Refund for Store Purchase
CmdrKeene
I purchased Win SCP via the Microsoft Store, but unfortunately it doesn't work with my host and I can't upload files. My host pointed me to use "Core FTP LE" instead, which works without a problem.
Can I get a refund for the purchase? I just purchased it mere moments ago.
CmdrKeene
Basically the issue is it times out. For example trying to upload a folder (example 19MB worth of files to a plugin folder on a WordPress install directory). As it churns through the queue it will upload 5-10 files, then timeout and disconnect (I have to click reconnect on the dialog to continue, and sometimes it results in the host blocking login saying too many connections from IP). My Transfer/Background preferences were already and still are set to max number of transfers: 1.
A log file from Core FTP for a comparison would help too.
CmdrKeene
I attached the log file of trying to upload a folder (The wordpress Jetpack plugin, 19MB in total size across 1553 files). I am generating a log file from Core program now, it can upload the whole folder fine but it takes a LONG time to do it, it's got about 12 MB left to do. I don't know why it's so slow but I assume it must be on the server end since my uplink speed is great here.
