Synchronize script not properly working
Capric0rn
DO
I have a small script file to mirror changes in local drive (K:\). So far the used syntax is working except one but very important point:
No files are copied from local to remote! If a new directory is created on K:\ with files in it, the script will only create an empty new remote directory.
Here is my script:
option batch on
open sftp://username:pw@192.1xx.y.zzz
lcd k:\
cd /media/Backup/"Backup K"/
synchronize remote -mirror -criteria=time -rawtransfersettings ExcludeHiddenFiles=1 -delete -filemask=""|*/$RECYCLE.BIN/;*/"System Volume Information"/""
close
What is wrong with my script? I hope somebody can help me here. Thank you in advance.
Martin
Re: Synchronize script not properly working
First, try to fix the quotes in your script.
It should be like this: -filemask="|*/$RECYCLE.BIN/;*/System Volume Information/"
If that does not help, please attach a full session log file showing the problem (using the latest version of WinSCP).
Capric0rn
DO
Hi, Martin
that did it! Thank you very much for your quick response and your support...
Best regards,
Martin
