note: if the problem repeats, try turning off 'optimize connection buffer size'
DazAK1984
I am getting the following error when running a send file push via a batch command to an SFTP location externally. "note: if the problem repeats, try turning off 'optimize connection buffer size'
I can perform the data transfer successfully manually by the WinSCP application. When running it via the command line from a batch file it give me the error on a file larger than 1mb. Anything smaller works fine. I have tried with the following:
#Start Script Code
Option confirm
open sftp://*******:***********@***********.com/incoming/20201201/
put \\******\London\FTPData\Dev\ -resumesupport=off -rawtransfersettings SendBuf=0 SshSimple=0
close
#end script
I am buffled and don't believe this is a network issue as it works via the gui without any changes within the GUI.
Any help ASAP would be greatly appreciated.
Re: note: if the problem repeats, try turning off 'optimize connection buffer size'
The settings though go to the open command:
open sftp://.../ -rawsettings SendBuf=0
Though if you believe the problem is different, please attach session log files both form the GUI and the script.
DazAK84
London
Attaching Logs
thanks,
I have added the recomemndation:
#Start Script Code
Option confirm
open sftp://**********:********@******.*******.com/incoming/20201201/ -rawsettings SendBuf=0
put C:\SFTP\*
close
#end script
attaching the log file as it still fails. It works via the GUI without issue. Also works from outside of my domain environment.
Re: Attaching Logs
So please attach a new log file. As well as a log file for "works from outside of my domain environment".
You should change your credentials, as you have posted them publicly.
