that the new version is attempting to poll (or otherwise interact with) several thousand potential UNC network locations, all of which are access denied. Although each interaction is subsecond, the cumulative effect prevents WinSCP launching in a timely fashion.
andybrown
Other thread
I've just seen the earlier thread about this issue here - missed because I didn't search for "lunch" !
I've tried the clean re-install and the alternative user (roaming profile corruption) options suggested, neither worked and in both cases process monitor demonstrated the same multiple UNC interaction behaviour. I'm happy to run a debug version of 5.15 if supplied, or a log if useful (although currently I've downgraded back to 5.13.7)
Re: V 5.15 very Slow to start
