When connection is lost and WinSCP resumes, some files are not uploaded but skipped
ronwilliams
South Africa
option batch continue
option reconnecttime 30
open ftp://*****************/
put C:\WINDEX\ /public_html/Elements/2021
Re: When connection is lost and WinSCP resumes, some files are not uploaded but skipped
Please attach a full session log file showing the problem (using the latest version of WinSCP). Give us a name of a file that was "not uploaded but skipped".
