Filename changes during download
CK_in_Cincy
I have a cmd file, which I want to download any file from the site with an .OUT extension:
Text file:
option batch continue
open h-results@file.ftpsite.org
lcd C:\sftp_downloads\LS\
get *.out ./
Cmd file:
"c:\Program Files (x86)\WinSCP\WinScp.com" /script=C:\LS_scripts\lsftpscript.txt
The file I want to download has a name like RS00001.OUT, but it's downloading as .%F
Any idea why that happens? I'd like to keep the name intact.
Thanks!
Re: Filename changes during download
