SFTP upload script not moving files
6packnbuzzed
States
Hello -
I'm having issues uploading files via SFTP to a remote host.Its supposed to move day old files to a temp folder, then upload those files to the sftp. I need it to run early morning through task scheduler but it doesn't move any files and i don't get any errors. If i run my batch file manually it works fine.. please help.
Batch:
cd C:\temp
del /q *.*
ROBOCOPY /MAXAGE:1 \\192.168.0.2\folder\folder\folder C:\temp
cd C:\Program Files (x86)\WinSCP
winscp.com /script=winscp.txt
Script file:
option batch off
open sftp://user:password@URL.com
put C:\temp\*.* /tlogs/
