- wilfredhagenaars@gmail.com
- 1
- tilburg
how can I do the command cd to folder "files jpg"
Site Admin -
- 43,194
- Prague, Czechia
Re: how can I do the command cd to folder "files jpg"
wilfredhagenaars@...
Hi Martin,
the "cd" command is the problem. The is the result and does not work???
Site Admin -
- 43,194
- Prague, Czechia
To generate the session log file, use
/log=C:\path\to\winscp.log command-line argument. Submit the log with your post as an attachment. Note that passwords and passphrases not stored in the log. You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names (unless they are relevant to the problem). If you do not want to post the log publicly, you can mark the attachment as private.Advertisement
