Error deleting file
we are using WinSCP Version 5.15 (Build 9365) with the basicaly following script:
We are facing some issues when "larger" files are being transfered (starting with files around 10MB).
There isn't any other process accessing the files as far as I am aware.
Any idea what could be the problem here, and how to troubleshoot this?
We don't have access to the logs from the FTP server. But I can confirm that the files were uploaded (but not deleted localy).
Thank you.
option batch continue option confirm off open xxx@xxx:22 cd /upload put -nopermissions -nopreservetime -delete E:\outbound\abt\*.xml /upload/* close exit
. 2019-07-10 10:53:20.293 File: 'E:\outbound\abt\ABT0000028212.xml' [2019-07-10T08:44:03.817Z] [11700061] . 2019-07-10 10:53:20.293 Copying "E:\outbound\abt\ABT0000028212.xml" to remote directory started. . 2019-07-10 10:53:20.293 Binary transfer mode selected. . 2019-07-10 10:53:20.293 Opening remote file. > 2019-07-10 10:53:20.293 Type: SSH_FXP_OPEN, Size: 47, Number: 1280771 < 2019-07-10 10:53:20.310 Type: SSH_FXP_HANDLE, Size: 25, Number: 1280771 > 2019-07-10 10:53:20.310 Type: SSH_FXP_WRITE, Size: 32757, Number: 1281286 . 2019-07-10 10:53:20.621 622 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets. > 2019-07-10 10:53:20.621 Type: SSH_FXP_CLOSE, Size: 25, Number: 1372932 < 2019-07-10 10:53:20.621 Type: SSH_FXP_STATUS, Size: 24, Number: 1349126 * *bunch of similar entries * < 2019-07-10 10:53:20.721 Status code: 0 < 2019-07-10 10:53:20.722 Type: SSH_FXP_STATUS, Size: 24, Number: 1372932 < 2019-07-10 10:53:20.722 Status code: 0 . 2019-07-10 10:53:20.722 Transfer done: 'E:\outbound\abt\ABT0000028212.xml' => '/upload/ABT0000028212.xml' [11700061] * 2019-07-10 10:53:20.811 (EOSError) System Error. Code: 32. * 2019-07-10 10:53:20.811 The process cannot access the file because it is being used by another process . 2019-07-10 10:53:20.811 Asking user: . 2019-07-10 10:53:20.811 Error deleting file 'E:\outbound\abt\ABT0000028212.xml'. ("System Error. Code: 32. . 2019-07-10 10:53:20.811 The process cannot access the file because it is being used by another process") < 2019-07-10 10:53:20.811 Script: Error deleting file 'E:\outbound\abt\ABT0000028212.xml'. < 2019-07-10 10:53:20.812 Script: System Error. Code: 32. < 2019-07-10 10:53:20.812 The process cannot access the file because it is being used by another process * 2019-07-10 10:53:20.812 (ESkipFile) Error deleting file 'E:\outbound\abt\ABT0000028212.xml'. * 2019-07-10 10:53:20.812 System Error. Code: 32. * 2019-07-10 10:53:20.812 The process cannot access the file because it is being used by another process
Thank you.
